Old 03-14-2008, 07:41 AM   #11 (permalink)
Turbo gas guzzler
grocery getter - '03 Mitsu Evolution
90 day: 17.55 mpg (US)
Originally Posted by Ryland View Post
Also when I took my drivers test years ago, they told me never to coast in neutral, but instead to simply use the clutch, apparently they felt it was safer.
I would guess that is to keep someone from getting panicked and putting the car into the wrong gear. Hitting 3rd when you are shooting for 5th can be a little shocking
Old 03-14-2008, 10:26 AM   #12 (permalink)
I'd rather be biking
boxchain's Avatar
Lexie - '98 Honda Civic LX
90 day: 39.46 mpg (US)
Beater Hauler - '92 Isuzu Pickup
Rentaclipse - '08 Mitsubishi Eclipse ?
90 day: 28.28 mpg (US)
Fahrt - '83 BMW R80 ST
I keep my car in gear, and turn the key back to run as well, this keeps my odometer rolling, speedometer working, and alows me to simply let out on the clutch to keep my speed up as I coast up hills, this also prevents me from trying to bump start the engine with the key turned off...
In an emergency situation when you need to accelerate, it's quicker to just let out the clutch and put your foot in it. Putting the car in gear takes an extra fraction of a second, which can make a difference, also it's another thought process you have to do while panicking, another thing that can go wrong. OTOH, most hypermilers aren't going to be in a gear where they can accelerate quickly anyway (5th @ 30) so you're still going to have to shift gears.
My bike runs on dihydrogen monoxide.
I like to use these acronyms
Old 03-14-2008, 01:43 PM   #13 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 126.4 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
You can say that again! A couple years ago me and a friend of mine took a roadtrip with my truck, a 5spd, and he'd never driven a stick before. 15 minutes in a parking lot to get the basics down and we were on the freeway. 14 hours in, he's driving while I'm sleeping. He'd shifted down to 4th to make it up an Appalachian foothill and was trying to shift up after cresting the hill. 3rd gear @ 70mph downhill and he dumps the clutch! Engine redlines and tires squeel and I'm awake now! I've never broken tire loose at that speed with turning or the brakes! Just thought you guys might enjoy the memory jazzie jogged. On a side note, he got better at the whole manual thing the next car he bought was a Jetta TDI 5 or 6 spd, I'm not sure which.
Old 03-14-2008, 02:34 PM   #14 (permalink)
Turbo gas guzzler
Im glad that nothing more than a rude awakening happened, because at those speeds really nasty things happen, I work with an accident reconstructionist and sudden loss of traction at 70 is just ugly. One more reason to make sure everyone here is keeping their head in the game while they are eaking everything they can out of the gallon. Its like the drafting issue, make sure you're not endangering someones life in the hope to get a little extra mpg.
Old 08-25-2009, 08:23 PM   #15 (permalink)
Betty - '08 Volvo S60 2.5T
90 day: 30.07 mpg (US)
For the uninitiated, can someone explain what "bump start" is and how to do it?
Whenever I do a EOC, I always make sure I'm in neutral when the engine goes off and when it goes back on. Otherwise my car makes a loud metal-crashy noise that doesn't sound very promising.
Old 08-25-2009, 08:34 PM   #16 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Turk182 -
Lots of info here :
http://ecomodder.com/forum/showthrea...gine-1141.html
CarloSW2
American Solar Energy Society
Old 08-25-2009, 08:42 PM   #17 (permalink)
Originally Posted by cfg83 View Post
Turk182 -
Lots of info here :
CarloSW2
Thanks! Seems like it can only be done with a MT, not AT, though. Am I reading that right?
Old 08-25-2009, 08:44 PM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Turk182 -
Yes, bump starts are for MT only.
CarloSW2
Old 08-25-2009, 08:58 PM   #19 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
With many ATs, you can leave the vehicle in "D", make sure it's in TC lockup and turn the key off to cut fuel delivery and engine brake. Then, you can turn the key back to the On position without using the starter.
Modern engine will cut fuel on decel anyway (DFCO), but if you need that in-between of compression braking without downshifting into a more aggressive gear, it's something to consider.
Since you lose ABS, Airbags, and most importantly, the Radio, a fuel-injector cut switch might be the best option for this.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
Pulse and glide with Caravan automatic (actually EOC) popimp Hypermiling / EcoDriver's Ed 20 12-29-2007 01:10 AM
