Old 10-08-2008, 06:32 PM   #1 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Frog in a Pot; a tale of tire pressure
If you throw a frog in a pot of boiling water, he'll jump out. Put him in some nice cool water and slowly bring it up to boil, he'll swim around dumb and happy until he croaks. Or so I've been told.
I was that frog recently.
My last two fill-ups have not reflected the MPGs I thought I should be getting. I was wondering if the new spark plugs I put in were to blame. Then I checked my tire pressure before leaving work. Yikes. They were all lower than where I like to keep them, and the front left was down below 30 psi. I put them back up to where I want them. (I'm NOT posting this story to spark yet another PSI debate...) Sure enough, on the way home the Vibe glided further and required less LOD on the SG to maintain speed, ie; like it used to! I had slowly gotten use to shorter glides and higher load readings over a period of time. Grrr.
Moral of the story; Don't be a frog in a pot. If your car doesn't perform like it used to, investigate. Check your tire pressures!
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
101Volts (08-14-2013)
Old 10-08-2008, 07:17 PM   #2 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
It's a seasonal thing. Everyone should check them at least once per season because temperature changes air pressure and some tires leak slowly. Good reminder. Thanks.
A real modding freak would check them every fill up.
That's sure not me. Off to the van I go... Damn moon discs.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 10-08-2008, 07:51 PM   #3 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
It's funny... All the time and attention we put into driving style and into modding, and we STILL forget to check our tire pressure. I wonder why that is?
The Following User Says Thank You to Will For This Useful Post:
Old 10-08-2008, 08:12 PM   #4 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I tend to do the same-- I don't check my pressure until I notice poor coasting. Luckily, my morning commute involves stretches of coasting that are extremely consistent when everything is working right.
Interestingly, wet weather is working against me. My longest coasting stretch starts at 50mph or so, and ends at 30mph or so (over about 1km), but when it's wet or my tire pressure is out of whack (i.e., one or more get down to about 35psi), I am only doing about 20mph at the end of that stretch.
The cold weather is also killing my FE, I think, and it's only fall! I've always notices lousy fuel consumption in the winter, but I've never tracked it as closely as I do now.
My last tank was a paltry 36.5mpg. The upside-- It took me three and a half weeks to use ten gallons of gas, and it was entirely in-town driving, so I guess it's not that bad.
The Following User Says Thank You to whokilledthejams For This Useful Post:
Old 10-08-2008, 10:03 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Will -
I'm too lazy. Also, it only occurs to me after I have been driving. I've read that the optimum time to check the PSI is when the tires are cold.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Old 10-08-2008, 10:20 PM   #6 (permalink)
90 day: 51.82 mpg (US)
Funny, I was going to post a similar story just last week when I noticed a difference in the ForkenSwift. Not the gliding so much, but it seemed to be riding much more "cushy" than usual... Sure enough all tires a bit low, one way down.
Corrected! Can now tell again whether a penny is heads or tails when I drive over it.
Did I learn my lesson and go check the Flea? Um, nope. Tomorrow!
Old 10-09-2008, 02:24 PM   #7 (permalink)
I've made a habit of checking my tire pressure during the first week of every month. I always know how long it's been since they were checked and it also makes it much easier to remember to do it.
Old 10-09-2008, 02:48 PM   #8 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
i had noticed my mileage being lower than expected - so i checked the tires and sure enough - they were all below 20 !!!!!.
I like the 1st of the month check - makes it easier to remember to check.
steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 10-09-2008, 05:03 PM   #9 (permalink)
Deadly Efficient
Yup, that's what I've determined to do. Along with a fluid check.
-Terry
Old 10-09-2008, 08:03 PM   #10 (permalink)
Thumbs up
I check them every day.
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
