10-14-2020, 05:51 PM
#111 (permalink)
AKA - Jason
Originally Posted by sgtlethargic
What don't you know with enough confidence?
(I will reply to more, later.)
I wouldn't bother.
I doubt there is anything you can say that wasn't said in the 875 pages of the thread: "The climate change consensus extends beyond climate scientists"
Some people don't believe the climate is changing or that the changes are man made. Zero minds will be changed "discussing" the topic on an internet forum.
10-14-2020, 06:10 PM
#112 (permalink)
To clarify, I don't fit within either of the mentioned categories of though JSH mentioned. Likely I don't fit into any category one would like to see me pigeonholed into.
The position that there is not evidence to suggest what should be done, and that politics prevents us from seeking evidence in good faith does not fit neatly into the climate change denier/climate change catastrophist dichotomies.
10-14-2020, 06:49 PM
#113 (permalink)
The Climate Consensus thread would've run longer if people weren't so invested in 'taking a side'. It's been an amazingly long time since April!
My position was always that from every degree of warming that infrastructure is hardened against, a degree of cooling should be accommodated as well. Since the the only thing we know going forward is that things will change.
.tragectory: Line goes down and to the right.
10-14-2020, 07:09 PM
#114 (permalink)
What does that mean? Not enough evidence of the problems? Not enough evidence of the solutions?
Well, you cut out the 2nd half of the sentence which answers this question.
10-14-2020, 07:57 PM
#115 (permalink)
How about we stop (as much as we can) "adding fuel to the fire"? Meaning, we've added and continue adding energy (trapped heat) to the ecosystem.
I take it you don't know how to do the math to calculate how much heat man generates versus how much heat the sun applies to the earth.
10-14-2020, 08:10 PM
#116 (permalink)
Let's just keep it simple.
There is not [enough?] evidence [of what?]
I'll simplify my position by analogy you might sympathize with. Imagine there are mountains of scientific evidence (studies) showing human activity including fossil fuel burning does not meaningfully alter global climate, and those many studies are funded by OPEC, BP, Shell, and Exon. Should we draw conclusions on what action (or inaction) should take place based on this "scientific" consensus?
As I've stated multiple times now, humanity has greatly benefited from warming as evidenced by every measure of wellness. Where are the studies showing ways in which humanity will benefit from more warming? Name 2 such ways off the top of your head. I can name 4 dozen ways we will be harmed by warming off the top of my head, and there's a political reason for that. When science is approached such that the conclusion is assumed, what good is the science?
It's setting earth as the center of the universe and developing the science to support that conclusion.
10-14-2020, 09:33 PM
#117 (permalink)
What's good at some points in time and conditions is always good at any other time and conditions?
Do we have a way to test the hypothesis at full scale?
I'm not following the first question. My reference to time was a span, not a point in time.
The 2nd hypothesis can be tested by seeking research grants. One proposal could be to study the positive effects of warming, and another could be to study the negative effects of warming. We could then compare which ones more often get funded. Differences in funding would indicate a likely bias.
10-14-2020, 09:37 PM
#118 (permalink)
Why do you think that matters?
Have you read the Climate Consensus at all? What do you surmise the answer would be? Are we there yet?
Rather than badgering redpoint5, try informing yourself. If Suspicious 0bservers [ https://www.youtube.com/user/Suspicious0bservers] is too out-there, go directly to NASA: https://sdo.gsfc.nasa.gov/data/ and https://www.helioviewer.org/. And just to have fun, https://www.windy.com/
You could spend months learning the stuff on you own, or 3 1/2 hours following this playlist https://www.youtube.com/playlist?lis...mAJbadWEpcH6B1
Instead of asking forum members to start from square one with you, [again]... The last science news story in today's space weather report:
attheu.utah.edu: Atmospheric dust levels are rising in the Great Plains
The trend of rising dust parallels expansion of cropland and seasonal crop cycles, suggesting that farming practices are exposing more soil to wind erosion. And if the Great Plains becomes drier, a possibility under climate change scenarios, then all the pieces are in place for a repeat of the Dust Bowl that devastated the Midwest in the 1930s.
“We can’t make changes to the earth surface without some kind of consequence just as we can’t burn fossil fuels without consequences,” says Andy Lambert, lead author of the study and a recent U graduate. “So while the agriculture industry is absolutely important, we need to think more carefully about where and how we plant.”
The story changes every day.
10-14-2020, 10:29 PM
#119 (permalink)
It would appear that warmer is better.
You only need to look back as far as "1,800 and froze to death, a year with out a summer".
If there was ever any question as to if cooler is better.
Go back a little further and it was the midevil cool period for crop failure, famine, pestilence, "the black death", depopulation, ect.
The midevil cool period was probably easy compared to the last iceage.
When it warmed up after the last ice age humanity moved out of caves and formed civilization, cities, ect.
10-14-2020, 11:41 PM
#120 (permalink)
Over any long timeframe, warming is the exception not the rule.
I've made a very simple and very strong case.
No you haven't. C. The consequences of [B]
Therefore from C alone: D. But we look at C. alone:
"C. The consequences of taking that risk are so severe that there is no good argument to continue taking (fueling) that risk."
Fueling the risk is not a unitary choice. There are myriad opportunities, each with their own opportunity costs.
When an option is chosen from alternatives, the opportunity cost is the "cost" incurred by not enjoying the benefit associated with the best alternative choice. The New Oxford American Dictionary defines it as "the loss of potential gain from other alternatives when one alternative is chosen." In simple opportunity cost is the benefit not received as a result of not selecting the next best option.
Top down political fiat, such as the Greed New Deal, fails. A bottom up approach raises all boats, if you will.
The ultimate replacement for fossil fuel, inexhaustable and inexorable, is Moon Power.
