11-21-2020, 01:03 PM
#3661 (permalink)
11-21-2020, 03:02 PM
#3662 (permalink)
April 10, 2019
Tesla Semi-like aerodynamic trucks will be mandated in Europe to make roads safer
https://www.teslarati.com/tesla-semi...europe-safety/
11-22-2020, 01:47 AM
#3663 (permalink)
Ultimate Fail
YKYAEM when you see that last picture posted of the Tesla semi and cringe.
( Just look at the area just behind the cab leading to the trailer.The semi may be streamlined, but it's not going to help much if you have the air smashing into the brick behind it ! )
The Following User Says Thank You to Cd For This Useful Post:
11-24-2020, 04:36 PM
#3665 (permalink)
11-24-2020, 04:59 PM
#3666 (permalink)
I liked the lattice vault roof. It reminds me of Félix Candela.
https://simplypetrol.com/15-best-car...orth-visiting/
I have a 1/25 scale Beetle with the two-tone paint from the Bugatti Royale (and no camera ), it's the same except the hood frunk is two-toned.
11-25-2020, 08:56 AM
#3667 (permalink)
Candela seems to be akin to Frei Otto but with concrete.
In all of the college credits I took in architecture school, only one class an elective dealt with 20th Century architecture. There was this massive hole between the historic and the current that was neglected, one had to seek this information out on their own.
If an architect's work wasn't on the "approved list" of must know, then somehow it just didn't matter it sort of seemed like. Very few winners, usually European or North American. I felt it was a cultural bias, a sort of discrimination.
Great list of automobile museums, I have to make it out to a couple of them one day.
11-25-2020, 11:59 AM
#3668 (permalink)
There's also Robert Maillart.
Robert Maillart
Robert Maillart was a Swiss civil engineer who revolutionized the use of structural reinforced concrete with such designs as the three-hinged arch and the deck-stiffened arch for bridges, and the beamless floor slab and mushroom ceiling for industrial buildings.Wikipedia
11-25-2020, 02:10 PM
#3669 (permalink)
Equal to +9,500 MPG?
Video: 2016
Under the Hood of the Fastest Bike in the World
2014
Eta's aerodynamic design
Eta's aerodynamic design — Aerovelo
From a forum post:
http://www.recumbents.com/forums/top...13&whichpage=8
At a wind speed of about 80 mph it only generates 6.25 Newtons of drag, which comes out to a Cd of .023. The bike has a frontal area of .34435 m^2.
I believe the Cda you have for Eta, maybe wrong. I first get this idea because one the Team Policumbent website they state "Considering a speed of 145 kph, air density of 1.18 kg/m3 and a frontal area of 0.284 m2, we get a Cd of 0.0218".
All of a sudden my numbers don't seem as unreasonable.
I also did some calulations for the Cda of based off a statistic that I found in an article which stated that Eta would only need 198 watts to go 90 kph. This would require (using a Crr of .005 and a bike weight of 6o lb and a air density of 1.22kg/m^3) a Cda value of about .007 @ 90 kph which is far lower than the cda of my design. of course this value would decrease a higher speeds.
Of course simulations do not provide a 100% accurate portrayal of the real world but can certainly help for analyzing trends from iteration to iteration.
So to sum up, I believe the Cda value of Eta is a lot lower that what you have listed. This not only would make sense based off my findings, but the results of Team Policumbents Taurus speed bike which give a Cda of .0061912, and as we know, they don't hold the world record at this time, so it may be a safe assumption to say that Eta is more aerodynamic.
2015
the fastest human on earth
https://tingilinde.typepad.com/oment...-on-earth.html
A person on a bike isn't the most aerodynamic object. The equation I derived is sensitive to the area of the air column you travel through. This turns out to the the cross section frontal area of the moving object times a coefficient of drag - a term that depends strongly on the shape of the object. A Tour de France racer in a racing tuck has a coefficient of drag, a Cd, of about 0.7 and presents a cross section of about 0.5 square meters to the wind. Someone riding a casual commuter bike has a larger Cd and cross sectional area. They effectively travel through a larger tube of air, but at a much lower speed.
Velomobiles are streamlined bicycles. They're rarely seen in the US - perhaps a few thousand have been made and mostly in Germany and the Netherlands. Commercial models have frontal areas similar to that of a cyclist, but the Cd is usually in the 0.1 to 0.15 range - tiny by the standard of even the most aerodynamic cars.2 Even though they're larger and heavier than a regular bicycle, it is relatively easy for a normal rider to cruise along at 25 mph.
The Aerovelo Eta Todd Reichert piloted is the part of a serious engineering project involving some University of Toronto people. The Eta's frontal area is 0.35 m2 and its Cd is an astounding 0.038. A bit of calculating shows the Eta should be nearly three times as fast as a Tour de France road bike at speed with the same power input.3
To put this in context, this bike is about as fast as the fastest hovercraft on record.
I don't know why so much dispute about it's Cd, and why it isn't clearly listed on their website.
EDIT
This one looks road ready, and it leans.
The Fastest Bike in the World
Velox4 streamliner
https://www.recumbent.news/2015/01/0...-in-the-world/
https://www.reddit.com/r/BicycleEngi..._these_things/
http://wimschermer.blogspot.com/2014...on-2014-2.html
11-25-2020, 02:44 PM
#3670 (permalink)
Freebeard may like this one.
Facet V1 Velomobile
https://www.instructables.com/Facet-V1-Velomobile/
The Facet V1 is made almost entirely out of Coroplast, the same corrugated plastic that many election signs are made from. The plastic shell is wrapped around a Catrike Expedition recumbent trike.
https://www.pinterest.com/pin/549157748289835610/
