04-01-2015, 06:45 PM
#481 (permalink)
proof of operation
Bam,do you remember back when GM cars had fiber-optic bundles which led from all the lights to small indicator panels on the fender tops?
This was an elegant solution.
04-02-2015, 08:29 AM
#482 (permalink)
Rat Racer
We had those. There was also a pod centered above the backglass with brake light indicators (repeaters?) so you could see them while backing.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
04-02-2015, 04:10 PM
#483 (permalink)
I was thinking the same thing; except using a fiberoptic cable all the way to the dashboard. Quick disconnect would be possible but non-trivial.
04-02-2015, 05:19 PM
#484 (permalink)
T-100 Road Warrior
I will keep in mind that type of ingenious technology if I come across the materials fer cheap and figure a way to implement them.
Fer now, I only have the dead wiring harness that I can put to use...which is basically free.
I did notice yesterday's run was rather smooth with the new tire installed.
I've been also looking/researching other replacements fer the air bag when the time comes to replace it due to age/wear. The Firestore Work-Rite suspension was too big and cutting it down would've reduced it's capability to function as designed. I ended up returning it today. I will need to contact Timbren about the axle-less suspension as it looks promising to use their 400lb rated spring as the air spring replacement in Dark Aero. I will probably have to install a bump stop fer the rebound. I will lose the adjustability of the air bag spring though.
Axle-Less - Timbren Industries Inc. Suspension Products
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
04-03-2015, 02:52 PM
#485 (permalink)
T-100 Road Warrior
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
04-03-2015, 03:25 PM
#486 (permalink)
T-100 Road Warrior
Doing more research fer the spring suspension...here's what I've come up with so far:
Original solid rubber puck, 2" thick, 3.75" diameter, 5/16"x1.5" studs
(Current) Goodyear Air Sleeve Spring, 1S3-013, 1.5" height (compressed), 3.6" height (expanded), 3.2" base diameter, 2.6" top diameter, 5/16" top bolt, 3/8" bottom stud/air port, 100psi (max)
Here's what I've found so far looking at airless airbag/springs:
Firestone Work-Rite, no suitable products that can be fitted because of the hollow core design
Timbren Axle-less suspension, potential in the 400lb rubber suspension part, 1" deflection when compressed, less than 3.5" wide, approximately 4.5" long, approximately 2.5" tall, unknown core
SumoSprings Solo, solid core, 5/16" stud attached, potential to cut down and attach a threaded insert to secure to the bottom, manufactured to various heights, densities, and diameters
The SumoSprings Solo has the biggest potential to replace the Goodyear airbag spring provided I can get some specs on the models they have available.
SuperSprings Self-Adjusting Suspension Stabilizers > SumoSprings-Solo
04-03-2015, 06:43 PM
#487 (permalink)
Sumo might be best. But take your time. Timbren has a great rep for consulting with those wanting to use their Aeon hollow rubber springs. All of them are going to want to know something about weight, lever angle and expectations.
The Following 2 Users Say Thank You to slowmover For This Useful Post:
04-04-2015, 06:41 PM
#488 (permalink)
T-100 Road Warrior
04-05-2015, 02:45 PM
#489 (permalink)
T-100 Road Warrior
Had a crazy idea of using the Kong dog toy as a possible replacement fer the air spring. I should be able to cut the bottom ring off and put a bolt and washer through the top to secure it to the articulating section of the single wheel. I'm not too sure how much weight compression the toy can handle over time though.
04-06-2015, 12:42 PM
#490 (permalink)
T-100 Road Warrior
Big picture view of Dark Aero hooked up. No load in the bed or Dark Aero...65psi in the air shocks and 95psi in the air spring.
