Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 12-11-2018, 02:08 PM   #241 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Recently bought this beauty from a thrift shop for 30 euros. Plan is to put new tires, saddle, brake pads and that handlebar strap-thingy whatsit.
This bike is finnish made, Nopsa President 12-speed. No clue what year it is.
ID:	25207   Click image for larger version
Old 12-11-2018, 02:34 PM   #242 (permalink)
It looks light. The welds suggest an aluminum frame.
You can't be wise and in love at the same time. -- Bob Dylan
Old 12-11-2018, 02:41 PM   #243 (permalink)
90 day: 51.82 mpg (US)
latest junk bike
Sadly, my second Pirate Bike disappeared a week ago. This will be its replacement as my around-town junk bike:
This is my 5th junk bike that was being thrown away by a neighbour. (By now the neighbourhood should know to just drop off the old bikes at my driveway!)
Needs: blinky lights, mirror, splash guards, rear basket.
Sadly, it's only a 6-speed. Its predecessors were 18 & 21.
Name:	pirate bike supercycle.jpg
Old 12-11-2018, 05:14 PM   #244 (permalink)
The Nopsa tubing diameter looks like a steel frame compared to my aluminum Jamis Aragon. A quick check with a magnet tells the tale. Most peole lose the inboard brake levers. I put extra padding under the handle bar tape.
In the relatively flat 1000 islands a 36T or 38T chain ring and a 28T rear should be adequate. The only time I use my low 28T chain ring is on our elevated bridges or steep hills. But then I'm getting old.
Old 12-11-2018, 06:48 PM   #245 (permalink)
You are correct, sir -- all steel. It's a bottom-rung cheap department store bike.
The gearing is adequate, yes. But I'm lazy, and I find I'm missing the granny gear the previous bike had!
Old 12-12-2018, 12:15 AM   #246 (permalink)
Freebeard and Grant, i had to go inspect the bike with a magnet. Steel frame allright, all the other bits and pieces are aluminum though.
And yes, it is fairly light too.
Old 12-12-2018, 02:30 PM   #247 (permalink)
I was phishing for a weight.
In my defense it was a small picture. The weld look unfilleted, as aluminum frame usually are. Aluminum often has a bigger oval down tube.
Old 12-13-2018, 02:24 AM   #248 (permalink)
11.3kg, measured on a people-scale so maybe not the most accurate result
The Following User Says Thank You to iikhod For This Useful Post:
freebeard (12-13-2018)
Old 12-13-2018, 09:35 AM   #249 (permalink)
11.3 kg is about 25 lb. That is common for this type of bike. I have done testing and calibration as an engineering tech for 25 years. You never know what will surprise you next. That's why we say "test don't guess". I consider freebeard and MetroMPG master ecomodders of good reputation.
The Following 2 Users Say Thank You to Grant-53 For This Useful Post:
freebeard (12-13-2018), iikhod (12-13-2018)
Old 01-06-2019, 04:51 AM   #250 (permalink)
Stopped for some water on my usual route.
This is my new to me-mtb i got couple of weeks ago, white xc275 lite with the 21"frame.
ID:	25386   Click image for larger version
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
EcoModder 100,000th Post Giveaway Spectacular!!! SVOboy Forum News & Feedback 35 05-09-2009 01:58 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
So you DO need collision insurance for a bicycle!!! Peakster Alternative Transportation 11 05-14-2008 12:32 AM
