Old 12-08-2019, 09:25 PM   #31 (permalink)
The passenger airbag can be switched of.
I wonder would this help in any way with removing the passenger seat.
Not sure what to do with the seat occupancy sensor. It is certainly very sensitive as I find that objects of no more than 1 kg sitting on the seat will trigger the seatbelt warnings.
Old 12-09-2019, 07:38 PM   #32 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
So don't mount it somewhere on the driver's seat frame where it won't be moved by someone sitting there.
Transmission type Efficiency
Old 12-10-2019, 05:38 PM   #33 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
It's some kind of a weight sensor, in the foam part of the seat cushion. One of the Mirage forum members accidentally ruined his when shampooing the seat. It got a tad too damp.
Old 12-10-2019, 05:50 PM   #34 (permalink)
never-before tried mod...
I've never made or tested side skirts before. But I was emboldened by GM's 'Vette patent:
Thread: GM aero patents (includes active side skirts for drag reduction)
The patent describes drag reduction in terms of shielding the rear tires (which, in the case of the Vette are probably 3 or 4 times wider than the Mirage's!).
The 14-15 Mirage didn't even get spats ahead of the rear tires. So hopefully this helps instead of hurting, because I won't be doing any A-B-A testing before April or May at the earliest!
I also like that the rocker skirt gives me options for integrating the rear wheel skirt -- could extend the wheel skirt lower and fair them together.
Also, while the middle of the Mirage underbody is relatively smooth (it has 2 OEM plastic aero panels), the rear underbody looks like a bit of a disaster. The side skirts should mean reduced flow there.
Next up: re-do the Kammback & air dam in coroplast.
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
Daox (12-10-2019), Gasoline Fumes (12-11-2019), mpg_numbers_guy (12-11-2019), Xist (12-10-2019)
Old 12-10-2019, 07:08 PM   #35 (permalink)
Looks pretty good!
How did you attach them to the body?
Old 12-11-2019, 08:12 PM   #36 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 62.22 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Lookin' really good!
Maybe even mini boat tails behind the rear wheels, also integrated?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 12-11-2019, 09:12 PM   #37 (permalink)
Yeah, lots to do on this fuel-sucking pig!
I just drove it 80 km on wet/icy/slushy roads after a blizzard. Blasted more than a few snuds with the cardboard air dam -- I was surprised it was still intact when I got to my destination!
Computer said 58 mpg, which we know is probably ~5% optimistic. But that was into a quartering headwind, so not too bad.
Old 12-11-2019, 09:28 PM   #38 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Based on my lazy tuft testing, the side skirts seemed to prevent some air from going under the the Nut Wagon.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MetroMPG (12-11-2019)
Old 12-11-2019, 09:31 PM   #39 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Ran out of black cable ties for the wheel covers?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-11-2019, 09:35 PM   #40 (permalink)
Tuft testing is awesome.
White zip ties - I actually did that on purpose. I thought it might look interesting. Turns out I'm not crazy about it either.
