Old 08-12-2010, 10:26 AM   #31 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
here is my data file. it has all my raw data and charts.
Old 08-12-2010, 01:19 PM   #32 (permalink)
90 day: 51.82 mpg (US)
Good testing is hard to do even when the weather (wind) does cooperate!
One suggestion: higher speeds will make any difference from aero mods stand out more (if there is any difference).
Old 08-12-2010, 01:29 PM   #33 (permalink)
Wiki Mod
how can I test at a faster speed with out braking the speed limit of 55mph? The only place I can think of is on the freeway (70MPH) but to get no traffic I would have to run the test between 2am and 4 am.
other ideas?
PS did more BABA testing this morning still need to put the data into excel.
Old 08-12-2010, 03:21 PM   #34 (permalink)
Wiki Mod
More data
Update:
I did a second set of steady state testing today.
Notes on testing:
Tested in this order B, A, B2, A2
warmed up car by driving 14 miles before testing (I think this was not enough)
Testing conditions:
Winds 5-8 N, NE
Temp, 78-84
RH: over 90%
speed was 55MPH using cruse
road was about as flat as I have around here.
A= normal no skirt
B= with both wheel skirts on
1S= run 1 South
1N= run 1 North
each way was 1 miles of testing
measurements with scan gauge
Here is the data:
Comments:
Wind was far more consistent today. it had some change to it but not a lot and it did about the same thing during each set of runs. I tossed of runs where there was lots of wind or no wind and still had more samples than yesterday.
The test mile was almost level, it had a hump at the start and end (intersection high spots). This made for less acceleration by the cruse control.
I might make up a graph without set B. I ran this set first and I think that the car was not fully warmed up by the 14 mile drive I did to warm it up. By the end of set B things seem to have fully warmed up as the next sets are similar to each other.
Summery: the data shows a slight benefit with the wheel covers on (.4 MPG or about 1%), This is still within the error rate for the test (standard deviation of between .6MPG & 1.1 MPG).
The benefit is even better if I toss out set B and only use the B2 data (.62 or 1.5%) with the same SD.
Those of you who have done testing like this, what do you think? valid results or not?
Attached is the data file with both today's and yesterdays tests.
Old 08-12-2010, 03:28 PM   #35 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
That looks slick!! Get ready to roll into the World of Rubberneckers
That's pretty much what I did. Well, almost. I started at 4:30am and it turned out that was too late (too much traffic).
Old 08-12-2010, 03:31 PM   #36 (permalink)
Wiki Mod
what were the results of your testing? I only found MetroMPG results when I was looking at doing this. If you have good data, lets get both of our tests linked on the 65+ mods page! I think a moderator has to do it though
Old 08-12-2010, 03:54 PM   #37 (permalink)
aero guerrilla
Piwoslaw's Avatar
My results are in my mod thread, post #40 and post #43. I got an 8% improvement in fc @ 100 km/h (62 mph), but this was for rear skirts, Kammback, removed roof rails and folded passenger mirror. I didn't have time to test each individually I've been hoping to test again this summer, but so far each weekend has been otherwise occupied. I want the second test done at a different site (less traffic) to compare to the first, and to compare once I get a bellypan, which can't be A-B-A-B tested easily.
Old 08-12-2010, 04:23 PM   #38 (permalink)
Wiki Mod
I will have to look at how you did your kamaback, I need to see if it is worth doing on my car.
Old 08-12-2010, 04:54 PM   #39 (permalink)
Wiki Mod
Here is my cost data for the wheel skirts:
materials:
braces $8.00 bought two used one, cost is for both
screws $0.50 used some I had, but bought some to refill stock, cost is for ones used
sheet steel 0 free, had it laying around
brackets 0 free, taken off junk stuff
hinges 0 free, taken off junk stuff
Primer $5.00 Used 95% of one can
paint $14.00 bought two 8 oz cans used 1.5
clear coat $5.00 used less than half of can
Total $32.50 (only what was used = $22)
Time:
design time 2
build first bracket 2
build first skirt 2
mount and tweak first skirt 1
paint first one 0.75 (not counting dry time)
build second brace 0.5
build second skirt 1
mount and tweak second skirt 0.5
paint second one 0.75 (not counting dry time)
Total 10.5 hours
Testing:
Time:
planning 0.5
first ABA test 3.5
coast down 1.5
second ABA 2.5
Total 8 hours
Costs for testing:
gas 7 gal
cost $19.00
miles 280
So in total I have about $50 invested in skirts and testing. I also have 18.5 hours invested in making and testing them.
Testing takes a lot longer then I had thought But good data is nice to have (and share)
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
MetroMPG (08-24-2010), Varn (08-21-2010)
Old 08-21-2010, 09:06 PM   #40 (permalink)
Wiki Mod
Update: after 700+ miles on the car I have had no issues! No rubbing or loose parts!
With all my mods I have seen a 2-3 MPG gain (very conservative number).
Daox's 2003 Matrix Build Thread Daox EcoModding Central 76 01-11-2016 01:47 PM
A new best tank for the Toyota Matrix: 48 MPG Daox Success Stories 10 09-24-2010 01:47 PM
Rick's Rental Reviews: 2003-2008 Pontiac Vibe / Toyota Matrix (35.5 MPG) MetroMPG EcoModder Blog Discussion 0 06-19-2008 11:26 PM
Better Gas Mileage from my 06 Matrix thevisionseeker Hypermiling / EcoDriver's Ed 9 06-02-2008 04:11 PM
An inkling of what the Matrix is worth Daox Hypermiling / EcoDriver's Ed 12 06-02-2008 02:56 PM
