Old 07-28-2018, 03:51 PM   #91 (permalink)
late to the thread.
Originally Posted by California98Civic
The weight distribution problem sounds kinda, well, dangerous maybe. Traction on the power wheels would be fine, but how would braking and especially cornering be affected?
I drove for decades with a 40/60 weight distribution. After battery location, you can fine tune the handling with tire size and inflation pressure. Higher pressure on the heavy end.
'Meanwell' is the best brand name I've seen since 'Dunn-Wright'.
Old 07-28-2018, 04:45 PM   #92 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Yeah I felt the same but supposedly they actually make excellent stuff.
Old 07-28-2018, 05:21 PM   #93 (permalink)
teoman's Avatar
A3 - '12 Audi A3
They are a reputable brand and would be one of my first choices if I were building a robotics system or an industrial machine.
Pity about the name.
I have used several of their products an have not had a problem.
Old 07-28-2018, 09:59 PM   #94 (permalink)
I was being un-ironic.
Old 07-29-2018, 06:16 PM   #95 (permalink)
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
well, I wish I would have stumbled on this sooner!
https://ecomodder.com/forum/showthre...tml#post565690
if you have ANY questions on the swap, let me know. the wireing actualy isnt that bad. i wouldnt bur the swap harness. Just a c101 pig-tale from a crv will do it. i just pulled out my k24a4 for a k24a2 last week!
Ill be updating my thread soon.
(50 mpg at 70, and 7.479 in the 1/8 @ 98.77 mph on street tires)
The Following 4 Users Say Thank You to Stacygifford For This Useful Post:
California98Civic (08-01-2018), MetroMPG (07-29-2018), samwichse (07-29-2018), wdb (08-04-2018)
Old 08-03-2018, 10:01 PM   #96 (permalink)
Finished cutting up my fuel filler lines, re-routing them, and laying the foundation for my hatch area rebuild.
ID:	24632   Click image for larger version
ID:	24633   Click image for larger version
ID:	24634   Click image for larger version
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Daox (08-04-2018), freebeard (08-03-2018)
Old 08-04-2018, 09:47 AM   #97 (permalink)
Nice work!
Very interested in your fuel line work as my fuel lines are rusted out in the back and I need to re-run at least one line. What is your plan?
Old 08-04-2018, 11:56 AM   #98 (permalink)
I ordered a 1.75" / 45mm ID fuel hose from Rock Auto - it was surprisingly hard to find one that big. I cut up the original fuel lines to reuse the elbows, and used sections of both to route it closer to the wall of the car. I'll post pics in a bit.
Daox (08-04-2018)
Old 08-04-2018, 09:21 PM   #99 (permalink)
Nice work!
As requested:
I cut a hole in the car in a different location, and plan to stuff the area around the hoses with duct sealant putty.
First rear panel finished!
The Following 3 Users Say Thank You to Ecky For This Useful Post:
Daox (08-04-2018), Joggernot (08-05-2018), MetroMPG (08-07-2018)
Old 08-05-2018, 04:15 PM   #100 (permalink)
Eco Storm Chaser
Dear lord, it looks like I may be the one needing help on my "finished" k-swap!
This could be worth tackling when I install my walborro 255. definitely cleans up the back
