Old 08-23-2021, 09:53 AM   #21 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Check engine light saying things are broken that don't even exist? Sounds like normal VW features.
I think that it is referring to the accelerator pedal position sensor. Unfortunately that means I need to replace the whole pedal assembly, which costs like $140.
Old 08-23-2021, 08:52 PM   #22 (permalink)
Originally Posted by Autobahnschleicher View Post
(unlike a certain version of VAGs 1.4L gasoiline engine)
I didn't see so many people complaining about this engine, even though it's not so popular in my country or in regional export markets.
Old 08-26-2021, 06:00 PM   #23 (permalink)
Nice. I started out with a 79 Rabbit diesel many years ago. The newer VWs seem to have more electrical problems, but the drivetrains are generally stout.
Old 08-28-2021, 07:38 PM   #24 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Taylor95 View Post
Supposedly the ones with the ALH engine (99-03) are considered the best.
My friend has a on 03 Jetta with 300,000 miles on it and it is still running strong. He has chased small electrical problems, the PC boards on the doors are problematical he has had some trouble with the trunk and fuel door.
Welcome to the TDI club.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 08-28-2021, 08:06 PM   #25 (permalink)
I've got a 1979 Dasher diesel parked out front right now with an electrical problem. The oil pressure indicator light has failed. It's an LED on a PCB. If it were a Beetle, that would have been fixed long ago.
You can't be wise and in love at the same time. -- Bob Dylan
Old 08-30-2021, 12:00 AM   #26 (permalink)
It is funny that you mention that, because mine has problems with the trunk opening as well as the door locks. Oh well. I have not been able to drive it yet since bringing it home because I am still working on it... waiting on a new turbo from Kerma TDI.
Old 09-07-2021, 11:12 PM   #27 (permalink)
I am very close to having the TDI all done. It actually would be done by now, but I lost an important bolt somewhere in the engine bay...
If anyone is curious, this is what I have replaced thus far:
Turbo
Thermostat
Ball joint
Coolant temp sensor
Accelerator position pedal sensor
ATF and filter
I have also done some aero mods including a side skirt and grill block! I will post some pictures tomorrow.
The Following 2 Users Say Thank You to Taylor95 For This Useful Post:
COcyclist (09-08-2021), freebeard (09-08-2021)
Old 09-08-2021, 05:14 PM   #28 (permalink)
What happened to the turbo leading you to get a replacement one?
skyking (09-17-2021)
Old 09-08-2021, 06:15 PM   #29 (permalink)
I had a check engine code for overboost, and it was pretty dirty. There was oil in some of the boost piping so I figured that wasnt good. Plus at 275k miles I figured a new one wouldnt hurt.
Old 09-09-2021, 04:16 PM   #30 (permalink)
Much better than taking the risk of an engine runaway. BTW did you use a stock turbo or an aftermarket one?
