08-16-2018, 11:54 AM
#131 (permalink)
Anyone know which vehicles I might look at to get a belt driven brushless motor-generator? Was GM's Eassist belt driven?
08-16-2018, 11:58 AM
#132 (permalink)
The GM system was indeed belt driven, you going hybrid with your K24?
My current Ecotec project...
My last Ecotec project...
08-16-2018, 12:12 PM
#133 (permalink)
Not necessarily, or maybe not at first. I have various ideas about 12v production. Brushed alternators aren't terribly efficient, and I can think of several ways to improve that. I want to look at GM's system and see if I could use it as a better alternator.
08-16-2018, 12:34 PM
#134 (permalink)
08-16-2018, 02:46 PM
#135 (permalink)
Originally Posted by Ecky
Thanks. When Ecomodder tells you not to do an ecomod, it's probably a good idea not to.
Ha! If you have to ask, probably better to keep quiet and just do it.
After all, what did Colin Chapman say: "De-RPM-ify and add cost". Or something like that.
08-16-2018, 10:40 PM
#136 (permalink)
https://ecomodder.com/forum/showthre...tor-35003.html
E-assist uses a serpentine belt with a massive tensioner. Wants 72-115V.
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
08-17-2018, 09:07 AM
#137 (permalink)
If I'm only using it to generate <1000w, and typically <500w, I bet a normal belt should be fine. It will be under the same (or lower) loads as an alternator. I might buy one just to play with.
Unrelated, but thought I'd throw a picture in of my dash. Currently getting ~70mpg / 3.3l/100 in my typical 50% city 50% highway ~12 mile commute. No check engine light, lean burn works, auto-stop currently comes on sometimes  so I need to tweak things a bit, engine needs to stay on in stop and go traffic.
08-18-2018, 06:22 AM
#138 (permalink)
Aero Wannabe
Is there a thread somewhere about your mirror removal? Great thread, it should be a little rocket with the engine swap complete. Subscribed.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
08-19-2018, 12:19 AM
#139 (permalink)
Why? Engine off if below 20 MPH, bump start!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
08-19-2018, 08:19 AM
#140 (permalink)
I thought these could be had for 80 bucks. Hnm.
