03-04-2014, 08:24 PM
#11 (permalink)
Live in Ellensburg, teach in Grandview.... about 75 miles away...
03-05-2014, 12:00 AM
#12 (permalink)
Boat tail and rear wheel skirts and you can do that on one gallon of fuel  . Good luck, you definitely have one of the best cars to start with.
The Following User Says Thank You to 2000neon For This Useful Post:
03-05-2014, 12:05 AM
#13 (permalink)
Thanks!!! We'll see about 75-80mpg on my work run. I have three mountain passes that always hurt my numbers. Though I get over 6-7 miles of engine off coasting a day...
03-05-2014, 12:31 PM
#14 (permalink)
Got 50mpg today on the way to work. That's closer to what I get in the Spring, so I think the HAI is helping.
I redid my boattail design. Look better?
The Following 2 Users Say Thank You to gijoe985 For This Useful Post:
03-05-2014, 06:15 PM
#15 (permalink)
how does
Originally Posted by gijoe985
I may take the plunge... I drive 150 miles a day...
How does this blueprint look? I assume good. Before I begin thinking about fabrication (I teach auto shop, so this will be a fun class project) I just want to make sure that my theory is good.
Here is 'Kamm's boat tail.You'll need to weigh out your departure angle so's not to rip her off on a driveway ramp.Just a comparison.
03-05-2014, 06:27 PM
#16 (permalink)
Hydrogen > EV
Although the best gains are from the rear, I believe in starting from the front to back. The better the front is, the better the gains at the rear.
As Metro said, increasing frontal area is better than a dirty belly- but a clean belly is better than that bigger front end.
I just had a brain tsunami, and have to cut this post short- only posting a halfee because I want to subscribe and am interested in following your journey
03-05-2014, 06:44 PM
#17 (permalink)
front
Here are some canopy images to look at.If you compare line 2 with line 3 you see no change in drag in spite of the 'more aerodynamic' nose of the line-3 canopy.Just something to think about.
As to line-1,construct it on paper or computer and see if you could live with it.
PS,it's a 'laminar' shape.something we don't get on real roads.
03-05-2014, 06:59 PM
#18 (permalink)
Right now I am trying ti determine what materials to use for the mock up. I dont have any large cardboard on hand. I could use 1/4 plywood. I could also buy foam. I thought fiberglass in the end would be pretty cool. We've got some lexan on hand for a rear window.
03-05-2014, 07:24 PM
#19 (permalink)
http://ecomodder.com/forum/showthrea...yle-26022.html
The Following 4 Users Say Thank You to redneck For This Useful Post:
03-06-2014, 09:41 AM
#20 (permalink)
I would say so! Phil's illustrations confirm it, but departure angle is a real world consideration, as he points out.
