05-08-2013, 04:00 PM
#31 (permalink)
Originally Posted by divedaddy03
...I don't know how all I'm gong to be able to test this (without a lab) with limited funds but I'm going to do my best to show you all the same data that I'm looking at and I'm leaning towards ABA tests as well.
Wayne, SC
Why, of course you will generate the funds you need to do proper testing by saving fuel from that grooved throttle body.
In addition, you can save even more by applying the true and tested 100+ hypermiling tips.
Once you have accumulated wealth this way, please spend some of it on the proper testing and report back here, at that time.
No need to quote my entire post and thank me in kind words right now, I'd be more than happy to wait for your reply until after the testing has been done.
05-08-2013, 04:12 PM
#32 (permalink)
I'm just sitting here LMAO at all this money, documentation, debate, and general mental gymnastics expended over a fracking gouge in a piece of aluminum.
Incidentally, gouge is a noun AND a verb...
Main Entry: channel
Part of Speech: noun
Definition: pathway, usually containing water
Synonyms: approach, aqueduct, arroyo, artery, avenue, canal, canyon, carrier, chamber, chase, conduit, course, dig, ditch, duct, fluting, furrow, gouge , groove, gully, gutter, main, means, medium, pass, passage, pipe, raceway, route, runway, sewer, slit, sound, strait, tideway, trough, tube, tunnel, vein, watercourse, way
Main Entry: cheat
Part of Speech: verb
Definition: defraud, fool
Synonyms: bamboozle*, beat, beguile, bilk, bleed, bunco, burn, caboodle, chisel, con, cozen, crib, cross, deceive, defraud, delude, diddle, do a number on, do*, double-cross, double-deal, dupe, fast talk, finagle, fleece, flimflam, fudge, give bum steer, gouge , gyp, hoodwink, hose, jerk around, milk, mislead, pull one's leg, ream, rip off, rook, rope in, sandbag, scam, screw, shaft, short, shuck, skin, snow, stiff, sucker, swindle, take, take for a ride, take in, take out, trick, trim, two-time, victimize
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
05-08-2013, 04:23 PM
#33 (permalink)
Smeghead
Main Entry: channel
Main Entry: cheat
I tip my hat to you sir.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
05-08-2013, 04:58 PM
#34 (permalink)
That's how I feel... regardless of whether or not it does anything beneficial, it's a gouge in a piece of aluminum. How is it even possible to enforce... anything... about that? If I go out to my garage and cut a groove in my throttle body are they going to come sue me over it?
Anyway that complaint is about The Gadgetman(TM) (R) (c) Experience. I'm still eagerly and respectfully following the thread to see if anything comes of the actual gouge in the actual aluminum.
Work From Home mod has saved more fuel than everything else put together.
05-08-2013, 05:07 PM
#35 (permalink)
Going forward I will refer to it as the Gadgetman Gouge.
05-08-2013, 05:18 PM
#36 (permalink)
Aero Deshi
Hi Wayne,
I appreciate the civil attitude you have cultivated here, these things can get out of hand. I can be really bad myself at times, but, I always start out respectful. I hope others make a concerted effort to remain cordial as well.
In reading through everything, and having a pretty solid working knowledge of the way engines work in regard to fuel injection, air induction and such I have some insight I'd like to share. I hope this opens a discussion and learning opportunity for everyone to better understand how things work.
Funny, back in November I got into a thread discussion where a guy who was claiming that Variable Valve Timing was a way to eliminate pumping loss, I thought he was full of it, but this led me to research the whole VVT thing and really cemented for me how it is that intake systems control the power of engines. The thread is Warm Air Intake (WAI) vs Cold Air Intake (CAI) ... School Me and worth having a look at.
Based on this, and the knowledge that Pumping Loss is the only real area that the Gadgetman groove concept can have an effect on to improve fuel economy, I see no way the his modification can improve an engine in order for it to run more fuel efficiently. At the end of the day, I think the engine management system will compensate for any perceived imbalance that it sees between what the Mass Air Flow sensor is telling it and what the Throttle Position Sensor is indicating.
His trick in theory is to put the engine in a lean burn condition whereby the fuel air mixture leans out due to more air being "snuck" into the engine via his modification to the throttle body, I could be wrong, but I believe the engine management system is smarter than this and will compensate for the extra air and keep the fuel air mixture the same.
Modern engines are 98%+ efficient at burning all the fuel that goes into the cylinder, so looking to improve fuel efficiency by claiming to promote “Better Combustion” is ridiculous. Pumping losses are a result of the cylinders in our engines needing to pull a small amount air into the cylinder in relation to what the cylinder is capable of pulling in. These result in about 3% of the energy produced by the engine being wasted on this process. No modification of the throttle body can eliminate this loss.
So the only 2 efficiency losses in an automobile that a throttle body modification can possibly have an effect are already very small, and the mod does nothing to improve either.
Your car needs X amount of power to go a certain speed, and unless you can improve the efficiency of the engine to create the same power with less fuel, you can’t get better mileage. Since there is no way for an air intake system change alone to improve the fuel efficiency of the engine, the idea of modifying it to improve mileage is doomed from the start. People who say otherwise are simply trying to baffle with BS because they know 99.7% of the people out there don’t have a clue about how the air intake functions to control the power of a car to begin with.
As always, there is a 1% chance I’m wrong, and would love to learn more if I am, so school me.
The Following 9 Users Say Thank You to ChazInMT For This Useful Post:
05-08-2013, 05:51 PM
#37 (permalink)
See, that's the kind of post that makes me happy I subscribed to this thread
05-08-2013, 07:19 PM
#38 (permalink)
Gougeman now has $350 towards getting proper instrumentation/testing.
05-08-2013, 08:18 PM
#39 (permalink)
Manifold vacuum is the enemy of efficiency, but when you eliminaute manifold vacuum you basically are at wide open throttle or close to it, which is why pulse and glide can increase mileage substantially.
If you restrict the incoming air to 50% of atmospheric pressure then you are in essence running the throttle wide open at 18,000 feet altitude, which is why turbo or superchargers are necessary on high altitude aircraft engines.
regards
Mech
05-08-2013, 08:32 PM
#40 (permalink)
X - '02 Ford Excursion Limited
Poppin popcorn as we speak lol.
