08-10-2018, 05:29 PM
#111 (permalink)
You’ve lost it lol... 40 RPM isn’t worth it... now if you already had to replace the synchros, maybe, but I’d still leave well enough alone...
My current Ecotec project...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
08-10-2018, 05:35 PM
#112 (permalink)
Eco Storm Chaser
If you had a rsx or a si 5 speed and was doing the 6speed conversion, then sure, why not.
However, if you already have the tsx 6th (aka accord 5th) the 0.659 vs 0.647 is completely negligible .
Not to to bring up ROI, but $200 could build you a full belly pan!
The Following User Says Thank You to Stacygifford For This Useful Post:
08-10-2018, 09:15 PM
#113 (permalink)
Thanks. When Ecomodder tells you not to do an ecomod, it's probably a good idea not to.
08-10-2018, 09:30 PM
#114 (permalink)
Eco Storm Chaser
If you do purchase the 0.647 I'll send you some $ for the tsx 6th! If that helps lol
08-11-2018, 01:14 PM
#115 (permalink)
So I ordered the gear.
Also, finished installing my sound-deadening. WOW, what a difference. First test drive, I can only liken it to how everything gets very quiet when your ears need to pop. Bass response from the speakers in the doors also greatly improved.
Older picture, there's even more dampening in the hatch area now:
Replaced the noisy ~40mm fan in the Meanwell power supply with two silent 92mm fans:
Also, I averaged ~129mpg on the way back from the recycling center, where I was donating aluminum.
The Following 4 Users Say Thank You to Ecky For This Useful Post:
08-11-2018, 05:43 PM
#116 (permalink)
The Following 2 Users Say Thank You to Ecky For This Useful Post:
08-11-2018, 05:54 PM
#117 (permalink)
Eco Storm Chaser
Ecky, you are really pushing me to make me want to make my insight better! I may have to add sound deadening to the list of things to do.... With as much driving as I do, it would probably help tremendously.
08-12-2018, 07:27 AM
#118 (permalink)
It's one of those mods with zero direct ROI, but certainly makes the car more pleasant to drive.
08-12-2018, 07:24 PM
#119 (permalink)
More progress in the back:
Also, cut off 1/3 of a coil from my springs, to lower the rear which came up almost an inch and a half with the removal of the IMA system. I think I need to take another 1/3 of a coil off.
https://i.imgur.com/0YcOl1v.jpg
08-12-2018, 07:52 PM
#120 (permalink)
Cyborg ECU
Originally Posted by Ecky
So it looks like your dampening is both on the inside of the outter door panel and the inside behind the inner trim. Correct that you added all of that? Did you go under the carpet, too? I don't recall seeing pics of that.
