Old 04-14-2018, 04:43 PM   #21 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Not bad!
I may be experimenting with temporary duct tape wheel covers until I get my timing belt replaced next week...we'll see if the weather dries up here first though.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 04-14-2018, 05:01 PM   #22 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Hey, I am experimenting with foil tape, weed barrier, and plastidip for this exact purpose right now. Over several posts in my build thread you can see my idea and progress. Build thread is in my signature below. I would love feedback/questions. Don't think I should just duplicate and repost here, so here is just one photo.
mpg_numbers_guy (04-14-2018)
Old 04-14-2018, 06:08 PM   #23 (permalink)
How about something like this: http://ecomodder.com/forum/showthrea...orn-14306.html
I did not like the idea of pizza pans, so I went with pizza separators, but I wanted to try the attachment method someone else on here promoted. Unfortunately, it did not work well for me.
Do I want to reuse the separators with superfluous holes?
Old 04-19-2018, 01:36 PM   #24 (permalink)
Team Mazda
Looks like too much work lol.
How about using 1/2" thick (can be shaved down at the edges insulation foam board? https://www.homedepot.com/p/Owens-Co...-36L/100320356
Pros: cheaper than coroplast and possibly more durable than duct tape covered cardboard?
Old 04-19-2018, 03:27 PM   #25 (permalink)
You could find coupling nuts that fit your lugs and then you would not need to drill them, but I cannot find any that fit my Hondas.
You could also put fiberglass and resin on cardboard.
Old 04-19-2018, 04:45 PM   #26 (permalink)
You could just pay more for gas. But is that the point?
Old 04-19-2018, 09:20 PM   #27 (permalink)
Team Mazda
Lol, I had the same issue when I searched for those, couldn't find them.
That expensive idea rather defeats the purpose of ecomods for saving money..
Why would we want to do that?
But it still doesn't answer my question!
Old 04-19-2018, 11:07 PM   #28 (permalink)
That's been done before!
Someone with their own tools could make their own from a single piece of steel. That would impress me.
Not all modifications need to look like the gorilla tape on the front of my Accord. Some look nice, but why don't you go ahead and strap foamboard to your wheels and report back in week. Tell you what, I will even buy you the foam so you can show us how well that works.
Old 04-20-2018, 01:36 AM   #29 (permalink)
Which one? Caulk? Foam board?
Have you laid a straight edge on that wheel to see if it is convex or concave overall?
Four holes for the lugs will lead to stress risers and failure. One hole can't eat away at itself. And if the wheel is convex, then a fairly large hole will center on the wheel.
Instead of caulk, wrap the edge with tape. Cut the circle by pinning the center and rotating the sheet material against a tool.
Old 04-21-2018, 09:27 AM   #30 (permalink)
Team Mazda
I just might, if I can find some thin enough. Right now I'll be experimenting with cardboard first. My timing belt is being changed right now and should be done in a couple of hours. Then it's time to go home and make 3 more cardboard discs for testing (I made one last night)
Foam board, sorry. Not sure if it's durable enough or if there are other concerns since I haven't seen many others use it and yet it seems like an even cheaper alternative to coroplast.
The wheels are slightly concave, but mostly flat, which makes them nice for mounting.
Wait, are you saying having 4 lugs is bad? Or something else? Sorry.
Good idea with the tape, kinda what I was planning doing with my cardboard prototypes, I just don't know if the tape will survive the weather.
For the discs I used a tape measure to measure out the diameter with the center laid against a penciled in point, then rotated the tape measure and added dots. I then connected the dots to something that was probably a "60-gon" so when I cut it, it was basically a circle.
