Old 05-13-2020, 02:08 PM   #71 (permalink)
donuts
Originally Posted by easythereturbo View Post
So much win here on page7. Good enough > perfection. Emotional investment.. and black wheels so so trendy. But to each.
I feel the same way about large wheels, so trendy. But what sells on the showroom floor matters to car makers more than anything. Understandably. So wide glossy black 22x10's sticking right up to the fender edge it is. Aero be damned.
Here is one for anybody who thinks you need huge wheels to have a sporting time in a car..
IMO the FRS dev team got it right when they spec'd skinny LRR tires as standard on that one. And the fun to fuel cost ratio on that vehicle happens to be very high.
CAR and DRIVER did the same thing on a Corvette in the 90s.It nearly scored as high a lateral G rating on the skidpad,as with the big fatty,OEM speed rated rubber. Isn't rubber compounding wonderful?
easythereturbo (05-13-2020)
Old 05-13-2020, 02:30 PM   #72 (permalink)
Originally Posted by aerohead
...re-test the Pontiac at Windstream,with and without rotation,and publish the difference.
That is pretty genius, A-B-A test the wind tunnel.
On the Beetle? Black? ... So, boring old silver.
Those are the obvious choices, but if I didn't think I'd get bored of it, a classic artillery spoke look:
https://classicgaragellc.wordpress.c...l-restoration/
http://www.2040-parts.com/1920s-1930...sler-i1966008/
So, maybe satin black with the wood-graining done in Plastidip?
Old 05-13-2020, 06:59 PM   #73 (permalink)
I have a 2013 FORD CMAX with 250K miles and I have been using flat LEXAN wheel covers for 240k miles and I gained 2 mpg which I have tested many times. I have read they increase 4 % mpg's. https://fordcmaxhybridforum.com/uplo...1382541182.jpg My mpg average for the last 140k miles is 52.8 mpg.
Paul
The Following User Says Thank You to ptjones For This Useful Post:
Old 05-13-2020, 07:21 PM   #74 (permalink)
Clear Lexan?
How are they adhered?
Old 05-13-2020, 09:58 PM   #75 (permalink)
Casual Modder
White Egg - '92 Nissan NX2000 SE
Last 3: 29.69 mpg (US)
The only way to factually determine a 'downside' is, to re-test the Pontiac at Windstream,with and without rotation,and publish the difference.Otherwise,it is scientifically impossible to know,one way or another,and pure speculation on your part.
What I should have said was that that the Lockheed testing was incomplete and not reflective of real world situations. I think the coast down testing that our members do here is more relevant than static wind tunnel testing, at least for the design of the underside, fender openings and wheels.
The Following 2 Users Say Thank You to TimRogers For This Useful Post:
aerohead (05-15-2020), gumby79 (05-13-2020)
Old 05-13-2020, 11:16 PM   #76 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Clear Lexan?
Appears a single bolt in the center through an aftermarket center cap press fit into to the wheel.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
freebeard (05-13-2020)
Old 05-14-2020, 01:55 AM   #77 (permalink)
Paul
Very neat.
Old 05-14-2020, 10:34 AM   #78 (permalink)
wheel cover
Clear Lexan?
I used a 1/4"-20 x 2" SS screw with 1/4"ID x 1.5" fender washer thru a 1/2"OD/ 1/4" ID x 1/2" long Nylon bushing. Machined a 2"Diameter aluminum plug w/1/4"-20 threaded hole to go inside the backside of the wheel to screw in the 1/4" screw. Used silicon rubber to glue in the plug so it could be removed and stuck back in when replacing tires. Use Lock Tight/Permatex medium strength glue on threads to keep screw from unscrewing. Used a nylon 1/4"-20x 1.5" screw near the edge of the cover screwed thru the cover and on the inside I have a 1/4"-20 nylon nut to lock the screw in place, this keeps the cover from turning when stepping on the brakes and damaging wheel spokes.
On the inside of the cover at the edge I use foam window seal tape 3/16"H x 3/8" W to stick on the inside of cover and go between the wheel cover and edge of the wheel all the way around. When it gets hot I have had problems with the tape adhesive losing grip so have used Supper Glue on the cover to stick the the foam tape on better.
Paul
Paul
The Following 3 Users Say Thank You to ptjones For This Useful Post:
aerohead (05-15-2020), freebeard (05-14-2020), JulianEdgar (05-14-2020)
Old 05-15-2020, 02:03 PM   #79 (permalink)
real world
*FKFS had three wind tunnels. One was a rolling-road type. Fachsenfeld reports the differences in drag they measured, with and without rotation. The results would have to be considered in the context of the typical passenger cars of the day.
*General Motors also explored rolling-road wind tunnel results around 1953 and reported that the difference in data was numerically insignificant,and could be easily compensated for,through simple modifications of tires during static testing.Again,the conclusion would have to be taken within the context of the reporting timeline.
*Wolf H.Hucho basically said the same thing in 1987.For high-speed sports cars and race cars it was another matter.Especially open-wheeled race cars.
*I don't believe that there's any disagreement as to the superiority to the rolling-road technology,however,any arbitrary extrapolation regarding the magnitude in error of drag coefficients derived in earlier,static-wheel testing would be un-founded and dubious at best,unless actually backed up by re-testing of a given specific vehicle,with and without the rotation and moving floor.This is my main objection to Mr. Edgar's claims. There exists no 'a priori',generalized knowledge of drag variability as a function of wheel rotation/stasis. Any excursion from this 'condition' would demand scientific verification,on a case-specific basis.
We could attack Julian for not employing laser-doppler-anemometry when compiling his pressure study data.If the results are the same,or within some standard deviation,do we want to go there?
Old 05-15-2020, 02:53 PM   #80 (permalink)
When I am doing testing, when I take the covers off to clean covers and wheels, it is easy to see the MPG difference on my trip MPG gauge.
Paul
gumby79 (05-15-2020)
