Old 03-30-2009, 05:10 PM   #11 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I am very interested in how it works.
Nissan Versa Aeromods
Old 03-31-2009, 12:57 PM   #12 (permalink)
Daily Driver - '01 Ford Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
Sweet! never even knew this kind of thing existed. i used to use a tractor throttle on my old truck, but it was to bump my idle up for different reasons.
i'm going to look into this for the old truck when i get it running again, but i will hook it straight to the linkage at the carb.
My Intro
Old 11-11-2009, 09:43 PM   #13 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I am interested in doing something like this, can you explain how you did the chain (I can not see it in the pic)?
Old 11-11-2009, 10:21 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I found two small cable clamps at the ace hardware.
I installed the cable so it pretty much pointed at the part of the gas pedal lever I wanted to pull on (the straighter the path, the better).
then figured out how long to make the chain by holding it up to the gap
then used the clamps to attach it to the pedal rod on one side of the chain and to the cable end on the other.
I could slide it a little bit on the cable end to fine tune it by loosening the clamp and repositioning it.
The key here is that the gas pedal actually pulls on the throttle cable via a lever, so I am clamped to that lever near where it connects to the throttle cable.
The chain just attaches to a clamp bolt at the ends, the pedal clamp goes around the pedal lever, the cable clamp goes around the cable. I think I may have flattened and even spot welded the chain ends to be captured by a clamp bolt, but not a requirement I'm sure.
Old 11-11-2009, 11:17 PM   #15 (permalink)
Gen II Prianista
Rokeby's Avatar
Another way to do this:
Jeep Rubicon Express Hand Throttle Installation
The hand throttle kit goes for ~$30:
RE1000 - HAND THROTTLE - Rubicon Express
Parts might be cheaper at your local bike shop.
Old 11-11-2009, 11:21 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
the one I installed had vernier control, so that ideally you could fine tune the throttle setting with ease by twisting the knob or make gross adjustments by holding the button in and moving it in our out.
I had a bit of fudge in my install though, so it took some finagling to make fine adjustments.
Old 11-12-2009, 07:21 AM   #17 (permalink)
Wiki Mod
this looks very doable. I have had a hard time figuring how to do mine as it is an electronic throttle.
Did this help you?
Old 11-12-2009, 07:29 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
Didn't really test it out, mostly an in-town driver and P&G everywhere. Was nice to have on the hiway though the few times I was on the hiway
Old 11-12-2009, 07:34 AM   #19 (permalink)
Wiki Mod
would it be possible for you to take another pic of how the chain is set up?
Old 11-12-2009, 07:55 AM   #20 (permalink)
dcb
needs more cowbell
dcb's Avatar
Nope, it has moved on, wasn't very tricky, look at last pic closely.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Throttle locking the cruise control? Xringer EcoModding Central 6 12-26-2008 10:29 AM
Reprogramming cruise control. TKWPrime EcoModding Central 7 09-22-2008 04:49 PM
Cruise control mod idea rjacob DIY / How-to 18 07-29-2008 11:27 PM
