Old 08-17-2015, 05:44 PM   #1 (permalink)
Dramatic drag comparison
The following is an anatomical drag comparison between a circular cylinder section and a NACA laminar wing section.
The two bodies are shown in true size relationship to one another.
The laminar wing section is 167-X longer than the cylinder.
They have identical drag.
(we don't need no stinkin' streamlining)
PS, the table is from 'Boundary Layer Theory,' by Hermann Schlicting,7th-Edition
The Following 14 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (08-18-2015), California98Civic (08-18-2015), darcane (08-17-2015), Ecky (08-19-2015), elhigh (08-18-2015), JRMichler (08-18-2015), oldtamiyaphile (08-18-2015), P-hack (08-20-2015), RedDevil (08-20-2015), sendler (08-19-2015), The donkey CRX (08-18-2015), UFO (08-18-2015), user removed (08-18-2015), wdb (08-18-2015)
Old 08-17-2015, 06:39 PM   #2 (permalink)
darcane's Avatar
Last two digits for NACA airfoil designations indicate maximum thickness as a percentage of chord.
21% of 167 is 35.1.
So this NACA airfoil has the same drag as the cylinder in spite of having a 35 times larger frontal area.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
aerohead (08-19-2015)
Old 08-17-2015, 07:36 PM   #3 (permalink)
Change that circle to a square and see how much smaller it'd have to be.
Either way, good lesson.
Old 08-17-2015, 11:08 PM   #4 (permalink)
Just need to quote this next time the "Can I increase frontal area AND reduce drag?" question comes up.
Old 08-18-2015, 08:17 AM   #5 (permalink)
Now I understand, thanks aerohead. CD and frontal area much more dependent on cd, especially when it gets low enough.
regards
mech
Old 08-18-2015, 11:52 AM   #6 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Clarify for me, by "drag" do we mean CdA and not just Cd? The airfoil has identical CdA? Seems increadible. That's not the case right? This is just identical Cd, yes?
Old 08-18-2015, 12:15 PM   #7 (permalink)
darcane's Avatar
Drag is the force pushing back on the body as it moves through a fluid. it is directly proportional to CdA as long as fluid density and velocity are held constant.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following 2 Users Say Thank You to darcane For This Useful Post:
aerohead (08-19-2015), user removed (08-18-2015)
Old 08-18-2015, 12:24 PM   #8 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Exactly! My travel trailer build will have a much lower CDa because of this. More can be less, much less
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 08-18-2015, 01:04 PM   #9 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
That's stunning.
I remember seeing add-on fairings to make the cables on one's ultralight aircraft less of a drag, but they didn't significantly increase the frontal area, they weren't much more than stiff tapes to add to the cable.
This shows that one could replace the cables with, for instance, spars and still have no net gain while picking up lots of strength.
The Following User Says Thank You to elhigh For This Useful Post:
Fat Charlie (08-24-2015)
Old 08-18-2015, 02:22 PM   #10 (permalink)
A little reality check on the math though....
35 times the frontal area? That means it has 1/35 the drag coefficient, right?
1/35 = .029
IF the coefficient for the round shape was 1 (it must be less, but follow along), the coefficient for the airfoil is .029? Seems too low, even for a section of a chord? Someone has some numbers, right?
