Old 07-08-2014, 05:40 PM   #11 (permalink)
A.J. - '04 Honda Civic LX
90 day: 41.47 mpg (US)
bruce - '08 Kawasaki Ninja 650 R
90 day: 46.52 mpg (US)
Big Blue - '09 Ford F-150 LX
90 day: 17.33 mpg (US)
dr - '13 Kawasaki DR650
90 day: 55.32 mpg (US)
Thanks for the replies. I finally found a few days to go home and start construction. I went the EMT/Rivet route as it is super easy to rivet. I will definitely be using the rivet gun for everything.
Similar to the Redneck Boattail I attached the top two bars to the car using existing Kammback holes and bent them until they matched the template. Then I bent the end elliptical piece which was easily the hardest part without a conduit bender. Then I attached the bottom two bars and started making cross members to add strength. I unfortunately ran out of time and conduit so I had to stop. I also tried to at least get the wiring complete but I need a 5 to 4 pole tail light converter for my car and the lights I got for it to work. I will resume production as soon as I graduate in August.
BTW, the boattail extends 36" past the bumper.
ID:	15347   Click image for larger version
ID:	15348   Click image for larger version
ID:	15349   Click image for larger version
The Following 7 Users Say Thank You to bs25942 For This Useful Post:
aerohead (07-08-2014), BamZipPow (07-09-2014), echo-francis (07-08-2014), Joris (07-08-2014), MetroMPG (07-08-2014), redneck (07-08-2014), whatmaycome14 (08-26-2014)
Old 07-08-2014, 08:49 PM   #12 (permalink)
Looking good.
Be sure to put a big x in between the lower bars to help control lateral movement. Also a bar on each side attached where the bar is bolted to the bumper up to the top of the back panel which will help control vertical movement and bouncing. The more cross bracing added, the better.
The Following 3 Users Say Thank You to redneck For This Useful Post:
aerohead (07-10-2014), bs25942 (07-09-2014), Cd (08-06-2014)
Old 07-09-2014, 12:55 PM   #13 (permalink)
You might consider these to be improvement. ..or not.
Please find 3 magenta lines (I had this blown up while I worked on it). The middle line, at the rear fender, is a much shallower curve than the other two. Shouldn't it be intermediate?
The yellow line shows an opportunity for a '57 Mercury type fender skirt.
If you carry the character line that runs through the door handles onto the boat tail it will tie it together visually. What will you skin it with?
UltArc (07-10-2014)
Old 07-09-2014, 01:20 PM   #14 (permalink)
My plan is to use 1/2" expanded polystyrene and cover it with a single layer of 6 oz fiberglass/polyester resin and a top coat of just resin.
Old 07-10-2014, 02:50 AM   #15 (permalink)
Good luck with that. A good surface finish can be obtained with a carefully worked female form.
I have experimented with, but not bough a good quantity of PolyMetal. It's like a metal/plastic plywood; equivalent to 5/8" ply but with 1/10th the weight. I have sheared, rolled and braked PolyMetal by hand (18" lever arm). Right now I'm working on a fastener detail, but I need to get a router repaired. I see the joining done with an H-channel strip glued and/or riveted along a simple curved edge of adjacent rolled sections.
Peel the protective paper off and you have a prefinished enameled aluminum skin. I really want to build a teardrop trailer this way.
Old 08-06-2014, 11:15 AM   #16 (permalink)
Update: I went home for a few days and finished the frame as well as electrical. I think I will put two straps from the trunk lid to the bottom member about 10" from the end of the tail to give more support. After using rivets and bolts I now see the huge benefit a weld joint would have on stiffness. Since there is still some pivot play in the large X I will have to put a lashing around it to stop any rotations and will hopefully weld it when I can get to my grandpa's place. I plan to start the skinning process on the 14th of August when I finally get done with school.
The Following User Says Thank You to bs25942 For This Useful Post:
aerohead (08-06-2014)
Old 08-06-2014, 11:58 AM   #17 (permalink)
Look into gusset plates.
aerohead (08-06-2014), Cd (08-06-2014)
Old 08-06-2014, 02:16 PM   #18 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Be careful welding galvanized metal.
The Following 2 Users Say Thank You to elhigh For This Useful Post:
bs25942 (08-26-2014), darcane (08-25-2014)
Old 08-25-2014, 06:37 PM   #19 (permalink)
Ok for now I am done. I put the foam over the frame and held it down with zip ties and bolts. I then fiberglassed over it and that's when disaster struck, for the left side anyway. The resin fumes got under the foil and ate away at the foam over a large area on the side. I cut it open and sprayed some Great Stuff and made it look as good as possible before taping it back down. I then taped the edges and painted everything. I plan on redoing it in 6-12 month with foam sandwiched between coroplast. The urethane foam is too stiff to work with without cutting and gluing it together so no more fiberglass...it was expensive anyway. I am thinking the corofoam sandwich should be very strong and stiff. I have only driven it 90 miles or so but it seems likes it is doing the job. It will take a while to tell how effective this iteration is.
ID:	15673   Click image for larger version
ID:	15674   Click image for larger version
ID:	15675   Click image for larger version
ID:	15676   Click image for larger version
The Following 6 Users Say Thank You to bs25942 For This Useful Post:
aerohead (08-25-2014), California98Civic (08-25-2014), MetroMPG (08-25-2014), redneck (08-26-2014), t vago (08-25-2014), whatmaycome14 (08-26-2014)
Old 08-26-2014, 02:19 AM   #20 (permalink)
90 day: 30.54 mpg (US)
Great progress!
aerohead (08-26-2014)
