10-14-2010, 03:51 PM
#81 (permalink)
They have two kinds of motors (aka power sources), that are used together to move the vehicle.
If two sources of energy are required to be a hybrid -- then there are NO hybrids sold in the USA; zero, none. The energy in the batteries of Prius' and Honda hybrids comes from the gasoline; so just one energy source.
Only plug-in conversions meet that criteria...
Take away the battery in the Volt (or don't charge it) and it turns into a conventional car? I think it would still be called a serial/series hybrid.
There are (obviously) a lot of variations in the bits and parts and combinations and different types of hybrids. Who's to say what parts are required to "be" a hybrid?
No mention of batteries, or plugging in...
It seems very simple to me. I'm still not sure if you agree on the definition of hybrid. Assuming you agree a hybrid vehicle is one that can use 2 power sources to move, it should be clear how a hybrid car is, and a locomotive is not.
The Prius is a good example. Obviously it can be powered from gasoline alone, and with a plug-in option it can drive from a battery charged from a different power source. It should be equally as obvious you cannot do that with a locomotive, at least one that can't reach to overhead electric lines.
Not everyone agrees on the definition. However, none of the others make sense to me.
I'm not coasting, I'm shifting slowly.
10-14-2010, 06:13 PM
#82 (permalink)
Pokémoderator
Neil -
Ay, there's the rub. While I prefer the idea of concise definitions of what it means to be a type of hybrid car, I don't think anyone implements the classic definitions in the real world.
Conceptually I'm a series-hybrid snob because I *like* the idea of being able to swap out the "generator component" and leave the rest of the drivetrain alone. That way when the oscillation overthruster finally makes it to market, I can just "swap it in" and keep going along my merry way.
CarloSW2
10-14-2010, 08:36 PM
#83 (permalink)
From the Wikipedia entry on Hybrid Vehicles:
A hybrid vehicle is a vehicle that uses two or more distinct power sources to move the vehicle.[1] The term most commonly refers to hybrid electric vehicles (HEVs), which combine an internal combustion engine and one or more electric motors.
Power sources for hybrid vehicles include:
* On-board or out-board rechargeable energy storage system (RESS)
* Petrol or Diesel fuel
* Hydrogen
* Compressed air
* Liquid nitrogen
* Human powered e.g. pedaling or rowing
* Wind
* Electricity
* Compressed or liquefied natural gas
* Solar
* Waste heat from internal combustion engine.
* Coal, wood or other solid combustibles
* Electromagnetic fields, Radio waves
A diesel electric locomotive uses two of these energy sources: diesel and electricity. It has two power sources: diesel engine and electric motor. It uses them together to drive the train -- without either one, it would not work.
It combines two power sources i.e. it hybridizes two things for one purpose i.e. it is a hybrid.
10-14-2010, 08:58 PM
#84 (permalink)
needs more cowbell
that is like calling a bicycle chain an energy source.
Without one it will not work means they are not distinct sources of power.
A car with an automatic has a hydraulic coupling too, that don't make it a hybrid.
10-14-2010, 09:05 PM
#85 (permalink)
Lotsa Master Debating going on...
10-14-2010, 09:13 PM
#86 (permalink)
EV test pilot
Ah, like HYDROGEN.
10-14-2010, 09:21 PM
#87 (permalink)
needs more cowbell
if you take the battery out of a hybrid, you no longer have a hybrid. It can only run off of the stored gasoline power, not the stored electric power. It's that simple.
FYI, I consider this is a hybrid, it is designed to be propelled by foot and/or electricity:
10-14-2010, 09:27 PM
#88 (permalink)
I think two or more DISTINCT power sources is fairly self-explanatory.
A diesel electric train uses a diesel engine to generate electricity, which drives the wheels through electric motors. Primarily because most mechanical transmissions will not hold up to the stresses.
Not a hybrid.
If you recovered the braking energy in some form of storage and used it for re-acceleration, then it would be a hybrid.
It was interesting to read that they tried diesel hydraulic trains, and they were more efficient that the diesel electrics, but had reliability problems.
regards
Mech
10-14-2010, 10:20 PM
#89 (permalink)
Bus - '94 Ford School Bus huge Stupid - '01 Chevy Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Honda Superhawk
By the definition that people are arguing with, a car with an automatic transmission is using two sources to provide locomotion, as the trans could go into lock up or it uses a fluid viscous coupling that the engine inserts energy into, where the energy is stored in a fluid through motion and then transferred to the transmission. Just because the diesel engine develops electricity, doesnt make it a hybrid. the electricity is just the "driveshaft". One might argue that a nuclear plant is a hybrid power plant, as they develop steam from the fusion and use that to spin a turbine to produce the electricity. Maybe people would feel better about nuclear if we called it a hybrid.
10-15-2010, 11:26 AM
#90 (permalink)
Power source |= energy source.
By that definition, the Prius is not a hybrid.
The Insight is not a hybrid.
They only have one energy source.
But they do have two power sources. Like a diesel electric locomotive does.
