Old 12-19-2009, 12:24 AM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Efficient Engine Design ???
As some of you know I built my entire engine around fuel efficiency and performance. When I started this project over ten years ago I made a list of major factors that would aid in the engines efficiency.
Here's my list in the order of importance.
1) Low numerical "Throttled BSFC" numbers.
2) Lean Burn Technology.
3) Fast-Burn Head design.
4) Reduced Pumping Loss Engine design.
5) High Fuel Atomization.
6) Programmable EGR system.
7) Advanced PCV system.
My list of modifications to reach these goals.
My goal was to be able to reach a BSFC number of
.25 or better (.25 BSFC is based in lbs) at part throttle. At one point I had the idea to decrease the engine size to under a liter and use a smaller engine and run at a higher load with a better BSFC number to help with FE. But then after talking to Ben Strader of EFI University and a few others, I decided against it.
I understand that car manufacturers base their engines BSFC at high load or part load. This will give them a better BSFC number, but it doesn't tell the whole story as far as the consumer driving down the freeway at light load.
IMO very light load freeway driving is by far the most used by the consumer.
One other thing I would like to address on this subject is I see a lot on this forum and other forums that ones thoughts are you will achieve your optimum BSFC at heavy load. So we feel like we need to run the engine at a higher load to get a better BSFC number.
I agree to some extent , but keep in mind all EFI systems have accelerator pump values that are read off the TPS. The accelerator part of the EFI program does what carburetors did with their accelerator pumps in their day. It adds fuel based on the speed of the throttle plate being opened to prevent a lean back fire. Usually the EFI throttle pump system will have three RPM opening points with a decay setting on all three. It will also have a coolant base adjustment built into it. All three will add to fuel injector opening time base on %.
So back to my point if you are trying to to get to the ultimate BSFC number with high load your also dumping more fuel in through the throttle pump part of the program. Something that is not included in the posted BSFC charts of different engines.
Now lets look at the BSFC WOT and or high load part of an engine. All engines have to rely on the fuel for thermal management. Incoming fuel is one of the largest factors for cooling down the combustion temperature that takes place durning the intake cycle. So at high load or WOT the engine is wasting a lot of fuel just for cooling purposes only. This kills BSFC numbers. Plus at high load you burn more fuel due to a higher VE. So more fuel results in more heat, more heat means more fuel that's needed to cool combustion temps.
One other factor is at a high load the air velocity is much slower. Slower velocity means less atomization of the fuel. So now more fuel is needed to make up for poor atomization due to lean spots and overly rich spots in the combustion chamber.
So as you can see I was left with a problem when I wanted to introduce my next modification "Lean Burn" There was no way i could run 20:1 + A/F at high load and keep the engine from detonation. So I had no choice then to concentrate on light load great BSFC design.
So that brings us to...
Lean Burn Technology goes hand in hand with great BSFC numbers. My thoughts were to use as little fuel possible to produce 20whp. To do this I would need a BSFC number around .25 so lean burn was my only option.
I came up with a prechamber design that would be able to ignite and start combustion with A/F ratios in the stock combustion area around 25:1 to 30:1.
At these A/F ratios the heat is reduced (good) and flame speed slows down drastically (bad). Plus NOx levels increase(bad). One thing I found out is at very lean conditions atomization improves a ton.
But back to heat. I noticed in my data logs that my water temps drop when it goes into lean burn. This was a relief because the higher A/F ratio requires a slight higher load. This is also where the turbo comes into play. With a higher load with an turbo engine makes more boost and reduces pumping losses.(good)
But now the bad, flame speed decrease and now I have to start the ignition timing sooner.
My Honda multi-valve pent-roof design has a fairly fast burn rate when it comes to head design. This helps with increasing flame speed so less ignition timing is required.
My main contributor to helping with pumping loss is the turbo.
Plain and simple it creates a higher then ambient pressure so as the piston cycles downward its being aided by pressure acting on it durning the intake stroke. But what about the compression stroke? High compression engines will take more energy then lower compression engines when it comes to the compression stroke.
My engine is around 7.5:1. You can turn it over to where it feels like there isn't any spark plugs in it. So at very light load it would turn very easily.
One other thing I think that is happening is there are some left over exhaust gases that will aid in NOx from a very low compression engine.
All I have done here is I'm running a higher then normal fuel rail pressure 60psi. to help aid fuel atomization.
These two items are what I'm working on now.
The programmable EGR system will be where I can control how much I want to recirculate.
The advance PCV system will have an electric evac system to reduce crankcase pressure down to almost a vacuum.
This will help with sealing the lose ring pack and reduce pressure in the crank case that will help when the pistons are cycling downward.
Well this is my own home brew engine design and so far it has been successful. I have gone against the grain on a few other ideas. But sometimes thinking outside the box is necessary no matter what the out come good or bad.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
BabyDiesel (05-11-2015)
Old 12-19-2009, 12:55 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Well, you're getting 66 MPG from a Semi-Sports car, so I guess I'll subscribe.
The Following User Says Thank You to Christ For This Useful Post:
pgfpro (12-19-2009)
Old 12-19-2009, 01:18 AM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
well, he did start getting those numbers AFTER hanging out here for a while
Was looking at similiar hondas, looks like palemalasian shoud get a mention
though, I'm not sure I buy that lean burn = "great bsfc", it detunes the engine, but the engine is still moving more air than necessary for the job of maintaining a constant speed.
nor do I quite buy that accelerating dramatically changes the topography of the bsfc map, and not just the numbers on the lines.
A smaller engine is indeed the correct answer for most efficient cruising, but I would never expect someone who puts as much emphasis on power as Ben Strader to ever recommend such action
"Typically racers, younger tuners, students, mechanics, and general performance enthusiasts will enjoy the benefits of attending an EFI 101 Class. "
The Following User Says Thank You to dcb For This Useful Post:
PaleMelanesian (12-23-2009)
Old 12-19-2009, 12:10 PM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I do agree that your best BSFC numbers will be at higher load. I need to be a better writer.
What I'm trying to say is its not practical nor safe for an engine that's not DI and a "purposely built high load new design engine" to be run at these high loads due to major heat issues from high load. I can't afford one of these new cars with this technology, so I have to use what I have, 16 year old technology So I choose a design that anyone could drive and get the same results(normal driving). It takes more of the driver out of the equation.
I would love to test a 1.0L of the same engine design as what I have and see what the increase in FE or decrease would be. I think the difference would next to none. The internal rotating mass and the pumping loss would be very minimal. So the question would be... how small would you have to make the engine to see major gains?
Old 12-19-2009, 12:18 PM   #5 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Subscribed. I want to see where this one goes. PFG, could you post some pics if you have them of your designs and builds? Can we find them elsewhere? Do you use a Megasquirt ECU for your design?
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-19-2009, 12:52 PM   #6 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I can't show pictures of my prechamber yet. Its not that I'm trying to market this design. Its that there is something similar out there that has a patent and its got me worried that I might step on his toes.
I will also be testing my design on a stock Honda 1.6L D16Z6 this summer.
I think it won't give the same results due to the stock piston design and the quench area is not the same. I'm running Suzuki Vitara piston that are modified in my honda engine with a after market Eagle rods that help with my lean burn.
I'm running a Honda P28 ECU with Neptune RTP engine management and also a PLX wideband with gauge and a Innovate LMA-1, LMA-3, W/B system.
Old 12-19-2009, 01:18 PM   #7 (permalink)
Nifty project. Keep us updated.
Couple questions.
How do the Eagle rods help with the lean burn?
The only thing I can think of is that, they will either be more resistant to damage from knock, or you have rods that are longer or shorter than stock rods to monkey with the compression ratio. Or something completely different...?
All other things being equal, higher compression ratio will improve overall Carnot efficiency. Look at diesels, 18:1 up to 20+ :1
Of course, all other things are not equal. We prefer that our engines not destroy themselves in short order. High combustion temperatures are good for efficiency, but bad for NOx. You win some, you lose some.
You only have to optimize about a dozen variables here to hit a home run, most of which negatively affect each other. You have chosen an impressive project with ambitious goals.
May the force be with you.
Please carry on.
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 12-19-2009, 01:54 PM   #8 (permalink)
pgfpro -
AH! You're running Vitaras! Have you considered the Supra pistons for a turbo app? Coupled with B16 (I believe) rods, you get about 8:1 comp with a nice squish pattern, IIRC, and pistons that were designed to be optimized in a turbo environment with high combustion pressures.
Old 12-19-2009, 03:31 PM   #9 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Couple questions.
Please carry on.
troy
The eagle rods with the Vitara pistons run the piston lower in the bore. I need this to direct the collected fuel in the intake valve relief pockets to the bore center.
Plus when I run 30psi around 450whp I need the extra rod strength
Old 12-19-2009, 03:33 PM   #10 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by Christ View Post
pgfpro -
I didn't know about them???
I went with the Vitaras because they have been proven up to 580whp. I like the shape of them and the cost is great $99.00 a set
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 03:44 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Video: Armory Lovins, Rocky Mountain Institute - promoting design of efficient cars Smoky Aerodynamics 6 05-10-2008 04:06 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
