Old 05-18-2009, 09:03 AM   #11 (permalink)
Ziggy - '95 Audi S6 Sedan
Manfred - '97 Audi A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 Audi A4 Quattro Avant
Sherman - '98 Audi A6 Quattro Avant
Cab - '96 Audi Cabriolet
Verrry impressive...
Have you zeroed in on uSec/gal yet? I'm within 0.5% per tank and still trying to get closer.
I'm currently working over the code to add more menu items. Adding a menu pick to allow directly entering the fill gallons and let the Guino calculate and save the uSec/gal. Also adding a menu pick to enter the distance actually travelled and calculate/save the VSS pulses. Strictly for convenience so you don't have to run through all setup screens every time you make a change.
Old 05-18-2009, 10:34 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Nice yetimus
Old 05-19-2009, 12:31 PM   #13 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Very cool on the Passat guino. Makes me wonder what other displays will work.
Winter daily driver, parked most days right now
Summer daily driver
Old 05-21-2009, 11:58 PM   #14 (permalink)
Thanks all for your kind feedback! rmccomiskie - I haven't made much progress zeroing in on uSec/gal - still ~ 2%. Lots of tinkering with the display, relatively few miles driven (i.e. bike commuting), and infrequent fill-ups on the VW (20+ gallon capacity and 40+mpg) make calibration rather time-consuming. I'll be interested to hear about your code hacks - sounds really interesting!
wagonman - any display that is HD44780 or KS0066 compatible will work AFAIK- link.
I'm still looking at some other displays that will provide a more readable big-number display as well as better backlighting. I'll post back if/when I come up with an upgrade....or... make it mo' gangsta (thanks leanburn!)
dcb - thanks for making this project possible!
Old 05-25-2009, 02:51 PM   #15 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
Old 05-29-2009, 09:39 PM   #16 (permalink)
Enclosure 5 x 2-1/2 x 1-3/4
Press-fits perfectly in the ashtray of my 95 Neon, the hole in the side allows USB plug-in or the RJ11 to be routed through in the vehicle.
Pushbuttons were made by cutting off LEDs.
The only trouble I had with the initial installation was the RJ11 cable wired backwards - fortunately the MPGuino (the kit from Spiffie) wasn't fried.
I hooked to the #4 injector - unfortunately you can't see the wire because it is in the conduit.
Name:	Copy of DSCF4759.jpg
ID:	3610   Click image for larger version
Name:	Copy of DSCF4760.jpg
ID:	3611   Click image for larger version
Name:	Copy of DSCF4761.jpg
ID:	3612   Click image for larger version
Name:	Copy of DSCF4763.jpg
Old 01-30-2010, 10:07 AM   #17 (permalink)
hello all
are in Romania (that's if you hear about us)
I have a question for yetimus
I have a car identical to yours
I would like to build one and I mpguino
hardwer problem is almost solved
which is the source code used by you?
excuse 'English' but translated with Google
I learned in school is Russian and German (it was during communism)
Old 03-09-2010, 01:05 AM   #18 (permalink)
civic - '95 Honda Civic DX 3 door hatchback
90 day: 49.27 mpg (US)
SV - '03 Suzuki SV650 S
90 day: 52.23 mpg (US)
Plexi-enclosure
Here is my enclosure almost complete. Made completely from re-used stuff I had lying around the house.
ID:	5756   Click image for larger version
Old 03-09-2010, 05:49 AM   #19 (permalink)
I finished and I mpguino
I used the Arduino programming than the
I built a separate wiring and I mounted ATMEGA168
works perfectly
ID:	5758   Click image for larger version
Old 03-09-2010, 07:05 AM   #20 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Here's mine
www.HyperKilometreur.com - Quand chaque goutte compte...
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
