11-02-2011, 07:42 PM
CRX HF EcoTurbo?
Well gentlemen.
Is it worth it to turbocharge a 1990 Honda CRX HF for increased economy?
I read an article in SuperStreet a loonngg time ago, in which a turbo Honda S2000's fuel economy jumped to 38 mpg. All because it took him less time and throttle to achieve highway speed.
I was thinking maybe a Mitsu 13G with an adapter plate to the HF manifold, plumbed straight into the throttlebody with no intercooler. Boost pressure would be low, only 5 psi or so. I would like to retain the factory 240cc injectors.
My biggest concern is tuning with OBD-0.
11-02-2011, 08:50 PM
Cyborg ECU
Originally Posted by office888
Well gentlemen.
Do you know if it will deliver the power in the low end? That's the key, from what I have read. For the best FE results you will want more power on the lower end of the RPM band and you will want as little delay as possible. This unit offers that?
11-02-2011, 09:56 PM
Doesn't the CRX HF have pretty high compression ratio already and with a turbo you want to have lower compression on your engine so the increased pressure doesn't cause pre-detonation.
11-03-2011, 12:19 PM
The TD04-13G is fairly small. I can't say for certain due to variables, but full spool at 5 psi would probably be around 2700 rpm. I spend most of my driving in the 1800 to 3500 range. The extra power would be nice for getting onto the highway.
The GT15 would probably be a little more efficient for my needs, and spool a little faster... However, that would increase the price by quite a bit.
9.1:1, so not terribly high. There's a lot of guys running 15 psi+ with much bigger turbochargers with that compression.
11-03-2011, 01:19 PM
The short answer is no.
11-03-2011, 02:12 PM
Cyborg ECU
I know Daox is right about the financial cost of the turbo charger. It wouldn't pay for itself for a prohibitively long time, if ever. I just looked up the prices on these units. Not any cheaper than others I have causally researched. $2K - $3K is a lot to pay for a little more FE. Your earlier response raises questions too. You say you normally drive in the 1800-3500 RPM range. An HF has taller final drive gearing than the VX and so you might be driving at some high speeds to make 3500 rpms on the freeway. Not all that great for FE. Still, I don't think anyone would dispute that there would be some gains, with modest driving technique changes, and that you would also have access to the power you seem to want. If costs are not part of how you value the mod, go to it. And please post a build thread with testing of results. I know I'd like to read it.
11-03-2011, 02:32 PM
A guy on d-series.org boosted his civic for the sole purpose of better FE. He tuned it so that his engine would be in neutral vacuum as much as possible to increase pumping efficiency . He also re-calibrated the fuel maps in his ecu to run in lean burn mode. I forget how many MPG's he was getting but is was up there. I'll try looking him up and post a link if I find it.
The Following User Says Thank You to pana For This Useful Post:
11-03-2011, 06:28 PM
Cyborg ECU
I found this on that site: I did some FE testing 64.8mpg - D-series.org. Is that the one? If so, he seems to have a turbo for power but relies on lean burn for higher FE on freeway trips. His average FE, tank to tank, would be interesting to know.
11-03-2011, 08:47 PM
#9 (permalink)
I would be surprised if just adding a turbo helped FE in any way.
Using a turbo to bring a car back to "acceptable" performance when something else has been done (e.g., lean-burn, downsizing the motor, etc.) is a well-trodden path to FE. Just ask anyone with a Cruise Eco.
It might be fun to run a 1st-gen Insight 3-cylinder with a turbo in a CRX.
-soD
11-03-2011, 09:57 PM
#10 (permalink)
Gasoline engines don't see much of a FE boost when turbo charged.
If you be good and drive them easy you can milk a few more MPGs out of your vehicle but the mod wont pay for its self.
It would be nice to have more power and MPGs, in that way it could be worth it.
I wouldn't try going non-intercooled.
