Old 07-21-2024, 07:23 PM   #71 (permalink)
Current drawings illustrating Zevo's wake size.
ID:	34927   Click image for larger version
Name:	Screenshot 2024-07-21 at 7.36.22 PM.jpg
The Following User Says Thank You to JohnForde For This Useful Post:
aerohead (07-22-2024)
Old 07-22-2024, 10:49 AM   #72 (permalink)
' yellow perimeter '
1) If choosing, I'd go with less than 14-degrees.
2) And it would integrate into the 'cuff' itself, where the local tangent angle agrees with the design slope angle.
3) If the slope begins on the 'yellow' perimeter, all the flow will have already been lost on the cuff, wherever the tangent angle reached 25-degrees.
4) If you must begin on the yellow line, then you're looking at a box-cavity technology, instead of a boat tail.
5) The extension panels would just go 'straight' to the rear, perpendicular to the rear of the box, with their trailing edge falling along an imaginary
streamlined path, capturing locked-vortices between the 'cuff' and the trailing edges.
6) And whether a boat tail, or box-cavity, the surfaces where they attach and adjoin each other. must be 'airtight'.
Please look at #62 (permalink ).
This is a 'Cliff Notes' version of Boundary-Layer Theory, $75,000 if you want to get in college.
BamZipPow (07-24-2024)
Old 07-22-2024, 04:51 PM   #73 (permalink)
I might be able to install these and try them Thursday or Friday.
Name:	Screenshot 2024-07-22 at 3.48.05 PM.jpg
ID:	34931   Click image for larger version
Name:	Screenshot 2024-07-22 at 3.49.12 PM.jpg
ID:	34932   Click image for larger version
Name:	For phil k 7-22.jpg
The Following 3 Users Say Thank You to JohnForde For This Useful Post:
aerohead (07-25-2024), JSH (07-23-2024), Piwoslaw (07-23-2024)
Old 07-22-2024, 07:18 PM   #74 (permalink)
Once your done prototyping, it might help to replace that cuff completely.
Old 07-23-2024, 08:29 AM   #75 (permalink)
A guy can dream. I should have numbers in a week.
Name:	ZEVO rear 14 degree.jpg
The Following 2 Users Say Thank You to JohnForde For This Useful Post:
aerohead (07-25-2024), BamZipPow (07-24-2024)
Old 07-25-2024, 10:27 AM   #76 (permalink)
' 14-degrees '
I located a citation online, from a 2013 Lawrence Livermore National Laboratory piece on Semi-trailer boat tails, starting on page-12 from the top of the report.
Of special interest is 'Tail 2' a straight, 11-degree EBLA tail, top and sides, with horizontal floor.
Tail 2 produced the lowest Cd of four tails tested, @ delta-26% for a 48" , 3-sided tail, and delta-26.1%, for a 32", 4-sided tail.
If extrapolated to full-length, Tail 2 would be 263.3" in total boat-tail length, longest of the four.
The trailer's 'box' was only streamlined, starting with a wake of 80.75-sq-ft, and reducing to 67.372-sq-ft/ 62.19-sq-ft, respectively; a 16.56% / 22.97% wake reduction, respectively.
Qualitatively, a 4-sided, 48" tail would provide a delta 36.2% Cd.
It's worth a 'long' look!https://www.energy.gov/sites/prod/fi...ari_2013_o.pdf
File Type: pdf vss006_salari_2013_o.pdf (919 Bytes, 10 views)
The Following 3 Users Say Thank You to aerohead For This Useful Post:
JohnForde (07-26-2024), JSH (07-25-2024), Piwoslaw (07-25-2024)
Old 07-25-2024, 10:30 AM   #77 (permalink)
' 14-degrees '
Please look at #76 ( permalink )
Old 07-26-2024, 07:07 AM   #78 (permalink)
Joggernot's Avatar
I'm not able to open the file. Can download the file (done twice), but get an error. Tried another way and got "file not found" error.
The Following User Says Thank You to Joggernot For This Useful Post:
Old 07-26-2024, 02:19 PM   #79 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The uploaded file does not open for me. However the link in the body of the post works fine and goes to the same document.
EDIT: This is likely the most interesting page
And I liked this plywood prototype:
Name:	Trailer Tail Aero.jpg
ID:	34944   Click image for larger version
Name:	Plywood Trailer Tail.jpg
The Following 4 Users Say Thank You to JSH For This Useful Post:
aerohead (07-29-2024), Joggernot (07-27-2024), JohnForde (07-26-2024), Piwoslaw (07-26-2024)
Old 07-27-2024, 12:39 PM   #80 (permalink)
It is rarely this hot here in MN. I had hoped to build today but will soon.
My plan is a rounded cuff of 1.5m radius followed by a hinged door at 14-18 deg. It might make sense to put vortex generators right in from of the hinge.
Name:	Screenshot 2024-07-27 at 11.32.37 AM.jpg
brightdrop, electric van, zevo
