08-18-2021, 07:18 PM
#11 (permalink)
Following! TDIs are an area I have little experience.
08-18-2021, 08:41 PM
#12 (permalink)
I haven't seen a pre-facelift Jetta of that generation for a while. Even the last TDI I saw had the facelift.
08-18-2021, 11:40 PM
#13 (permalink)
Interesting observation. Supposedly the ones with the ALH engine (99-03) are considered the best.
08-19-2021, 06:35 PM
#14 (permalink)
Was the DPF introduced there around 2004?
08-19-2021, 10:33 PM
#15 (permalink)
I am still learning a lot about my car but I believe so. My 2003 does not have a DPF.
08-20-2021, 08:30 AM
#16 (permalink)
I suggest the TDI forum for proper care and feeding. https://forums.tdiclub.com/index.php
08-20-2021, 12:12 PM
#17 (permalink)
The TDI forum has proven to have a wealth of information on all sorts of topics. It is pretty great.
The last few days have been pretty productive. I am making progress on eliminating all the check engine lights. I have changed the oil and I am waiting on the transmission filter, which will hopefully fix P0811, which is excessive clutch slippage. I am not sure what exactly tripped that, since that code should be exclusive to manuals.
Today I should finish up replacing the thermostat and temp sensor, which should resolve P0118 and P0228. I will also be taking the intake apart for P0401 and clean the EGR valve, which should (hopefully) fix that issue; it is pretty dirty.
After all that I still have P0234 (overboost) and a code for the TPS. The car does not have a TPS as far as I am aware and I haven't noticed any related problems when I drove the car home. Input on these are welcome.
The Following User Says Thank You to Taylor95 For This Useful Post:
08-21-2021, 09:45 PM
#18 (permalink)
No DPF, no problem
08-23-2021, 08:12 AM
#19 (permalink)
Check engine light saying things are broken that don't even exist? Sounds like normal VW features.
08-23-2021, 08:26 AM
#20 (permalink)
Originally Posted by redpoint5
My friend burned through 3 VW diesel engines. I don't think any were TDI though.
Not sure if he's got bad luck, or creates it. He's also burned up a Ford Ranger engine (started a small fire when we popped the hood).
I think your friend just has a tendency to kill engines.
TDi engines may have had issues with emissions, but reliabaility hasn't realy been an issue from what I have heared.
(unlike a certain version of VAGs 1.4L gasoiline engine)
