Old 05-23-2010, 11:11 PM   #11 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by Gasoline Fumes View Post
I'm not sure if power windows or locks were ever offered. I've never seen them on a Metro. Some 1989-1994 Suzuki Swift GTs had them, but the parts won't fit the newer Metros. All of the following applies to the "new" 1995-2001 cars. If you want MPFI, you'll have to get a Metro/Swift with the 4-cyl engine from 1998 or newer. If you want maximum fuel economy and OBDII, get a 1996+ 3-cyl Metro hatchback. There are very few options on these cars. Some had ABS. Some had a tachometer. Some had trip odometers. Metro hatchbacks were sold with both 3 & 4-cyl engines. Sedans were 4-cyl only. 3-cyl 5-spd had a 4.39 final drive, 4-cyl 5-spd had a 3.79 final drive. Automatic was only an option on the 4-cyl, avoid it. Power steering was an option on the 4-cyl sedan. Some of the '95-'97 Metros had recessed sealed beam headlights. Swifts were all 4-cylinder hatchbacks.
The "new" cars have another rust problem not found on the older models. The front section of the rear wheelwells rot out.
by far the best grouping of information I've found..
much appreciated..
how oddball is a 3cyl 5 speed with a/c?
Old 05-23-2010, 11:38 PM   #12 (permalink)
EcoModding Minded
Chris D.'s Avatar
much appreciated..
Old 05-24-2010, 01:17 PM   #13 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
much appreciated..
No problem, glad to help.
I don't know. Probably more common in some place like Florida.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 05-24-2010, 07:08 PM   #14 (permalink)
EcoModding Minded
Chris D.'s Avatar
Are there different years where it used a slave cylinder for
a hydraulic clutch vs a regular cable actuated setup?
I'm just thinking about this for my backs sake
::crosses fingers::
Old 05-24-2010, 10:25 PM   #15 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
The 1.3L 5 speed is good on gas, not quite as good as the 1.0, but if you need the extra "hamster" you have it.
A/C isn't that rare nor is it super popular, but do you really need it? Get an XFi if you can. If you can't, get the 3.79/.59 transmission, 3tech economy cam, +10 cam gear and you should be good. Lower it an inch or two, block the grille, and you should be good.
The Following User Says Thank You to MadisonMPG For This Useful Post:
Chris D. (05-25-2010)
Old 05-25-2010, 08:44 AM   #16 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
::crosses fingers::
They're all cables.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Old 05-25-2010, 07:46 PM   #17 (permalink)
EcoModding Minded
Chris D.'s Avatar
They're all cables.
thanks
I looked at a Chevy Metro listing on autozone and that vs the older Geo
cars didn't have a cable listed for replacment, absolutly all cable actuated?
I'd like a/c for the time the girlfriend is riding with me..
Humidity sucks out here in the summer time also..
Isn't the XFi an older model? older than 1996 (pre OBDII?)
If I regear it with the trans, cam and cam gear, will it be less powerfull or more torquey?
I'd be thrilled to death just to have a 35mpg combined vehicle..
Old 05-27-2010, 12:02 AM   #18 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
thanks
I think there was a 1.6L Suzuki Swift sold in Canada that had a hydraulic clutch, but all 1.0/1.3 cars had a clutch cable.
XFi was only in the older body style.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-27-2010, 12:53 AM   #19 (permalink)
Metro XFI - '94 Geo Metro XFI
90 day: 66.09 mpg (US)
Well if your happy with 35 mpg then you could get any metro they all get above that. I have an XFI and the noise inside is alittle loud but worth it I can get 50mpg with the gas all the way to the floor but most of the time I drive slow and get In the 60s. The 3cylinder 5 speed is the only way to go I think if you get a 3.79 or 3.59 trans you will lose fast take off speeds but will gain probably around 10mpg. The xfi cam or the custom one from 3tech helps with mpg and low end power so if going to a taller trans I would put one in. Obd1 or obd2 these cars are very simple and easy to work on after 96 the cars were a little heavier so they lose a little mpg but not much it really just depends on what you want. Good luck shopping.
Oh and powersteering in a geo wouldn't be worth it they are light and very easy to steer
Old 05-27-2010, 02:18 AM   #20 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Dude, the Metros are lighter and easier to steer than my MK2 Golf... and I can steer that while parked from lock to lock with two fingers.
If you have trouble with manual steering racks, try adjusting the caster angle of the wheels a bit. The more caster angle, the easier to steer (less tire scrub while steering).
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
I Bought the Geo Metro!!! Wayneburg EcoModding Central 12 07-22-2010 07:17 AM
Restoring a 1989 Geo Metro IheartGeos Introductions 18 02-22-2010 02:00 AM
BMW Working on Their Answer to the Geo Metro? SVOboy EcoModder Blog Discussion 8 05-12-2009 10:33 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 11:15 PM
