Old 12-01-2009, 08:11 PM   #201 (permalink)
apowers's Avatar
My charger is bolted to the vehical and I have a ground fault breaker to interupt
the power, just in case. It has worked a time or two when the acid made a short
to the frame. I have since isolated the batteries better.
Alvin
Old 12-03-2009, 12:16 PM   #202 (permalink)
Originally Posted by jackbauer View Post
I'm not sure about the whole isolation issue. My thinking is that the car body should be connected to mains earth while charging.
I agree.
...unless designed around an almost impossible to source custom hf transformer.
But don't you need a custom transformer either way? I'm just asking, I hardly know anything about the transformer market. But I'm quite sure that HF transformer at least should be much cheaper to manufacture.
Old 12-04-2009, 05:12 AM   #203 (permalink)
hy all
from my findings
we can use an lm723 as current and voltage monitor to shut down the chagring
also tha 555 and fet design seems to be cheap and reliable
if you are interested i am triing to desing it
also here are some guidelines http://www.smps.us/Unitrode.html
Old 12-16-2009, 12:25 PM   #204 (permalink)
jackbauer's Avatar
Just for anyone interested i'm working on a design from diyelectricar :
Old 12-17-2009, 04:15 PM   #205 (permalink)
jackbauer's Avatar
I came upon an old 80's era 40amp 3 phase inverter plasma cutter today with a dead control board. its a charger in a kit! Input rectifier complete with precharge and bleed resistors , Massive fan cooled heatsinks , a huge ferrite core transformer with primary inductance of about 3.6mh , output rectifier rated at 400v 60amps fast recovery and a big honkin' output choke! Interestingly the transformer seems to be a 1:1 ratio which has me thinking about building it up as a forward converter with RCD reset. This would give an isolated output
Thoughts? , comments? , ideas? am i insane?
ID:	5032   Click image for larger version
Old 12-17-2009, 04:19 PM   #206 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
no comment on sanity But if I didn't already have a plasma cutter (I don't) I would be very tempted to try to fix/rig the control board as a plasma cutter can be nice to have indeed.
Old 12-17-2009, 04:24 PM   #207 (permalink)
jackbauer's Avatar
Just build this:
but be careful its non isolated. I used a few electric cooker rings as a ballast.
Old 12-17-2009, 04:44 PM   #208 (permalink)
EVVette - '71 Chevy Corvette Coupe
Jack,
That looks like a great power stage for a charger. The isolation transformer is a great thing to have. With that for the power stage, you will have about an 8KW charger!! And, Thats figuring at 200V output!
You might need to add some caps to the bank to further smooth the ripple. It was meant to cut, not charge batteries. lol.
I cant wait to see what you come up with!.
-Adam
P.S. You are insane!
P.P.S I havnt forgotten about you with RTD Explorer...Its coming...
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 12-17-2009, 06:26 PM   #209 (permalink)
PaulH
MPaulHolmes's Avatar
I also would like to say that jack is insane.
Also, with a 3.2mH inductor, if those 2 big capacitors are the input filter caps, then you really only need a very small cap bank that goes with the 3.2mH inductor to complete the low pass filter. Like 300uF or something. For a buck converter, the ripple will be just a few volts. You could add a current sensor, and PI loop in software that will make the ripple more like 0.1v, but that's not necessary. This is awesome!
kits and boards
Old 12-17-2009, 06:26 PM   #210 (permalink)
Out of my mind, back in 5
Originally Posted by adamj12b View Post
Jack,
-Adam
Who ever said insanity was a bad thing?! We'd never get any cool stuff done...
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 10:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 12:23 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 04:10 AM
