Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 01-07-2019, 08:40 AM   #251 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
- Tony
The Following 4 Users Say Thank You to arcosine For This Useful Post:
19bonestock88 (01-07-2019), Grant-53 (01-11-2019), order99 (01-07-2019), The Toecutter (01-25-2019)
Old 01-19-2019, 10:30 AM   #252 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Sorry for the dark and vertical picture
The Following User Says Thank You to iikhod For This Useful Post:
Grant-53 (01-19-2019)
Old 01-19-2019, 07:14 PM   #253 (permalink)
In this kind of weather I recommend a rack for the cross country skis.
The Following User Says Thank You to Grant-53 For This Useful Post:
iikhod (01-26-2019)
Old 01-25-2019, 02:06 PM   #254 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
Here's pics and video of mine:
Video of me riding it at 30+ mph:
https://vimeo.com/284616898
https://vimeo.com/284616919
Current configuration(weighing about 65 lbs with the body installed):
-x1 KMX adult-sized steel frame kit
-x2 Velocity USA 20" rims, 14ga spokes (front)
-x2 Gas Shocks (front, set to 60 psi)
-x2 Schwalbe Marathon Greenguard 20"x1.5" tires (front)
-x1 26" double-walled wheel with 12ga spokes (rear)
-x1 Schwalbe Marathon Plus Tour tire, 26"x1.5" (rear)
-x3 packs of KMC 3/32" anti-stretch 7 speed chain
-x1 DNP Epoch 7 spd rear freewheel cogset, 32-11T
-x1 Suntour XCT Jr. 22/32/44T front crankset with 152mm crankarms
-x1 Shimano Tourney 7sp rear derailleuer
-x1 Shimano Revoshift 7 spd grip shift
-x1 Microshift FD-M42 front derailleur
-x1 SRAM 3 spd grip shift
-x1 SunLite dual cable pull lever
-x2 Avid BB7 cable-pull disc brake rotors, calipers and organic pads
-Lights, cables, mirror, speedometer, ect.
I did remove the body to work on the trike though. I do not know when I will have the replacement ready to use.
The Following User Says Thank You to The Toecutter For This Useful Post:
Grant-53 (01-25-2019)
Old 01-27-2019, 07:20 PM   #255 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Now for something completely different...it looks it anyway.
I dont have a video yet of the corovelotrike, but I got one of the old Carp from 10 years ago,,,45 mph
Where is Reneckistan?
My other ride...
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
The Toecutter (01-28-2019)
Old 01-27-2019, 11:39 PM   #256 (permalink)
What are those pedals? They look like flip-flops in that picture
Old 01-28-2019, 12:44 AM   #257 (permalink)
I love this build. You're probably going to change the nose though; it looks like it would induce too much unwanted torque during crosswinds that could make you lose stability.
Where is Redneckistan?
Where I used to live, which was South Texas.
I just updated it to Ghettoville, USA, which is St. Louis, MO, where I am currently located.
That's fast.
My coroplast-bodied trike could reach 33-35 mph on the flat with me riding it. I've gotten up to 51 mph downhill when I still had the 28/38/48T front cranks on it. Flat ground cruising speed was about 21 mph.
I'm working on a new body that should be significantly less lossy. My steering bars limit my minimum possible width/frontal area as I have to have room to accommodate them, so my bodyshell should have significantly more area than yours. At best, keeping the stock steering setup, I could get a frontal area around 0.5 m^2 from the looks of things(and that's with having holes cut in the sides to allow the steering bars to move, with elastic boots made to flex in and out as I steer, but to seal the airflow up when I'm going straight).
If I had a rack and pinion steering or tiller steering, and the steering bar clearance wasn't an issue any longer, the possibility of getting a frontal area as low as 0.45 m^2 exists.
Right now it has front suspension and is very comfortable and stable, even over potholes. I can make lane changes at 45+ mph with confidence that I won't lose control.
I will eventually get to 40 mph top speed on flat ground, and a cruising speed of 25+ mph, fully under human power, dammit.
Once reached, whenever I can raise the funds, it is THEN getting an overpowered electric drive system, and possibly an upgrade to a rear suspension, as well as moped rims all around, integrated lights/turn signals, and a roll cage.
The goal is a vehicle that can move like a velomobile with electric assist disabled. When electric assist is enabled, I want it to operate as a pedelec with sports car-like acceleration with a 60+ mph top speed. The efficiency target is 3000+ miles per gallon equivalent and a 200+ mile range at 30 mph with a rider input of 100W and the electric drive providing the rest. Theoretically it's perfectly possible. Getting the aerodynamics right is key, and they're not good enough yet.
Old 01-28-2019, 11:52 AM   #258 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Hi,
Do you know Jerry .., use to live in Mo now Dallas? I lived in st Louis around 1990.
35 mph is pretty fast for flat ground and no wind. Yes a suspension is good. I rode on a bumpy bike trail, with cracks across, and it was like being inside and someone kicking the sides of a cardboard box. I put zote foam between the frame and coroplast.
I take it you built the bike from scratch, do you have a write up? I have 28/38/48/58 (4) on my swb bike, 20 inch fwd, runs out around 25-30. I hit 33 on the flat bike trial. I have the fairing loosely mounted in the front, people ask ifI have a suspension, its just the fairing moving.
Yes 40mph would be great. I had one bike 10 years ago that hit 40 mph one the flat ,well the one in the video, but it had a full enclosed top on it. The top made a big difference.
Yes the nose it from Warrens Barracuda mold, and it is too long, I tried it out 20 mph down hill into a 25 mph wind and 23F and was buffeted quit a bit, I want to make a new nose. I find the noses are the hardest to get right. I should just bite the bullet and carve up some Styrofoam make one from fiberglass.
The trike use to have USS and I changed it to OSS, made new linkages. This allowed me to lower the seat 3 inches, its now at 6.5 inch.Its hard to get out of with the oss, trying to get knees out from under the bars. I have no plans for electric drive. The fairing is 16 inches wide.
Do you do any touring in you coro faired trike?
- Tony
Old 01-28-2019, 12:12 PM   #259 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Zote foam over the toe clips, keeps toes warmer on -F days. Bike has studded tires, 700c wheels on a 26 inch frame and 165 cranks, gives snow clearance.
- Tony
Old 01-28-2019, 01:11 PM   #260 (permalink)
Use math.
You can't be wise and in love at the same time. -- Bob Dylan
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
EcoModder 100,000th Post Giveaway Spectacular!!! SVOboy Forum News & Feedback 35 05-09-2009 01:58 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
So you DO need collision insurance for a bicycle!!! Peakster Alternative Transportation 11 05-14-2008 12:32 AM
