04-12-2015, 05:07 AM
#501 (permalink)
T-100 Road Warrior
Made a quick run with the original rubber puck installed and I can say that I really miss the air spring ride. I believe the air spring isolated the road vibrations much better than the solid rubber puck. Too bad the air spring I installed wasn't able to handle the load.
I might try a lower PSI in the air shocks to see if it will make a difference or not in the road vibrations.
I've ordered a bigger single convoluted air spring (a used one fer $25 shipped from eBay) and I'll see if that will fit within the dampener section or not. The Goodyear/Enidine Y1-1B5-500 should fit and has a bigger air volume than the Goodyear Y1-1S3-013 that I used before. Since the air volume is bigger, I should be able to run a lower PSI to perform the same load rating as the smaller one.
Both the base and top mount plate of the bigger air spring are aluminum vs the plastic plates on the smaller one. I'll have to drill some extra holes in the dampener section so I can mount the new air spring.
If it doesn't fit without rubbing in the dampener section, I'll have to extend the area with some metal plate or cut down the boxed in area. I'll be consulting with a local metal fab shop if I go in that direction. I'm looking to bolt the plates in place but if I have to git them welded in place...I can have that done, too!
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
04-13-2015, 12:13 PM
#502 (permalink)
T-100 Road Warrior
04-16-2015, 01:50 PM
#503 (permalink)
T-100 Road Warrior
04-22-2015, 07:48 PM
#504 (permalink)
T-100 Road Warrior
04-23-2015, 03:11 AM
#505 (permalink)
T-100 Road Warrior
Couldn't wait until morning so I hooked Dark Aero up and went fer a spin.
I went to the Lowes where my rig was posted on reddit so I could shop fer some stainless steel fasteners. Got approached by 3 people about my rig. Another person was snapping piccies when I came back out. Ended up chatting with him fer about 30 minutes and showed him everything on the truck including the cab cover as well as the Sparebumper device. Maybe he'll go and buy a Sparebumper device to help protect his family.
First impressions...I really did miss driving with the air spring when compared to the original rubber puck. It seems as though the bigger air bag (as well as the longer distance from the pivot point) provided more air to dampen the road with as the ride seemed a lot smoother than with the first air bag spring. I didn't put any sand ballast in Dark Aero on this trip but I will load up the trailer in the morning with about 180lbs to see how well it will handle the load increase.
So size does matter when it comes to air bag springs.
I'm tempted to go out and drive around some more...
04-23-2015, 08:06 AM
#506 (permalink)
Rat Racer
Make sure you include all that parking lot chit chat time in your average speed calculations.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
04-23-2015, 09:46 AM
#507 (permalink)
T-100 Road Warrior
Loaded up with 120lbs of sand ballast over the single wheel. Bumped the air pressure in the air bag spring up to 50psi to account fer the extra load.
The smaller bumps in the road seems to have less of an impact on the road vibrations felt through the truck. Can't say it helps on speed bumps though...
04-24-2015, 03:59 AM
#508 (permalink)
T-100 Road Warrior
Been doing more brainstorming on how to reduce or eliminate the sand ballast from the design. The current sand ballast setup is used to keep the rear wheel planted to the road when traversing over bumpy roads. The current geometry of the air shocks don't allow immediate engagement fer these smaller bumps.
I figure I might be able to change the angle of the air shocks so they would be closer to a 45 degree angle to git the maximum amount of energy transfer and the air shocks would engage quicker compared to the near vertical position they are in now. The key will be to allow fer clearance of the tailgate when the tailgate is in the lowered position and how much articulation range the new position will allow. It may have to be where the tailgate cannot be in the lowered position when traveling with Dark Aero when traveling in extreme approaches...not that I have ever done that with the current setup.
04-24-2015, 10:16 AM
#509 (permalink)
Originally Posted by aerohead
How about some of those 'CAUTION : RADIOACTIVITY' emblems?
Or: 1/2-Law of Thermodynamics
Fallout Symbol Decal Sticker | Zazzle
Pulled the rudder off and put on new reflective "1WD" lettering on the both sides of the tail cone.
I haven't been here in a while, but I have to say that fin looks pretty cool. You're really going all out on this!
The Following User Says Thank You to Sven7 For This Useful Post:
04-24-2015, 04:58 PM
#510 (permalink)
45-degree
All I can think of,is to create a short pivoted link (which won't obstruct the end of the tailgate) which translates the bucking forces of the trailer to a double-armed pivot,which then translates the pivoting motion to the air-shock which is moved lower or under.Indycars and Formula -One cars do creative things with their suspension with components at odd geometries.
