Old 07-13-2013, 12:12 AM   #11 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
My boxy & short-geared xB is only good for 41 mpg @ 60 mph, & 49 mpg @ 50 mph. I've managed 60 @ 60 with a Prius, but I can't even get close with the xB. I have to P&G to top 50 mpg with my xB on highway trips. Those of you who aren't aerodynamically challenged are very fortunate.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 07-13-2013, 03:14 AM   #12 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Awesome! I haven't been active in this forum for a year. Now that I'm back and catching up with threads , your car has come a long way since you joined 2 years ago!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 07-13-2013, 04:38 AM   #13 (permalink)
Nice results!
Old 07-13-2013, 09:47 AM   #14 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Very nice work and I enjoy all your write ups!
Old 07-14-2013, 08:24 PM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Another test
Had to do a 27 mile drive today so I did a different test. Could I maintain a 60mph average while keeping a 60+ mpg average without engine off coasting? In the previous test I had used light EOC and got as high as a 66.7 mpg as a one-leg average of my test route. Forn this test, I allowed myself only engine on pulse and glide (55-65mph) and reasonable drafting whenever possible. I only got an opportunity to draft for a couple miles, and I followed the 2 second distance rule. The terrain was hilly. There was a fairly significant crosswind. The results:
aerohead (07-20-2013)
Old 07-15-2013, 01:09 AM   #16 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
You averaged 59.8mph... Epic fail. Just kidding. Great job!
Old 07-17-2013, 04:40 PM   #17 (permalink)
Blue Angel's Avatar
Previous Car - '12 Chevrolet Cruze Eco MT
Team Chevy
90 day: 44.29 mpg (US)
535d XDrive - '16 BMW 535d M-Sport
Doing two way average runs over flat ground with the cruise set at 62 this weekend, I got an average of 53.8 from the on board computer corrected at -7%.
To achieve 60@60 I'll need some significant aero mods... The car is pretty much stock right now, except lowering springs and higher tire pressure. I'll be checking out your mod thread for ideas, but I won't be disconnecting the alternator!
2016 BMW 535d
4100lb XDrive Eco-Yacht
The Following User Says Thank You to Blue Angel For This Useful Post:
Old 07-17-2013, 06:44 PM   #18 (permalink)
what gauge are you using? I had a scangauge 2, but it was never accurate in actual MPG numbers...
Old 07-17-2013, 08:05 PM   #19 (permalink)
Cyborg ECU
I use the Ultra Gauge. I think it is the slightly older one. Mine displays 6 readouts at a time. Newer ones display 8, I think. But whatever gauge you are using, you need to calibrate the distance and the fuel usage measurements. Still, guys with experience here will tell you that only the MPGuino is really accurate as to fuel use because it monitors the injectors directly (using voltage signals, I think).
Good luck with the aeromods! You have a modding thread?
Old 07-17-2013, 10:29 PM   #20 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Originally Posted by basjoos View Post
70@70 below 1000 ft elevation and 75@75 above 2000 ft elevation in the aerocivic. The mileage improves with altitude.
How recently, basjoos? I went to your fuel log & it looks like your last entry was 2 years ago. ???? Did the aerocivic break down, or?
