Old 01-24-2014, 01:57 PM   #101 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I would go for the 175 series for my saturn.
- Tony
Old 01-24-2014, 02:21 PM   #102 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Deflection is essentially like rolling uphill all the time, and even the small surface bumps in the paving add a little to that.
I don't think your small bumps theory is included in current rolling resistance tests (smooth rollers)...
A larger diameter wheel "bridges" across more of those bumps, and all else being equal, a larger diameter tire will have lower rolling resistance than a smaller diameter tire.
Not entirely because of what you think though, a WIDER tire bridges more bumps too in that case. To use your style of reasoning, why don't cars have 10,000" wheels?
Old 01-24-2014, 04:38 PM   #103 (permalink)
P-hack's Avatar
And well I suppose there is this to think about too with truck like inflation pressures and narrow tires:
The Following User Says Thank You to P-hack For This Useful Post:
TexasCotton (04-02-2014)
Old 01-24-2014, 06:36 PM   #104 (permalink)
I think it's because the contact patch of the tire between the road deforms the roundness of the tire. That deformation becomes rolling resistance and has been described like your driving up a very shallow grade. The larger diameter tire 'should' rotate into the contact patch at a shallower angle and thus deflects less as it deforms into the contact patch.
I would love to have a tire with 0 aspect ratio and no deflection. Almost like a solid metal train wheel which has a rolling resistance equal to or less than the best racing bicycle tires.
I try to be helpful. I'm not an expert.
Old 02-04-2014, 11:20 PM   #105 (permalink)
Originally Posted by sheepdog 44 View Post
Comfort be dammed! I'd like to see tires with NO sidewall. Just the inch and a half thick tread fixed onto the rim. Then there'd be practically no rolling resistance.
Ive been looking over a few older threads, there seems to be a popular disconnect.
Over at the prius forums people have been experimenting with larger than OEM rims (but important to stress same rolling diameter) just for the 'looks' of it. The experience is, that even with tyres with good RR data, the fuel economy rises some 3-4 mpg shifting up from the very light 15" OEM wheel to something in the area of 17-18" diameter rims.
The problem is, we have been unable to establish a common RR formula for both standard size and larger diameter tyres. We have been unable to adequately correlate a data set that examines different tyre diameters on the same rolling diameter. Despite numerous examples were in fact, unable to find a case were people had fitted similar weight wheels in larger diameters, with tyres provided by the same manufacturer in the same pattern.
It always seemed logical to me that very small sidewalls would create a lower weight tyre, which would offer better sidewall control, and therefore better mileage. But experience has proven this to be flawed, and I think because as lower tyre weights are apparently more than offset by heavier wheels. Add to that generally taller wheel diameters always seem set to wider than conventional rims, generally adding to the aero drag and generally behaving different to stock diameter footprint.
This could also mean, you might be tempted to do this for the additional contact patch at similar psi. IOW reasons of safety in more marginal driving conditions. Which is ok, options are good, but it isnt a like with like comparison if fuel economy was of interest to you.
We also found that, it mattered if summer or winter driving conditions, but have been unable to establish if this is because the tyres themselves are warmer and less brittle on the road or if winter driving conditions just made general fuel economy suffer.
I think we desperately need to know some things, like a common RR for tyres of different diameters. And establish rim/tyre combos that come out as near equal weights. Only then will this argument be scientifically settled. But the fact remains is that despite this thinking, practical experience proves that larger diameter wheels fitted with suitable low profile tyres of the same rolling diameter will increase MPG in the area of 3-4 MPG.
The Following 2 Users Say Thank You to sidecar For This Useful Post:
NeilBlanchard (02-05-2014), Thenorm (02-05-2014)
Old 03-31-2014, 03:03 PM   #106 (permalink)
Some more information about these tires on the BMW i3:
More Details on the BMW i3 Bridgestone Ologic Tire Technology | Inside EVs
Old 03-31-2014, 04:39 PM   #107 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Interesting. Actually we get some of the same properties when we inflate our tires to higher pressure - IE lower rolling resistance due to less deformation. A sort of poor mans LLR tires....
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 03-31-2014, 05:44 PM   #108 (permalink)
PSmodder lurker
Someone wants large diameter/narrow tires? Coker Tire - Buy Vintage Tires and Wheels
Old 03-31-2014, 09:53 PM   #109 (permalink)
Dark Egg - '12 VW Touraeg
Here are some 19x4.5" steel wheels in either 5x4.5 and 4.75 or 5x5 and 5.5.
$255 each though.
Hot Rod Steel - 19x4 1/2 Primed
Here is the BMW 19x5 aluminum wheel for $202 but only for strange 5x120mm
aluminum-alloy-19x5-wheel-rim-59378
I beleive the some of the newer Range Rovers use a 19x5ish compact spare wheel but they are also the strange 5x120mm
Old 03-31-2014, 10:08 PM   #110 (permalink)
The gl450 has a 19x4.5 donut spare wheel in 5x112
07 08 09 10 Mercedes GL450 Wheel 164 Type GL320 19x4 1 2 Spare | eBay
