Old 04-12-2013, 02:12 AM   #191 (permalink)
Smokingwheels - '84 Nissan Bluebird wagon LX
90 day: 35.99 mpg (US)
Red Z - '79 Nissan 280 ZX
Blue Ford - '95 Ford Falcon GLI
90 day: 18.18 mpg (US)
Send a message via MSN to Smokingwheels Send a message via Yahoo to Smokingwheels
Well what about a cruise control that you can set a speed range to slow down to up hills.
eg 20 km/h below the setpoint when throttle goes past a certain percentage.
The Following User Says Thank You to Smokingwheels For This Useful Post:
Bruce_3 (06-22-2014)
Old 04-12-2013, 05:56 PM   #192 (permalink)
The Blue Bomber - '95 Geo Metro
90 day: 52.09 mpg (US)
I found that with my Metro & an aftermarket universal Rostra electric cruise control, if I set the PPM to 8000 instead of 4000, the cruise pretty much pulses & glides on its own based on elevation changes. If I set the cruise at 60 MPH, my speed will fluctuate between 53 MPH-68 MPH. It automatically slows down going up hills & speeds up going down hill. On flat ground it pretty much stays at 60 MPH.
Old 04-12-2013, 10:23 PM   #193 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Old 06-20-2014, 07:26 PM   #194 (permalink)
First, I understand that this thread has been dead for a year, but in case someone else is looking for the same thing I was I'll add my thoughts here.
I like the ideas, and was searching for a 'Smarter' cruise control. After reading here, I decided my stock cruise module should do the job with a Arduino intercepting the incoming speed signal, and outputting a new speed signal to the cruise module. I made the circuit board today, and did some testing. I think some of the speed constants I'm using might need adjusted, but overall I am getting the result I wanted.
I want the cruise to react slower to changes, and allow the speed to drop (but still controlling the speed within reason, after all that is the idea of cruise.) I have some pictures, a schematic, and the program. Once I figure out how to add it here I'll include more information. But I do appreciate all the thought and ideas here that led me to this.
--Bruce
The Following 4 Users Say Thank You to Bruce_3 For This Useful Post:
California98Civic (06-21-2014), Cobb (06-20-2014), radiantthought (06-20-2014), t vago (06-29-2014)
Old 06-20-2014, 09:05 PM   #195 (permalink)
More Information...
I should mention that my truck is a 2000 Chevy Silverado 5.3L with the stock cruise module. I tested the speed signal to the cruise, and it was a 12V square wave that was approximately 1 cycle per MPH.
The only wire cut is the speed wire from the PCM to the cruise module. I also tapped into the 'Set/Decel' , 'Resume/Accel', 'Cancel', and cruise power wires.
ID:	15221   Click image for larger version
ID:	15222   Click image for larger version
ID:	15223   Click image for larger version
ID:	15224   Click image for larger version
The Following User Says Thank You to Bruce_3 For This Useful Post:
Old 06-20-2014, 09:17 PM   #196 (permalink)
Arduino Code
The Arduino Code, still needs cleaned up some.
Any improvements are welcome.
--Bruce
Code Updated slightly.
The Following 2 Users Say Thank You to Bruce_3 For This Useful Post:
California98Civic (06-21-2014), radiantthought (06-20-2014)
Old 06-20-2014, 09:37 PM   #197 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Cruise control with Arduino intelligence
--Bruce
Very good idea, to use Arduino to modify the standard logic of the Factory cruise control, or even an aftermarket one.
Go ahead and many will appreciate your findings.
Oldbeaver
Mercedes 300 D turbo 1993
Old 06-20-2014, 10:34 PM   #198 (permalink)
Very cool! My wife and I had the privilege to borrow the all new, not in full production yet, 2015 ATS Coupe. It had Adaptive Cruise Control. There were 4 sensors embedded into the front bumper that would "see" vehicles in front of the car and based on a setting of "Far, Medium, or Near", the cruise control would automatically slow the car down as you got within range of a car in front of you. It would make "drafting" extremely easy! lol I drove 2 hours on the highway & never once touched the breaks or adjust the cruise control. It was pretty awesome.
Old 06-20-2014, 11:16 PM   #199 (permalink)
Oldbeaver
Thanks, I realize that it is not actually a MPG sensitive cruise, but I am hoping the end result is similar. Also this keeps cost down since I did not need to replace my cruise module. I need to fine tune the values to work best in my truck (SPEEDDROP, MAXDROP, and SPEED_MULTIPLIER). But my three test runs today had the cruise working smooth without harsh downshifting.
--Bruce
Old 06-20-2014, 11:22 PM   #200 (permalink)
I've driven a Toyota that has that option, and it is very nice.
--Bruce
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
3 ?'s (SuperMID; cruise control for Metro) Pillzilla EcoModding Central 16 03-31-2008 06:34 AM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
TP control? Harpo EcoModding Central 9 03-14-2008 06:54 PM
