Old 01-28-2010, 05:43 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
kill switch 5th gen honda civic
For this one you need a normally closed push to open switch. I found a brake light switch at napa 10 bucks. Some wire, 18 gauge should be fine one male and 3 female spade connectors.
find the fuel injector relay under the dash to the left. It is a gray box as shown in the image. unplug the connector and then pull out the white wire holder in the back of the connector. A small flat head screwdriver applied to the ends where the white tabs show will free it. There is a black wire in the corner this is the ground, pull it out.
Run your length of wire, doubled, from where your switch will be to the relay. Two female spade connectors at the switch end.
Strip the insulation off one of the female spade connectors connect to one wire for the switch and place it in the connector where you pulled the black wire out, then replace the white wire holder.
Put the male spade connector on the other wire and plug it into the female connector on the black ground wire(s).
Secure your wires and attach the switch, all done.
Motor dies quickly you know it is dead when the red battery light comes on, restarts instantly with pop of clutch or turn of key. When you press the button the check engine light comes on then goes back off when you let go of the switch.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following 10 Users Say Thank You to bestclimb For This Useful Post:
Bugzilla (07-26-2013), christofoo (06-05-2013), fifteenwindow (07-04-2013), j12piprius (03-11-2011), jedi_sol (07-14-2010), myrefugeisintheLord (12-17-2012), NachtRitter (07-15-2010), PaleMelanesian (09-29-2010), pletby (07-16-2012), WD40 (10-14-2010)
Old 07-14-2010, 08:07 PM   #2 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Basically this.
Name:	Fuel Injector Kill switch.jpg
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following 3 Users Say Thank You to jedi_sol For This Useful Post:
j12piprius (11-05-2014), NachtRitter (07-15-2010), PaleMelanesian (09-29-2010)
Old 09-29-2010, 03:44 PM   #3 (permalink)
Civicsedan - '94 Honda Civic EX
90 day: 42.23 mpg (US)
Does this mod kill the speedo and tach as well? or only the injectors?
Old 09-29-2010, 04:48 PM   #4 (permalink)
Smeghead
The tach drops too zero quicker than the motor spins down but the speedo and odometrers are not inturupted.
Old 10-14-2010, 11:44 AM   #5 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I like the simplicity of this, very easy implement and to reverse
Has anyone else tried this and can confirm no issues or side effects.
thanks
Dennis
2000 Insight MT 106K Citrus A/C
Old 10-14-2010, 04:02 PM   #6 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Running this setup for 6 months now with no side effects so far.
Old 03-11-2011, 06:18 PM   #7 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Still no side effects?
It kills all injectors !
Old 03-11-2011, 08:45 PM   #8 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
How did you connect this to the dash?
Do you have any more photos? Thanks
Old 03-11-2011, 11:48 PM   #9 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
11 months so far, still no side effects. This particular setup is essentially the same as turning your ignition key in the "off" position, instantly shutting off the injectors. The nice thing about this setup is that it does not wear out your ignition key.
My old setup was a switch that cut off the fuel pump only, but it was not as effective because the fuel pump would still run for about 7 seconds before it completely shut off, thus squirting bits of unburnt fuel into the combustion chamber.
The Following User Says Thank You to jedi_sol For This Useful Post:
j12piprius (03-12-2011)
Old 03-11-2011, 11:49 PM   #10 (permalink)
Smeghead
The electrical connection is made to the car under the dash at the far left side of the car a small gray box labeled PGM FI. I ran the wires up under the dash with zip-ties to what ever, then to my shifter. I made a bracket out of aluminum to mount the switch to.
I have been running this set up for nearly a year. The car had 250,000 plus miles on it prior to me getting it, now it has at least 260000+ no side effects as far as I can see.
The Following 2 Users Say Thank You to bestclimb For This Useful Post:
j12piprius (03-12-2011), jedi_sol (03-11-2011)
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
Honda Civic 5th gen and 6th gen jennyfurwhen Off-Topic Tech 15 10-01-2009 12:44 AM
FS: Carbon Fiber Hatch for 5th Gen Civic trikkonceptz For Sale 8 06-04-2008 04:40 AM
