Old 12-11-2024, 02:56 PM   #1661 (permalink)
I knew that (excepting the year). It's easy enough to find, the other concept in 1955 was the EA48.
Number 12 of 15 prototypes produced between 1953 and the end of 1956, the EA-47-12 was VW's first attempt at creating a modern successor to the Beetle. It was the first of many Beetle replacements designed by Italian automobile designer Ghia, which is probably why it looks like the quirky Karmann Ghia. The car was powered by a 1192cc four-cylinder boxer air-cooled engine with a power output of 30 horsepower. In addition, it boasted a transverse link front axle, torsion bar rear suspension, and fully synchronized gearbox—unique technology for the time. Top speed was 50 mph.
Source - Volkswagen
https://www.conceptcarz.com/z31664/v...n-ea47-12.aspx
I think the driver of that single cab was about to lose some teeth, unless they're really strapped down.
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
ChopStix (12-22-2024)
Old 12-16-2024, 05:39 PM   #1662 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
ID:	35401   Click image for larger version
ID:	35402   Click image for larger version
ID:	35403   Click image for larger version
ID:	35404   Click image for larger version
ID:	35406   Click image for larger version
ID:	35407   Click image for larger version
The Following User Says Thank You to ChopStix For This Useful Post:
Joggernot (12-17-2024)
Old 12-16-2024, 06:14 PM   #1663 (permalink)
My eye stops at the A-pillar. There is a crease added that runs from the frunk opening to the sun visor. And the drip rail is truncated..
Old 12-19-2024, 12:25 AM   #1664 (permalink)
Old 12-21-2024, 07:26 PM   #1665 (permalink)
Only my second favorite Type III; because the rear roofline. But because my first car was a bullet-nosed Studebaker. I don't mind those probably 1954 Packard, else 1956 Cadillac tail lights.
Somebody should reproduce Ron Courtney's X-51 from a sectioned Type III Notchback.
https://kustomrama.com/w/images/thum...rd-custom7.jpg
ChopStix (12-22-2024), Joggernot (12-22-2024)
Old 12-22-2024, 10:15 AM   #1666 (permalink)
ChopStix's Avatar
ID:	35411   Click image for larger version
ID:	35412   Click image for larger version
ID:	35413   Click image for larger version
ID:	35414   Click image for larger version
Old 12-22-2024, 10:16 AM   #1667 (permalink)
ChopStix's Avatar
Love that
freebeard (12-22-2024)
Old 12-22-2024, 04:21 PM   #1668 (permalink)
Here's what I was driving when I saw Ron Courtney's shoebox Ford on the street in McMinnville, OR. I know Studebaker and Ford had a similar cowl width; it looks like Mr. Roussell didn't have to shrink things much to fit the Type III.
https://images.ca.khaoscontrolweb.ne...if?w=300&h=300
In the 1980s there was a famous topless Squareback show car (the underbody was painted with scallops to match the topside) that had a chopped Type II windshield (with Safari windows). That would pair well with the bullet nose.
It works the other way too. I held a Type III windshield up to my panel van and the width was perfect. The top would tuck under the roof and block or eliminate the ventilator. It would be a not-bay window.
Old 01-02-2025, 10:35 AM   #1669 (permalink)
ChopStix's Avatar
Factory Diesel
ID:	35423   Click image for larger version
ID:	35424   Click image for larger version
ID:	35425   Click image for larger version
ID:	35426   Click image for larger version
ID:	35428   Click image for larger version
