01-19-2016, 03:38 PM
#601 (permalink)
Another reason to get a trailer!
Details:
Behind the commercial:
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
02-08-2016, 04:56 AM
#602 (permalink)
Just for laughs...
Got a bed, booze, a flatscreen (with a remote!) and probably a coffee maker.
What else could a man need? Curtains? Overrated!
Good that the scooter has a large battery... right?
In all honesty this COULD be the perfect solution for someone.
Just nobody I know.
02-08-2016, 09:53 AM
#603 (permalink)
That does not look long enough for an adult bed. Also, unless the television swings out, someone outside would have a better view.
02-08-2016, 10:02 AM
#604 (permalink)
Rat Racer
It's like modern houses. They're designed for checking off as many "feature" boxes as possible, not for usefulness.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
02-17-2016, 09:20 AM
#606 (permalink)
trailering!
Had a 2004 Kia Rio M/T with hitch, sometimes the trailer and load were bigger than the car. It was funny looking but very practical. Never hurt a clutch or axle. It's impressive what you can do with a small car if you don't mind a little abuse.
The Following User Says Thank You to jaysittinback For This Useful Post:
03-27-2016, 03:33 AM
#607 (permalink)
From reddit\imgur:
Ghetto camper - Imgur
So far, nobody knows anything about it, although someone mentioned a neighbor having a similar trailer. Why would you cut off the wagon behind the front seat? I guess the front doors were damaged, and that is still long enough. I slept in the back of my Forester a few times, although I think I needed to move the seats forward. I guess that it makes sense. Okay, say you pick up this salvage SUV: https://erepairables.com/salvage-car...class-15373013
Well, no, maybe not that one. There are probably enough good parts that you could sell individually for a good amount, but still...
How about this one? https://erepairables.com/salvage-car...unner-15338671
Chop off the engine compartment, sell everything that is still good, install a bed, and what would you need to drive that could pull such a heavy trailer?!
03-27-2016, 12:22 PM
#608 (permalink)
Might be to keep the tongue weight down. A truck or large SUV can usually handle 1000+lbs of tongue weight; most car hitches are rated for 100-300lbs. Having the axle in about the middle of what's left of the car would help keep it balanced and keep the tongue weight down.
The Following 2 Users Say Thank You to vskid3 For This Useful Post:
03-27-2016, 05:54 PM
#609 (permalink)
03-27-2016, 10:42 PM
#610 (permalink)
