03-14-2023, 11:37 PM
#71 (permalink)
Originally Posted by Isaac Zachary
One thing to note is that a trunk does keep things safely secured. I knew a lady who was killed by stuff in the back of her station wagon coming up and hitting her in a single car accident.
You seem to have known a variety of people who have died in very unlikely ways.
03-15-2023, 12:06 AM
#72 (permalink)
High Altitude Hybrid
What can I say. Everyone I've known has either died or is going to die.
This was a neighbor's sister. According to my neighbor the accident happened at 25mph on an icy road and it was skiing equipment that was in the back that came up and hit her. I didn't get the rest of the details.
03-15-2023, 03:51 AM
#73 (permalink)
Originally Posted by beatr911
The used full size Chevy vans have not increased at nearly the rate of the smaller vans. Maybe this is an indicator that businesses are concerned about operating costs? Gee, who knew?
Most likely second-hand van buyers in California tend to prefer something more in line with an European taste, so the last all-American van might tend to get a lower resale value. Not to mention being seen as nothing more than a simple workhorse may imply it's more likely to be used for heavier jobs which may cause more wear and tear.
03-15-2023, 11:54 AM
#74 (permalink)
That really too bad...
I've allways thought the 4 cylinder diesel Expresses (Savanas) were awesome! Too bad they don't make them anymore. In fact, the Chevy Express and GMC Savana are slated to be canceled in the upcomming years.
If GM had promoted these vans properly, they probably would have been be quite popular. Dramatically lower cost of operation and huge intervals between refuelings. Full frame for heavy loads and towing. They would of crushed the Turbo v-6 trucks.
However, its like they didn't exist. I'm glad I got one. The amount of money I am saving in fuel costs over the v-8 models is going to buy its replacement in about 12 years....though I may just keep this one going with an engine rebuild. Body is under warranty by Ziebart... so all I need to worry about is mechanical.
The Following User Says Thank You to EcoVan For This Useful Post:
03-15-2023, 03:25 PM
#75 (permalink)
Have you thought of insulation wrapping the exhaust for better longevity? I've heard that diesel exhaust parts like more heat as they have a harder time staying up to proper temperatures.
I miss my 1985 VW diesel. That car is immortal. I'd love to have a diesel again.
03-15-2023, 03:40 PM
#76 (permalink)
I hadn't heard that
but it does make sense. I am so glad that I insulated the whole interior since the engine doesn't put out much heat. However, the insulated interior stays warm at 0F driving with just the fan on low now and A/C in the summer is easy too. Probably has upped the mileage.
The only thing I'd worry about with insulating the exhaust is the regen cycle. The exhaust is supposed to get really hot then.
The 4 banger diesel just makes so much sense in vehicles for this use. Lots cheaper than the 6 cyclinder diesel to make, but all the torque you need.
I guess GM is replacing these vans with an electric. That certainly won't work for us and with the electrical shortages expanding across most of the U. S., I wouldn't want one. I am in Chicago and we are one of the only major cities in the U. S. that is not running out of electricity during extreme winter temperatures, but I bet that time is coming quickly. The efficiency programs are probably going to only go so far to cover the huge increased loads from heat pumps and electric road vehicles.
03-15-2023, 04:09 PM
#77 (permalink)
but it does make sense...
The idea is that it will burn less fuel to get hot enough to regen if it's insulated. It will also stay hot for longer after the regen takes place burning up more of the particulate matter and thus help keep the DPF cleaner. It would also keep the catalytic converter closer to optimal temperatures and help that not get clogged up as diesels have cooler exhaust temperatures than gassers.
Starting at 15:08 on this video:
03-16-2023, 02:02 AM
#78 (permalink)
A hotter exhaust would allow a passive regen to happen more often during longer drives, decreasing the amount of active regens required.
03-17-2023, 01:26 AM
#79 (permalink)
Were these sold in the US? I never knew. At one time I wanted one of those 2.7L I5 diesel Sprinter vans. Something like these may have got me to sell my Toyota pickup many years ago.
This reminds me of the time I totaled my 1975 Corolla. I slid into a rock at least half the size of the car at 45 mph. It crushed the rear corner, bent the frame, sheered one leaf spring in half, almost removed the rear axle. The only injury I suffered was the knot on my head from a can of pineapples in the back seat hitting me.
The Following User Says Thank You to Nissandriver For This Useful Post:
03-19-2023, 04:16 AM
#80 (permalink)
Yes, but the engine was sourced from that factory in Thailand which GM sold to the Chinese GWM. Odd enough, the very same engine is still being made in Brazil.
I remember seeing just one US-spec Sprinter in my hometown, turned into a campervan and driven by a redneck girl who was travelling through South America.
