Old 07-20-2012, 04:42 PM   #11 (permalink)
"Wear out the neutral gears"? I'd be inclined to not trust that mechanic anymore.
Atheria (07-20-2012)
Old 07-20-2012, 05:16 PM   #12 (permalink)
EcoPlotting
night9's Avatar
Sliver - '12 Hyundai Elantra limited
90 day: 35.1 mpg (US)
t-ruck - '06 chevy Colorado Lt
90 day: 21.88 mpg (US)
Bob - '09 Harley Sportster Nightster
90 day: 38.88 mpg (US)
Pearl - '14 Toyota Prius C 3
90 day: 48.1 mpg (US)
I think the real concern is not the coasting in neutral (as long as the car is running) but actually putting the car back in gear from nuetral at speed repeatedly that may wear components on the transmision faster. Any thoughts on that?
The Following 2 Users Say Thank You to night9 For This Useful Post:
Atheria (07-20-2012), Cd (07-21-2012)
Old 07-20-2012, 05:21 PM   #13 (permalink)
If it's a gentle re-engagement I'd say it's fine and if there's a clunk, grind, or lurch I'd say it's not.
Old 07-20-2012, 06:00 PM   #14 (permalink)
High Mileage Lover
Sophia - '13 Fiat 500
Send a message via AIM to Atheria Send a message via Yahoo to Atheria
Talking To clunk or not to clunk...that is the question.
Thank you EVERYONE for responding. Since my tranny only has a warranty on it for less than a month, I'm panicking. Brake Masters said there was some metal in my transmission fluid, which IS concerning IF true. I did eventually have them change the fluid during my recent oil change.
Regarding putting the car back into drive after coasting in neutral at 40 mph or whatever, USUALLY I am good at it and know how to "feel" so that I go smoothly back into gear with no clunking. I will admit I clunked it a few times when I was getting used to switching back and forth. But the vast majority of the time I do it perfectly. I noticed the transmission can clunk even if I stay in drive, for example, if I have been coming down a hill to an intersection and have to slow way down to turn and then speed up again. If I hit the gas too hard, sometimes it'll clunk. Gentle is the name of the game...which, of course, also helps gas mileage, which is my goal.
Atheria
I love my cute Fiat 500, Sophia!
Old 07-20-2012, 06:18 PM   #15 (permalink)
SOME metal- depending on what and how much there is- is normal and not automatically a cause for alarm.
Old 07-20-2012, 06:53 PM   #16 (permalink)
In most conventional automatic transmissions the primary pump is driven off of the torque converter. As long as the engine is running you have pressure for lubrication and to activate the bands which clamp down on planetary gear sets for power to the wheels.
Never coast engine off in any conventional AT because you have stopped all lubrication.
I would not even risk it if the owners manual said flat towing was OK. Cars have data recorders that show what you were doing and that would allow the manufacturer a way to deny any warranty claim.
I coast my 2011 Fiesta in neutral regularly, but it is a salvage rebuilt vehicle with no manufacturer's warranty. I have reengaged drive as high as 75 MPH without issues. The transmission control unit apparently detects vehicle speed and picks the appropriate gear when I re-engage drive. It usually goes to 6th (highest) gear then to a lower gear if my speed is below 40 MPH.
My powershift 6 speed is an automated manual transmission, completely different from your Toyota. I have coasted in neutral in my 06 Corolla without issues. I think you should be fine, but then take any advice at it's value, which in my case is.
"I ain't paying for your broken transmission!"
regards
Mech
Old 07-20-2012, 07:58 PM   #17 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I had a totota avalon that I engine on coasted in neutral....alot. never had a problem sold the car at 216,000 miles
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 07-20-2012, 10:39 PM   #18 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
The owners manual will say the car should not be towed with all wheels on the ground because the engine is not running if you do that
The Following User Says Thank You to GRU For This Useful Post:
Old 07-20-2012, 10:43 PM   #19 (permalink)
High Mileage Lover
You've all made me feel better, thank you. Now I am "nervous" though and don't know if I should go back to driving like a "normal person" full-time or what. I drove in gear all day and hated it. I miss my coasting in neutral! In gear, it seemed like the car was always being held back when on a hill. Pfffffffffft.
Atheria
Old 07-21-2012, 12:35 AM   #20 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I am by no way a professional at all, but I have a little experience that may help.
My 89 S10 Blazer, in 2007, had its tranny taken apart by my mechanic, a Jehovas witness. He aaid there were metal shavings, and he wiped them out, and it was fine. From his account, a series of gears constantly rotating is supposed to do that. That sounds like brake masters wants to break your wallet.
In most newer vehicles, no throttle in gear is better han coasting in neutral. I do not know this for FACT in ALL situations, but It was explained to me that the computers now know how to coast in gear, and when we people think we know better and put it in neutral, the tranny and engine are thinking 'oh crap, what's going on' and use more fuel to be ale to adjust faster.
Example: if you are on the highway, 55 mph. In gear, you can coast and use little fuel not accelerating. If you are in neutral, the tranny may be expecting you to suddenly drop to 2nd, 1st, whatever.
But I'm sure it varies. Just DON'T go off of rpm to judge. When I shift into 1st to go down a steep hill at 35, I approach 5000 rpms. But my mpg are not the 3-7 mpg I get when I am at 5000 rpm getting on the highway in first gear lol, rather 45+
my point is, every car is different, and you can only believe half of what you see, and nothing that you hear. I hope you find your answer and some peace
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
Atheria (07-21-2012)
neutral, scion, transmission
