Old 10-15-2010, 12:25 PM   #91 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Power source |= energy source.
By that definition, the Prius is not a hybrid.
The Insight is not a hybrid.
They only have one energy source.
But they do have two power sources. Like a diesel electric locomotive does.
Which diesel electric locomotive?
Old 10-15-2010, 12:45 PM   #92 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
please describe what precisely makes the electricity in a standard locomotive a distinct source, and not just a very temporary conversion (i.e. a glorified bicycle chain or a torque converter)?
Old 10-15-2010, 03:08 PM   #93 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
My car's a hybrid because I move it out of the garage under human power, then down the driveway on electric power.
Old 10-15-2010, 03:45 PM   #94 (permalink)
dcb
needs more cowbell
dcb's Avatar
My car has electricity going to the radio = hybrid
Old 10-15-2010, 04:59 PM   #95 (permalink)
Old 10-15-2010, 05:53 PM   #96 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
I drive a Hybrid (HCH II), but more than one person has told me that it is not a REAL hybrid because it can not run only in electric mode. I told them it can for a very brief moment between 18.5 mph and 19 mph .
Fooling around with alternating current is just a waste of time. Nobody will use it, ever. Thomas Edison, 1889.
Old 10-15-2010, 06:30 PM   #98 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
You fail to see the difference, these cars have a storage medium, which power can be transfered to via regen braking and generation by the engine. If you totally disallowed generation by gasoline, then they could still generate electricity by braking using that to propel the vehicle as well as using the gasoline engine.
A diesel electric train cannot do this. it cant store, it cant generate separate from the diesel.
As a side note, I fail to see why people are so upset about this chevy. The Motor Trend test confirms serious potential, and if you have a car that goes down the highway and switches to gas only, how is this bad. I cant imagine that using the inefficiency of gas and electric combined, or using one to produce the other, is going to net better results than using each separate.
Old 10-15-2010, 06:41 PM   #99 (permalink)
A hybrid drivetrain does not require two energy sources, nor does it require a storage medium for all the different energy sources.
It only requires two or more power sources i.e. two kinds of motors.
Motor Trend Claims Volt Gets 127 MPG, Not Quite True – Gas 2.0
Old 10-15-2010, 07:16 PM   #100 (permalink)
dcb
needs more cowbell
dcb's Avatar
Diesel-electric transmission - Wikipedia, the free encyclopedia
"In some high-efficiency applications, electrical energy may be stored in rechargeable batteries, in which case these vehicles can be considered as a class of hybrid electric vehicle."
what kind of term is "hybrid driveline" anyway?!? We were talking about hybrid vehicles. And a locomotive is still a crummy example for a car in the trying to justify series hybrid in range extended mode debate. In ragne extended mode I would most likely be cruising at a fairly constant speed/load headed out of town = parallel FTW. That's why I'm glad to see the volt with some parallel capability, because you can turn off the electric baggage and pretend its not a hybrid at cruise. two clutches sounds like a good deal too. It is obviously too much engine though (and $$).
chevy volt, failure, hybrid
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
"Homebrew" Chevy Volt: Possible? ncc74656m EcoModding Central 24 10-14-2008 10:52 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
