Old 04-26-2008, 03:34 PM   #21 (permalink)
Re the .85, .81 etc.
I have noticed that many car makers seem to be going in two directions: to give cars the "macho" look they tend to make them squarer (when seen from front)--think Hummmer and other SUVs. On other cars (and I suspect they'd be the wider and more luxury oriented cars), they seem to increase the amount of tumblehome.
I noticed that the Prius and Insight did not have much tumblehome, though they weren't perfectly square, either. I did the "reverse calcs" on both and found that .85/.85 calculated out as about right.
--Steve
The Following User Says Thank You to SteveP For This Useful Post:
aerohead (08-06-2016)
Old 04-27-2008, 12:41 PM   #22 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
One Very Questionable Number
The Cd of a Scion xB is 0.32? Pardon me if I don't believe that the brick of bricks has a Cd under 0.45.
The only good thing I can say is that it is a small brick.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 04-27-2008, 06:25 PM   #23 (permalink)
toomuch's Avatar
Unwaking Sleeper - '00 Toyota Corolla LE
90 day: 34.11 mpg (US)
Well, I thought it might be nice to get a good aerodynamic comparison going between different cars and CdA is really the only way to get that. So, this morning I threw some data together on an excel spreadsheet and totaled up some of Toyota's smaller cars on it. I'd like to expand it to other brands (I'm most familiar with Toyota) and I would like you guy's help for that. Here is what I have so far.
You can see I sorted it by CdA. The height and width are in inches and frontal are is in square feet (W * H * .84). The formula used for CdA is Frontal Area * Cd.
CdA List
CdA List.xls
Thanks, I could not find my Frontal Area anywhere. But I guess I could have just figured it out, but I wanted a number from the Manufacturer.
Old 04-28-2008, 08:16 AM   #24 (permalink)
That would be the new xB has the Cd of .32. The older (smaller more boxy) xB is .35. Radiused edges on the front and sides do wonders for aerodynamics.
The Following User Says Thank You to Daox For This Useful Post:
Old 12-13-2008, 08:44 PM   #25 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Toyota Previa 1990
Cd.35
frontal area 34.45 sq.ft. / 3.2 m2
Cx 1.12
width 70.8 in
height 68.7 in
Source: Carfolio.com
That's the Egg.
I think the later ones have a cd of .33 but I can't remember where I read that.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
Old 02-28-2009, 10:04 PM   #26 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
How accurate is this list?
Id read through a lot of it and it seems a little up for contention.
Past Present Future?
Old 02-28-2009, 10:24 PM   #27 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Since the Civic data has not been updated, I thought I'd throw that info out.
Honda Civic HB 1992 - 1995
Cd: 0.36 (according to basjoos's posting)
Frontal Area: 20.76 sq ft (using drawing in Honda Service Manual)
Honda Civic Coupe 1992 - 1995
Cd: 0.31 (according to basjoos's posting)
Not sure about the Honda Civic Sedan numbers
Last edited by NachtRitter; 02-28-2009 at 10:26 PM.. Reason: Aerocivic is the car, basjoos is the owner
The Following User Says Thank You to NachtRitter For This Useful Post:
Old 03-01-2009, 08:50 AM   #28 (permalink)
Hi,
I have an amateur measurement of the Aptera 2e (the current prototype):
The area is taken from a long lens photo, and measured with a polyline tracing the outline in DataCAD: 19.881 sq. ft. The factory Cd is 0.15, so the CdA is 2.98.
Old 03-01-2009, 10:13 AM   #29 (permalink)
your answer:
Originally Posted by Daox
Well, its definitly no Bible. But, its a heck of a lot better than nothing. Most of my info that I wasn't sure about I double checked against multipule sites. That being said I have used info from tons of different sites since I pulled most of the info from google. Frontal area is definitly estimated, so this really is a 'best guess'. No offense, I'm not going to go through and source every piece of info. The numbers will vary, but not by that much. You can see generally where your car sits against the pool of cars on the list. So, when someone comes on the site and says they have a frontal area of 19ft^2 you can know that is pretty small.
So, basically its as good as its probably going to get.
Thanks for the added info NachtRitter and Neil. It will be added.
Old 03-01-2009, 12:59 PM   #30 (permalink)
Grasshopper
Is it possible to make this a sticky or give it its own page
Honestly this was the first thing I searched for and I found it way back on page 17.
Its really usefull methinks.
cda list
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 01:17 AM
What are your 2008 mod goals / wish list? MetroMPG EcoModding Central 45 01-02-2009 01:57 AM
