Old 01-04-2009, 07:28 PM   #41 (permalink)
Master Modifier
MD2000's Avatar
Acceleration from a stop on flat dry road, with the e-wheel is probably 30-40 seconds. It feels very long as the guy behind me is probably going to be on the horn.
Moderate Hill climbing once I am up to 30MPH is reasonable, with only a drop of 4-5 MPH.
If I had the money, I would have put in a bigger system, with a top speed of 40-45.
The controller is a Curtis that can do 400A max, but the motor life would be severely reduced, and the AGM31 batteries also would have issues, so I set the current limit at 200A.
I typically use the e-wheel when city driving, or on back roads with little traffic.
If I were to do it again, I would do it differently for sure.
Mike Dabrowski
http://www.99mpg.com/
Old 01-05-2009, 02:29 AM   #42 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.7 mpg (US)
Your vehicle only weighs in around 2k lbs doesn't it? I've done some impromptu towing with my Burgman that put me over 2k GVWR (Yeah, yeah, I know ) and I was still able to pull away faster than that at half throttle, which is ~9-10hp at the wheel, going by a dyno chart and the revs I was pulling. On flat ground no less.
But money is a sticking point, isn't it? It's basically the only reason I don't yet have electric conveyance.
Old 01-05-2009, 02:51 AM   #43 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Exactly; that's what a transmission will get you. :-)
Old 01-05-2009, 03:27 AM   #44 (permalink)
10hp at the WHEEL. That tends to make the transmission gains kinda moot.
Old 01-05-2009, 03:35 AM   #45 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Your Burgman must be sick. Suzuki claims 34hp, and the 250cc Helix puts down 13hp at the wheel.
Old 01-05-2009, 04:13 AM   #46 (permalink)
I'm guesstimating my actual output, as opposed to peak, by dyno charts, and my throttle-position vs. RPM. Peak HP in the RPM range I was in is around 13-14.
As for HP, Suzuki claims the crankshaft HP, which is substantially higher than wheel. The '07 and up has more HP than my '06 due to a larger stroke. Mine is ~30 at the crank, and peaks 19 at the rear wheel.
Either way, it's got some damn fine torque for a bike it's size. Now I just need a new drivebelt. (No, not because of my towing adventure, because I'm several thousand miles over the suggested change interval, and I haven't been nice to the belt before the towing ).
Old 04-10-2009, 08:37 PM   #47 (permalink)
China Monkey's Avatar
Red face HP what HP?
Found a hub motor but in my state ( of ignorance ) have no idea what kinda HP i would get. I'm thinking a ground up build and wish i could get an AC motor - braking gains . But found some DC that sound ok. Bulk purchase sadly but you do what you must.
Heres the Info if someone could give a newbie some hp numbers that would be great!
DC 72 V, 1500-5000w, 500 - 1000rpm
83% efficiency
on a max of 14 inch rim
Oh and its bushless
has one side shaft
Old 04-10-2009, 09:28 PM   #48 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
1 HP = 746 watts, so you have about 5.5 HP.
Yet another plug-in parallel hybrid retrofit - hub motors MetroMPG Hybrids 8 04-15-2008 07:21 PM
