Old 04-23-2013, 03:49 PM   #41 (permalink)
Eco Sol
Shortie771's Avatar
Sorry for the long delay on updates, I have been busier than normal. The idea involving coating the hangers in glue was unsuccessful, so what I did to remedy the sagging problem was went to Lowes and picked up two 3' long, 1/16" thick (maybe they were 1/8") steel rods and used them as the center support which runs all the way through the coroplast. The rod barely fits through the coroplast (it really helps to rub bar soap on the rods to get them through). It fixed the sagging and is MUCH stronger now, I used some the the bits of the rod, I had to cut off with a dremel as the counter weights on the back. I have also painted the grill block black and it is hardly noticeable. Some pics of the final product are attached.
ID:	12964   Click image for larger version
ID:	12965   Click image for larger version
ID:	12966   Click image for larger version
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following User Says Thank You to Shortie771 For This Useful Post:
Pawtuckett (06-06-2013)
Old 04-23-2013, 04:01 PM   #42 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Looks good. Notice any MPG increase?
Old 04-23-2013, 04:19 PM   #43 (permalink)
Eco Sol
Shortie771's Avatar
Haven't been able to accurately calculate any gains yet, since I am going on a tank to tank basis. Plus I just recently installed a kill switch, which will probably muck up the numbers. What I plan to do when I get some time is do a coast test with the grill block propped open and then another test with it closed to calculate the difference in Cd, since I can't accurately do any A-B-A testing without having a MPGuino installed yet.
CR-Z Current Mods:
Max Sidewall PSI
Old 04-23-2013, 04:33 PM   #44 (permalink)
EcoOdy - '07 Honda Odyssey EX-L
90 day: 20.52 mpg (US)
slick - '95 honda civic lx
Last 3: 26.46 mpg (US)
Thanks, This is really good!
Old 04-23-2013, 04:49 PM   #45 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Looks great! Good job.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-24-2013, 08:21 AM   #46 (permalink)
Eco Sol
Shortie771's Avatar
Originally Posted by Phantom View Post
One thing you should check is how the grill works with the fans running at full speed. You do not want to be stuck in 5mph traffic then have the fans turn on pulling the grill shut.
I put a jumper on the fan control switch to turn it on and it does not effect the opening/closing of the grill block at all Thanks for the suggestion, it would be pretty bad to be in bumper to bumper traffic and have my fans kick on and only make things worse.
CR-Z Current Mods:
Max Sidewall PSI
Old 05-28-2013, 01:42 AM   #47 (permalink)
Eco Sol
Shortie771's Avatar
Just got my MPGuino, still have to install it. Once I get it all set up I will be doing some A-B-A testing to figure out exactly what this grill block is getting me This will be the first time I will actually be able to do any testing, I'm excited. I will be testing on a section of flat road with my cruise control set to 60mph and will not turn the car off between tests, so that I can use the resume function for better accuracy. I will also be sure to do record temperature and wind speed, along with direction at the time of testing. I will also be sure to perform all tests traveling in the same direction each time.
The test will be:
A - 60mph - grill block propped open.
B - 60mph - grill block able to close on it's own.
Am I missing anything?
CR-Z Current Mods:
Max Sidewall PSI
Old 05-28-2013, 03:04 AM   #48 (permalink)
AndrzejM's Avatar
Can't wait to see the numbers. Good luck with ABA
Old 05-29-2013, 01:19 PM   #49 (permalink)
Eco Sol
Shortie771's Avatar
Woohoo made it to the top picks list!! Not sure how that list works, but I'm on it
CR-Z Current Mods:
Max Sidewall PSI
Old 06-02-2013, 04:07 AM   #50 (permalink)
Eco Sol
Shortie771's Avatar
Got my MPGuino installed today and it's working great. After a few tanks of calibration to ensure I get accurate numbers, I will do some A-B-A testing.
Does it matter if it's calibrated correctly yet? Wouldn't it still add up to be the same percentage difference?
CR-Z Current Mods:
Max Sidewall PSI
