Old 03-07-2010, 09:44 PM   #11 (permalink)
I'd be suspicious of a vacuum leak. I had one on my car and it had symptoms like you describe: ran poorly when warm, reduced power, and ate fuel at about a rate of 20 mpg (US).
It did not set off the check engine light.
How does one check for such? Be very detailed and specific.
Old 03-07-2010, 10:06 PM   #12 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I diagnosed mine with a ScanGauge (MAP - Manifold Absolute Pressure) reading which showed it way out of normal range. ScanGauge is not an option on your '92, unfortunately.
Google "how to find engine vacuum leak" for other detection methods (that's what I'd do).
Has your exhaust become smellier or more noticeable (cloudy)? Mine did, because the vac leak caused a rich condition.
Cincyguy (03-08-2010)
Old 03-07-2010, 10:09 PM   #13 (permalink)
What's Google? Haha- Just Kidding. Will check.
Nothing coming out of the exhaust any smellier than normal.
Old 03-08-2010, 09:14 AM   #14 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I suspect a clogged cat, clogged fuel filter, poor spark, or low compression.
GeoMetroforum.com - got mpg?
The Following User Says Thank You to Johnny Mullet For This Useful Post:
Old 03-09-2010, 12:20 PM   #15 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Cincyguy View Post
The fuel filter is in the tank? Or the fuel pump?
There's a fine screen bag in the tank attached to the pump like all cars have. It shouldn't be clogged unless you've been dumping really dirty fuel into the tank. But there's also a real fuel filter next to the tank, on the driver's side. Round black cylinder with two fuel hoses clamped to it. Wouldn't hurt to change it.
I think some of the later Metros had just an in-tank filter instead of the screen bag, but your '92 has an external filter.
Old 03-09-2010, 06:39 PM   #16 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
i'd check the vaccum lines, filters (fuel air Etc), also a fuel regulator may have somethin to do with it
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
catalytic, converter, low, performance, sluggish
Tested: power draw of Geo Metro accessories & systems (volts, current/amps, watts) MetroMPG EcoModding Central 28 10-06-2013 09:47 PM
Restoring a 1989 Geo Metro IheartGeos Introductions 18 02-22-2010 01:00 AM
A Running Log website similar to EcoModder? 1337 Off-Topic Tech 2 03-12-2009 04:28 AM
94 geo motor/tranny swap into a 96 geo body tborgers DIY / How-to 13 12-31-2008 12:15 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
