03-07-2020, 08:31 PM
#491 (permalink)
Epickups will fail. Can't idle them for hours on end! Can't pull the mufflers off for the BOOM BOOM.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
03-07-2020, 10:49 PM
#492 (permalink)
Originally Posted by aerohead
The attribution for the 1937 Schl'o'wagen has always been Mr.Shl'o'r.I didn't want to confuse anyone.I meant it to be in it's own column,and the only way to separate it to the left is with all the period marks,or something else.
The L/W ratio impact would fall below plan view leading edge radii,body camber,plan taper,and boat-tailng.The L/H is the most important metric as far as aero drag goes,according to Hucho.I've never seen a counterfactual example,so I'll leave it at that.
Every other full size pickup also shares the Cybertruck's L/H.
The Following 2 Users Say Thank You to Hersbird For This Useful Post:
03-08-2020, 12:01 AM
#493 (permalink)
How do you roll smoke with electricity?!
The Following 2 Users Say Thank You to Xist For This Useful Post:
03-08-2020, 09:54 AM
#494 (permalink)
Rolling smoke is so Jurassic...
https://en.wikipedia.org/wiki/Tesla_coil
The Following 3 Users Say Thank You to RedDevil For This Useful Post:
03-08-2020, 11:48 AM
#495 (permalink)
Give no attention to driving while autopilot is engaged, then have a semi pull out in front of you.
03-08-2020, 01:16 PM
#496 (permalink)
Moderator
Exactly what I was going to point out. L/H ratio is only part of the story.
03-08-2020, 04:28 PM
#497 (permalink)
Poke a cell pack or two with something long and ice pick like.
Take the battery to DEAD and recharge at a fast rate. Waaay overcharge.
Take out a light pole at 2am.
03-08-2020, 05:51 PM
#498 (permalink)
Originally Posted by RedDevil
Electric boat tail.
.Two wrongs don't make a right, but three lefts do.
03-11-2020, 11:00 AM
#499 (permalink)
every other
Yes! It's why they'll all,as BEVs,have no trouble coming in at,or below Cd 0.30 if they want to.
03-11-2020, 11:25 AM
#500 (permalink)
rolling coal
Elon's worked out an agreement with a Hollywood special-effects group, to provide an OEM-optioned faux 10-inch tailpipe,with diesel-smoke-colored smoke cookies, to provide the effect on command;along with a simulated, 120 dB,turbo-diesel soundtrack,played through a 15-inch,all-weather JBL transducer.
Consumers can choose between Caterpillar,Cummins,Navistar,Detroit Diesel,MAN,Steyr,Hanomag,or any of hundreds of available brands.'Idling',and gear-grinding soundtracks come with all packages.White-smoke, 'blown head-gasket' cookies are also available.Also,faux DEF fill ports,and naked-babe,chromed-emblem mudflaps,bull-testicles.
