09-26-2021, 11:31 PM
#21 (permalink)
A good article but the pictures won't embed.
www.evconvert.com/article/ev-pusher
.tragectory: Line goes down and to the right.
09-26-2021, 11:37 PM
#22 (permalink)
home of the odd vehicles
Originally Posted by Isaac Zachary
I almost convinced myself to make a diesel pusher for my Leaf out of the 1985 non-turbo VW Golf I had. The idea was to cut the front off from the cabin and make it a trailer.
Others have done similar , the IMIEV forum one is most famous
https://insideevs.com/news/325682/mi...ange-extender/
VW EV Pusher trailers have a long history going back into the 1970’s
Pushers are a much better use case than running a portable genset to “charge”
My view has always been that anything that allows you to better use your car is good if that’s a pusher go for it.
A proper commercial “pusher” would allow owners to continue using old tired “leaves” that no longer have enough battery capacity for daily use.
The trouble I’ve seen is you have a lot of purists who have zero tolerance for fuel burners, especially those from Europe they have no comprehension, or views of fair play , sadly that mentality seems to be present amongst most everyone these days.
09-27-2021, 01:35 AM
#23 (permalink)
I have seen that EV pusher. I don't think I need an entire vehicle sized engine and drive line.
I'm going to try to keep it single wheeled, gokart drive line based.
And I don't believe in destroying an air cooled VW body to make a pusher.
The other problem with using a vehicle based push trailer is the authoritarian enthusiasts may think that it needs to at least be registered as a trailer or possibly as a vehicle. No one should see a single wheeled pusher thing and be like that needs to be registered as a trailer.
I don't think battery powered pushers make any sense to privately own. If you need a pusher that much buy a plug in hybrid, if the battery trailer sits for weeks at a time the battery is still deteriorating. And for best storage life you should keep a lithium ion battery around 1/3 to 1/2 charge, so you can't keep it ready to go.
As something you could rent yeah.
(some one always brings up battery powered pushers)
09-27-2021, 02:10 AM
#24 (permalink)
Good on you. I was distracted by #22, when it said Golf. Maybe this is more to the point:
Ignore the bike rack and cardboard box. The swiveling wheel would store as such. Perhaps your requirement would be filled by something similar?
09-27-2021, 02:38 AM
#25 (permalink)
High Altitude Hybrid
09-27-2021, 03:00 AM
#26 (permalink)
I want my leaf pusher to be small enough to be thrown in the back hatch. If I ever make a 22hp or 35hp version then probably not so much.
09-27-2021, 05:42 AM
#27 (permalink)
It looks like the rhb31 turbo I put on my kubota tractor can be spooled up by a lowly 200cc diesel engine.
Just imagine a leaf pusher rolling this much coal, the hate would be epic.
09-27-2021, 10:47 AM
#28 (permalink)
No one should see a single wheeled pusher thing and be like that needs to be registered as a trailer. )
Don’t disagree, many VW pushers came “pre-wrecked” hence why they became pushers
09-27-2021, 01:40 PM
#29 (permalink)
I've known people who got their cars by patching two wrecks together. A short-nose Type III and a Type III Karmann Ghia. My 1957 Beetle was replaced from the A-pillars forward.
That's a hard constraint. What are the maximum weight and dimensions?
09-28-2021, 02:04 AM
#30 (permalink)
Even a wrecked motorcycle can be turned into a pusher for an EV, considering a Honda thumper around 250 to 300cc even though some workaround would be required to provide a reverse gear. Repurposing a starter motor to become an auxiliary reverse unit can get the job done.
You would really be surprised of how intolerant electric vehicle people are
I see so many virtue-signallers praising EVs just to claim some sort of moral superiority whenever anyone else points out any deficiency of EVs under some conditions.
