Old 07-01-2018, 03:37 AM   #51 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Most "H" or fasters speed rated tires eather have no load capacity or are 28" or smaller or10-30"wide drag rears.
To day I've found some options
32.18"D 235/55r22 (104w) 1984lbs 168mph $154 usd
31.41"D 275/25r26 (98w) 1653lbs 168mph $215 sud
30.04"D 255/50R20 (109Y) 2271lbs 186mp
From #14
http://ecomodder.com/forum/showthrea...0-a-35805.html
There is also a 32.68"D 315/35R24 w
Stock 31.7"D 235/85R16 LT S speed rating. Yielded 87.14mph 1:03279 standing mile.
What kind of impact should I expect ?
Going to a smaller speed rated tire requires installing a Bonneville specific quick change rearend for gear, just to get to 130mph @2500 RPM.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 07-01-2018, 04:31 PM   #52 (permalink)
Originally Posted by Effic1ent1
The real question is should I cover the nice new wheels with coroplast?
Needs pictures. These ones?
http://i.ebayimg.com/00/s/MTA2NlgxNj..._id=8800005007
No.
Coroplast is cheap and impermanent. If you want cheap get Moon disks and zip-tie them on. To do justice to what you have, there is a particular JDM wheel that was a spoke wheels with a dished cap that fit into between the spokes as an aerodynamic upgrade. If I remember what it's called I'll come back and edit this. You could make something similar by indexing a cap and cutting 15 notches in the rim.
Else, a center cap with left/right handed knock-offs that just hold the disk.
Old 07-01-2018, 04:36 PM   #53 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
The real question is, why not? How important are aesthetics to you?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 07-01-2018, 04:55 PM   #54 (permalink)
Effic1ent1's Avatar
MZ3 - '13 Mazda 3 i Sport
90 day: 49.47 mpg (US)
Those look like the backs.
I was just kidding really. Only on ecomodder's do you take a nice new set of alloy wheels and cover them with cheap black plastic, even if they did cost next to nothing. That being said, no I don't really care about aesthetics and I might still cover them up.
Old 07-09-2018, 09:42 AM   #55 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... I was just kidding really. Only on ecomodder's do you take a nice new set of alloy wheels and cover them with cheap black plastic, even if they did cost next to nothing. That being said, no I don't really care about aesthetics and I might still cover them up.
Hahaha! FWIW, I would not cover such rims with cheap plastic. I would sell them and buy crappy rims & good LRR tires!
Old 04-25-2024, 02:41 AM   #56 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
https://www.linkedin.com/pulse/impac...28gr75qA%3D%3D
Here some pondering. very little impact. I have calculated 0,2% savings in Tesla Model Y with 24kg less rotational mass.
Here they calculated 0,4% in the example
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 3 Users Say Thank You to Vekke For This Useful Post:
aerohead (04-29-2024), Ecky (04-25-2024), Piwoslaw (04-27-2024)
Old 04-27-2024, 10:30 AM   #57 (permalink)
Jetsin mobile - '03 Honda Insight
90 day: 64.59 mpg (US)
Vaderr - '95 Chevrolet Impala Super Sport
90 day: 17.98 mpg (US)
Karalee - '87 Pontiac Fiero GT
90 day: 30.71 mpg (US)
Bertha - '86 Jeep Cherokee Poineer
90 day: 20.37 mpg (US)
Benz - '94 Mercedez-Benz SL500 GT
90 day: 20.34 mpg (US)
Tire, rim weight
Tire weight is very important. The less weight, the quicker you vehicle can be, and the less energy or fuel will be use to get up to and maintain speed. You can search this on the web. Every seven pounds you take off your rotational mass (alloy rims, light tires, alloy axles and driveshafts) is like taking 100lbs of weight out of the car.
Imagine riding your bicycle, well then take seven pounds or more of fishing weights, and add them to your spokes. It will take a lot more effort to pedal that bike. You may not notice with your vehicle because it has so much more horse power than you, but your fuel mileage will notice it.
Tire width also is important, but you can look into that on your own. Every seven pounds you take off of your rotational mass, you will gain 1/8 of a mile per gallon. My jeep, factory rims and tires I averaged 28MPG. After I swapped out; Allow driveshafts, ultra light rims with low rolling resistant tires, I averaged 33MPG at 55MPH.
The Following User Says Thank You to catmwarrior For This Useful Post:
Old 04-28-2024, 03:52 AM   #58 (permalink)
One would also need to account for flywheel rim effect accellerating and deceleration which effects energy in and out of the system along with steady state operations
Old 04-29-2024, 11:42 AM   #59 (permalink)
' Quicker '
* With ecomodding, what's important to us is, what's the difference at an identical rate of acceleration.
* Once up to cruise velocity, energy losses during braking can actually be 'harmed' with a mass reduction, considering hybrids, plug-in hybrids, and full BEVs.
* A rather remarkable difference in all-up weight will be necessary, in order to experience ANY change to rolling resistance-related power absorption and mpg, even if BSFC is known to be constant.
Old 05-01-2024, 08:08 AM   #60 (permalink)
Throttle response changes with heavier tires, the same for lighter wheels. If you drive 400 miles (example) non stop on the hiway then there may not be an impact but over a mixed tank where your starting/stopping it does impact mpg's.
one lb off an engine pulley was enough to see the throttle response change and enough for me to go after the remaining pulleys and driveshaft.
when I did the driveshaft I lost boost rpms, meaning it was starting to come off ambient pressure at approx 1400 rpms. After the DS install it was up to 1600+ rpms. Found out the areas in the tune where timing is key for boost (diesel) were no longer being hit. Changed the slope of the timing curve and got those 200 rpms back and once seeing the cause & effect, went after more boost down low. Ended up getting boost coming off ambient pressure all the way down to 800~900 rpms. Engine is always under boost now.
With all that and then some, got my truck up into the 22+ mpg's range with a peak at 25.0x & a couple of 24's. Had that for 2~3 years then needed new tires. Unfortunately they are stickier & heavier which impacted mpg's (now in the mid 20's :-( )
Weight matters...
The Following User Says Thank You to steve05ram360 For This Useful Post:
Ecky (05-01-2024)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
