Old 10-15-2010, 02:45 PM   #21 (permalink)
Originally Posted by basjoos View Post
The Chevy Cruze comes with a either a 6 speed manual or a 6 speed dual clutch automatic, both with the same gear ratios and the manual gets 4 mpg better city and 1 mpg better highway mileage. From your description above, the dual clutch automatic goes into 6 gear engine braking whenever you let up on the throttle rather than the no drag freewheel that's available with just the touch of the clutch pedal on the manual. And with freewheel easily tapped, it is a lot easier to hypermile your way to even greater mileages than the EPA stickers would show. They've sold a lot of manual Cruzes overseas, so it must be enjoyable to drive.
I have very tall gears on my manual Honda Civic CX and manual Ford F150 and have no problems or frustration driving them.
Acording to Chevy site the Cruze LS (1.8L ) 6 speed manual gets 26/36mpg and the Cruze LT, LTZ with 6 speed DC auto gets 24/36 but have turbo 1.4L engines with fatter TQ #'s
Old 10-15-2010, 04:42 PM   #22 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
That mileage comparison isn't valid since the two cars being compared have a different transmission and engine. The EPA mileage figures I saw were 26/36 mpg with the base 1.8-liter four-cylinder and a 6 speed manual and 22/35 mpg for the same engine with the 6 speed automatic.
The Following User Says Thank You to basjoos For This Useful Post:
Allch Chcar (10-25-2010)
Old 10-27-2010, 03:52 PM   #23 (permalink)
RSX2fast4mpg - '02 Acura RSX Type S
90 day: 38.22 mpg (US)
bubbatrucker - '98 Chevrolet K1500
90 day: 18.1 mpg (US)
So if there's no torque converter and no transmission oil pump in the auto, why couldn't you turn the engine off in neutral? I thought the reason you couldn't/shouldn't turn off the engine in an auto was because it stopped the flow of oil in the transmission, thus, you had an unlubricated driveshaft end of the transmission.
I'm not claiming you can, I'm just curious if I understand correctly.
BTW, this is the first American-made car that has piqued my interest in the last 20+ years (since I sold my hotrod). Not to say I haven't owned a half-dozen Chevy/GMC pick ups and Blazers in that time, but they were tools of necessity rather than something that actually interested me.
Old 10-27-2010, 04:20 PM   #24 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I agree that Detroit has mad a lot of uninteresting vehicles for many years. Thankfully Ford seems to be doing a good job of improving the quality and value of their vehicles.
Bassjoos did make an excellent point about the differing gear ratios. The tallest overdrive gear ratio I've ever owned was in an automatic; for the life of me I can't understand why car makers can't put taller gears into manuals as stock. I know the 6 speed in the Corvette has a ridiculous overdrive (.50 to 1 IIRC) which allows the Corvette to get amazing fuel economy on the highway when cruising, as in around 30 mpg!
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 10-27-2010, 05:35 PM   #25 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
most likely as with an auto if it starts to bog on you, the trans downshifts, with a manual, you could end up damaging the engine if you refuse to downshift.
thats the best reason I can come up with.
~Mike
Old 10-27-2010, 06:03 PM   #26 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Originally Posted by euromodder View Post
BTW the Fiesta Econetic (diesel) version, is rated for 3.7 L/100km or 63.6 mpg US in the Euro cycle !
Aargh rub it in!
Nissan Versa Aeromods
Old 10-27-2010, 08:13 PM   #27 (permalink)
White Lightning - '98 Ford Ranger XLT Off Road
If they built it with special piston rings and cylinders as they do marine engines, then you could bog that motor down all day. I believe marine engines also use special bearings.
1998 Ford Ranger 4.0L 4x4
Old 10-27-2010, 08:52 PM   #28 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Modern engines like my cobalt 2.2 won't bog like antiques because the computer doesn't allow it, I have driven off from 500rpms with rather minor bog, it just doesn't take off efficiently doing that.
I find it odd my 5sp cobalt is rated higher than the 6sp cruise, should have put in a double overdrive instead of short shifter me thinks.
Old 10-27-2010, 10:48 PM   #29 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Someone would have to be pretty brain dead to not understand what the engine is telling you long before you can do any damage. I can do the same thing <20mph in 5th in most cars.
Not so much. A marine engine is built to run at a higher power setting for long durations. As in 80% load at 3500 rpm. They use heavier duty bearings, better internal oiling, and increased cooling to deal with the higher internal temperatures and higher average stresses that they are submitted to continuously.
The bogging and chugging you get when you lug an engine is due to the spark happening before top dead center, and with lower speed the piston is not far enough past top dead center when the pressure of the expanding fuel charge is increasing. So instead of adding a push down the burning fuel charge puts a stopping pressure on the piston and the momentum of the engine and previous combustion in other cylinders forces the "lugged" cylinder over the top and down.
This increase in resistance coupled with low oil pressure (because the engine driven oil pump is not turning very fast) causes the rod bearings to squish all the oil out and the bearing surfaces come into contact.
A marine engine with better bearings can withstand this for longer (though it would not likely be subjected to this as water is a viscous medium to transmit power to rather than a tire/road interface) but it is still bad for it.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 10-28-2010, 10:14 AM   #30 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
I want to know this too... or if you can just pop it in neutral (since in this case it would be "true" netural)
Auto Meter 9100 ecometer MPG gauge gone-ot Instrumentation 27 08-26-2013 01:11 PM
Review: 2008 Chevy Malibu LT (31.3 MPG) RH77 General Efficiency Discussion 12 05-16-2009 09:07 AM
Review: 2008 Toyota Avalon Touring Edition (32.8 MPG) RH77 General Efficiency Discussion 2 09-04-2008 01:27 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Autoblog Prius review: more evidence of the power of MPG instrumentation MetroMPG Instrumentation 6 01-02-2008 11:48 PM
