Old 01-28-2019, 04:56 PM   #1 (permalink)
AdrianD's Avatar
Jeep Aero mods testing - with results
Hello everyone!
With very limited time I managed to get some testing done on my Jeep. My scan tool displays and logs a ton of ECU parameters and I chose actual injection quantity and mass air flow. Instant MPG resolution is 1L/100km, which is not exactly accurate
Control test was done with this lip installed:
Mod #2 was installing front tire deflectors:
Mod #3 was installing a big plastic panel over the lower grille
The test was done on the flattest stretch of road I could find, in a, luckily, free of traffic interval and I've removed from the data log entries when I was accelerating or coasting. Speed was set with cruise control to 60mph.
Control test (only lip):
Average injection quantity: 21.40 mg/stroke
Average MAF: 619.4 mg/s
Front tire deflectors:
Average injection quantity: 21.48 mg/stroke (0.37% worse)
Average MAF: 617.0 mg/s (0.38% better)
Front tire deflectors and lower grille block:
Average injection quantity: 20.89 mg/stroke (2.4% better)
Average MAF: 610.2 mg/s (1.49% better)
It's a short stretch of road, 4.5 miles total.
Just looking at the instant MPG, I was in the 6L/100km range three times with the front tire deflectors and the lower grille block, while during the other tests I was in that range only once.
Thoughts? Should I still keep the front tire deflectors?
I have the panels for blocking the upper grille ready, I just did not have time to install them today when testing.
Old 01-28-2019, 05:51 PM   #2 (permalink)
I'd say insufficient sample. Results < 1% are down in the noise. How many passes for each of the three scenarios? Did you control for temperatures and wind speed/direction?
The deflector [apparently] leaves 2" of the tires tread exposed.
"We're deeply sorry." -- Pfizer
Old 01-28-2019, 06:26 PM   #3 (permalink)
Keep it on, it looks cool.
Tell us more about the material used.
Is there anyway you can make it more of a gentle radius verses a 90 degree bend?
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 01-28-2019, 06:49 PM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Testing is nice, but frankly we have a pretty good archive to know what works based on previous user experience.
If you can't reliably test fuel economy, use coast down tests. If you notice more speed at the bottom of a hill you always drive, then your mod is working. I've always found that this is noticeable in the airdams I've done.
I've also found there's a lot less noise coming up from under the floor.
The actual fuel savings are harder to measure, but if it does the above then it's got to be helping.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Fat Charlie (01-29-2019)
Old 01-28-2019, 10:03 PM   #5 (permalink)
Please post bigger pics next time. Thanx
Old 01-29-2019, 01:35 AM   #6 (permalink)
AdrianD's Avatar
4.5 miles was round-trip, between 2 roundabouts. All tests done in the span of 30 minutes.
Almost 2 inches of the tire was exposed, it's less now with the new tires. Image updated in the first post.
I agree on the archive part, I've went through a lot of topics with aero mod results but nothing for a Jeep and all the trucks I could see had the wheels more tucked in.
The airdam worked, I'm sure of that, I've went through a few fuel tanks with it installed.
As for coastdown, the hills around here are all twisty or have a 30mph speed limit at the bottom
Heck, I even edited the current ones to comply
Thanks!
It's some 3 mm plastic board from a local home improvement shop. Soft surface, bendy when heated up but brittle when cold.
I've tried a soft bend on the grille block, couldn't do it, maybe I need to heat it up differently, a heat gun is too focused.
The Following 2 Users Say Thank You to AdrianD For This Useful Post:
freebeard (01-29-2019), RedDevil (01-29-2019)
Old 01-29-2019, 10:53 AM   #7 (permalink)
Originally Posted by AdrianD View Post
Thanks!
Is this a plastic laminated foam core board?
Please post a close up photo of an edge or provide a link to the material.
In my experience, chin spoilers greatly enhance stability in cross winds, and that reason alone makes them worth doing.
Chin Spoiler:
Roof Wing
Old 01-29-2019, 12:09 PM   #8 (permalink)
AdrianD's Avatar
The results here are all only with the chin spoiler:
https://ecomodder.com/forum/showthre...l-35650-2.html
It's homogeneous in structure, I'll try to find the sticker on the board to get more info.
Old 01-29-2019, 12:28 PM   #9 (permalink)
Looks like ABS plastic not PVC plastic, but I'm far from being sure about it.
ABS is stiffer and lighter than PVC if I recall correctly.
Plus ABS is typically black, and PVC typically white.
However, ABS is typically much stiffer and less prone to bending than fresh PVC.
Chin Spoiler:
Roof Wing
Old 01-31-2019, 01:52 PM   #10 (permalink)
AdrianD's Avatar
It's in different colors, even yellow. Sticker not found, I will get it next time I go to the home improvement shop
Anyway, here is the upper grille block:
I set off to Austria for the yearly skiing holiday and used only 3 out of 5 blocking plates out of fear of overheating. When giving it the beans uphill, the water temperature went up a few degrees. Going steady uphill on the highway, no problems what-so-ever.
Running all 5 blocking plates here but it still takes about 5 miles to get up to full temperature.
Over the usual test section of highway (600 km) the trip computer showed 35.1 MPG and the calculated fuel consumption was 31.65 MPG. Exact same as the summer fuel consumption and 3 years ago when I had snow tires and just the chin spoiler. Traffic however was not the same, lots of trucks to pass, and passing on the highway in Europe means going 70-80mph. I'm pretty happy given that. Trip computer shows 28 MPG going 75mph, which is awesome.
The lower corners of the tire deflectors are now rounded off...I guess they are not stiff enough to maintain their position going 80mph.
The whole chin spoiler was wet from road spray all the way until the bend in the deflectors. Does that mean that the bend is too sharp?
On the return trip there should be less traffic.
The Following User Says Thank You to AdrianD For This Useful Post:
BamZipPow (02-11-2019)
