Old 05-07-2013, 01:17 PM   #11 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Originally Posted by mcrews View Post
THe trick to 'coasting, engine on' is if the rpms drop to idle when in neutral.(imho)
I drove a 2009 Ford Tarus for a couple of weeks a while back and the rpms DIDNOT drop when coasting in neutral.
Fords always seem to idle stupidly high when put in neutral. I kicked my Taurus into neutral once trying to go from D to OD ... with no foot on the gas, the RPMs shot up to 3000 for no reason.
The Following User Says Thank You to Miller88 For This Useful Post:
riva2model64 (05-08-2013)
Old 05-07-2013, 07:30 PM   #12 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Engine on coasting, like everyone else said, really matters on the car and conditions of using it.
But the varied response is similar for your transmission. Look up the towing procedures, and that will direct you to the safest route- per manufacturer.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
Old 05-08-2013, 09:59 AM   #13 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Coasting in neutral shouldn't hurt the tranny unless you turn the engine off. I coast with my tranny in neutral all the time, no worries.
The Following User Says Thank You to elhigh For This Useful Post:
Old 05-08-2013, 01:32 PM   #14 (permalink)
Hydrogen > EV
How to Tow an Automatic Transmission Toyota Camry | eHow.com
Coasting in neutral may be okay, engine on, but from this write up, I would be careful. For shorter periods, and the transmission normally running, I doubt itnwouldoverheat. But I'm also not a mechanic lol
Best Tanks:
Old 05-08-2013, 01:39 PM   #15 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Help me.........do you tow with 'engine on'?????????
Does this thread talk about driving w/ 'engine off'?????????
Then PLEASE EXPLAIN the relevance.
THis pops up every time some asks about ENGINE ON COASTING IN NEUTRAL
There is NO CONECTION between the two.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 05-08-2013, 01:41 PM   #16 (permalink)
mcrews's Avatar
Please explain why information on ENGINE OFF towing is 'causing you to 'be careful' when discussing engine ON
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-08-2013, 01:43 PM   #17 (permalink)
mcrews's Avatar
FACT:
ran a 1997 Avalon w/ same engine and tranny for 210,000 miles. AND engine on coast in nuetral ALOT. Never had a problem.
Infiniti Q45 274,000 same.
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-08-2013, 02:05 PM   #18 (permalink)
Cam - '94 Toyota Camry LE
Thanks for the knowledge everyone!
It seems as if coasting in neutral on a modern automatic is ok as long as the engine is on (mccrews personal experience attests to this). And coasting with the drive wheels moving with the engine off is not ok.
According to this article (blog?) from popular mechanics : Coasting in Neutral or Gear to Save Gas - Coasting and Fuel Economy - Popular Mechanics
coasting in neutral on an auto doesn't save gas. To be fair, this article is probably not a scientific quality, peer-reviewed study, and the writer seems to be a bit biased, but the logic seems to make sense. The argument of the writer seems to be that when a modern car coasts, the fuel injectors are off, so you are only experience engine resistance. When you shift into neutral, the fuel injectors turn back on to keep the engine in idle.
Interesting argument, but the issue with the article is that the 1 gph figure seems a tad high and the writer also didn't release the testing data.
With that in mind, I have another question
If you're parked in your driveway, and you want to move your car 10ft, is it ok to simply put the parking brake off, switch in in neutral and push it out of the way? Or is it better to to move it the normal way (turning it on and and reversing out)?
Old 05-08-2013, 02:27 PM   #19 (permalink)
90 day: 51.82 mpg (US)
Moving the car 10 feet is fine. But, again, realize you will not have power steering or power brakes (if the car has been off for some time) should you need them.
And the problem with that Popular Mechanics article is that it tries to come up with a hard and fast "rule" on the topic. But the subject is more nuanced than that. Sometimes coasting in gear is better, sometimes coasting in neutral is more efficient. It's further complicated by differences between vehicles. There are lots of threads on the subject - try the search box top left of the page.
Old 05-08-2013, 05:58 PM   #20 (permalink)
Hydrogen > EV
I was thinking key in the on position, not thinking about the engine being on. My mistake, this thread is lasting longer than my memory of first reading through.
Best Tanks:
