Old 02-01-2015, 07:05 PM   #1 (permalink)
Grid Charger connections
First would like to thank all for this resource. Takes some of the mystery out of the hybrid vehicles.
I have a 1st gen Civic, 2003, that has an IMA light on. I finally built a basic grid charger hoping to charge the pack up and and balance it. I got the schematic from 99mph.com. I connected the charger to the battery's output terminal but have not been able to get the pack to charge. I am guessing there is a different spot I need to connect the charger to? Thank you for your help.
Old 02-02-2015, 01:00 AM   #2 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I would compare the instructions to those on this site: Hybrid Automotive - Grid Charger Installation Instructions
Camry Thread
E-Bike Thread
Old 02-03-2015, 10:11 AM   #3 (permalink)
90 day: 39.99 mpg (US)
See post #93 in my thread:
http://ecomodder.com/forum/showthrea...-29288-10.html
The IMA system should be laid out nearly identically in our cars.
Old 02-03-2015, 04:40 PM   #4 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
The IMA from the civic and insight are completely different. Ours lays flat while civics sit sideways. The routing and the fan harness installation is also different by a lot.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Ecky (02-03-2015)
Old 02-03-2015, 04:47 PM   #5 (permalink)
My bad. I assumed since it was the same basic system... yeah.
Old 02-03-2015, 04:49 PM   #6 (permalink)
Furry Furfag
Sadly, no its not. I don't understand why Honda went with the wacky way they did it, but I guess it is what it is.
Old 02-21-2015, 06:44 PM   #7 (permalink)
The temperature finally got to double digits on the weekend and got the ambition to shovel the car out of the snowbank and play around with the battery. Charger appears to be working now. Have LED light and voltage at 156.7 when charger on. The battery was totally flat sitting in the cold for couple months. Will see what happens. Thanks for the help with the charger connections.
Old 02-22-2015, 01:08 PM   #8 (permalink)
This morning I checked on the grid charger and charging LED was off. Power supply still putting out power but main battery terminals have no voltage on them. I read 175.6 V on the terminals where the grid charger is connected, that is without the charger on. Is this normal not to have voltage on the main battery terminals when the vehicle is sitting? The grid charger was on for about 8 hours last night.
Old 04-19-2015, 02:13 PM   #9 (permalink)
Battery charging
Just want to send an update. I hooked the grid charger to the connections from the linkk and have been able to charge the battery. The IMA light has been off and I was actually able to get the car through inspection!! I have been charging the battery about once a week overnight and have seen improvements on the packs charge and discharge rates. Thank you all for you help with this. I can actually use the car again. Wish I had done this sooner!!
Old 09-03-2015, 11:28 PM   #10 (permalink)
Carbon Abuser
iamnotahippee's Avatar
Olaf - '03 Honda Civic Hybrid
Sven - '06 Volvo Xc90 2.5t
Work Truck - '04 Chevy Silverado 3500
I know i digging up an older post, how is your grid charger working out? Are you still getting good results?
Where did you source your power supplies?
1986 Chevy C-10 10mpg Grandpa's Truck
2004 Chevy 3500 diesel 10mpg The work Truck
2003 Honda Civic Hybrid 5 spd ?? Mpg My Carbon Pentance
