Old 02-07-2017, 01:59 PM   #271 (permalink)
Dark Egg - '12 VW Touraeg
But the piston isn't really moving much 20 degrees before or after TDC and even at just 2000 rpm what fraction of a mili-second are we talking about before the piston reaches TDC? The explosion and heat expansion if started at TDC even IF the vapor system increased the explosion (which is doubtful as the energy content doesn't change) it still needs to be started just as early or it will be wasted on a less compressed air volume.
Old 02-07-2017, 02:24 PM   #272 (permalink)
OK so what is knocking??
Normal combustion
Under ideal conditions the common internal combustion engine burns the fuel/air mixture in the cylinder in an orderly and controlled fashion. The combustion is started by the spark plug some 10 to 40 crankshaft degrees prior to top dead center (TDC), depending on many factors including engine speed and load. This ignition advance allows time for the combustion process to develop peak pressure at the ideal time for maximum recovery of work from the expanding gases.[2]
The spark across the spark plug's electrodes forms a small kernel of flame approximately the size of the spark plug gap. As it grows in size, its heat output increases, which allows it to grow at an accelerating rate, expanding rapidly through the combustion chamber. This growth is due to the travel of the flame front through the combustible fuel air mix itself, and due to turbulence which rapidly stretches the burning zone into a complex of fingers of burning gas that have a much greater surface area than a simple spherical ball of flame would have. In normal combustion, this flame front moves throughout the fuel/air mixture at a rate characteristic for the particular mixture. Pressure rises smoothly to a peak, as nearly all the available fuel is consumed, (This I and others disagree with)then pressure falls as the piston descends. Maximum cylinder pressure is achieved a few crankshaft degrees after the piston passes TDC, so that the force applied on the piston (from the increasing pressure applied to the top surface of the piston) can give its hardest push precisely when the piston's speed and mechanical advantage on the crank shaft gives the best recovery of force from the expanding gases, thus maximizing torque transferred to the crank shaft.[2][3]
And again I am others disagree, maximum torque would be at where the crank is at 90 degrees where the most leverage would be applied. So the burn and power should still be present at this point...
Abnormal combustion
Main article: cool flame
When unburned fuel/air mixture beyond the boundary of the flame front is subjected to a combination of heat and pressure for a certain duration (beyond the delay period of the fuel used), detonation may occur. Detonation is characterized by an instantaneous, explosive ignition of at least one pocket of fuel/air mixture outside of the flame front. A local shockwave is created around each pocket and the cylinder pressure may rise sharply beyond its design limits.
If detonation is allowed to persist under extreme conditions or over many engine cycles, engine parts can be damaged or destroyed. The simplest deleterious effects are typically particle wear caused by moderate knocking, which may further ensue through the engine's oil system and cause wear on other parts before being trapped by the oil filter. Severe knocking can lead to catastrophic failure in the form of physical holes punched through the piston or cylinder head (i.e., rupture of the combustion chamber), either of which depressurizes the affected cylinder and introduces large metal fragments, fuel, and combustion products into the oil system. Hypereutectic pistons are known to break easily from such shock waves.[3]
Detonation can be prevented by any or all of the following techniques:
the use of a fuel with high octane rating, which increases the combustion temperature of the fuel and reduces the proclivity to detonate
enriching the air–fuel ratio which alters the chemical reactions during combustion, reduces the combustion temperature and increases the margin above detonation
reducing peak cylinder pressure
decreasing the manifold pressure by reducing the throttle opening or boost pressure
reducing the load on the engine
retarding (reduce) ignition timing
Because pressure and temperature are strongly linked, knock can also be attenuated by controlling peak combustion chamber temperatures by compression ratio reduction, exhaust gas recirculation, appropriate calibration of the engine's ignition timing schedule, and careful design of the engine's combustion chambers and cooling system as well as controlling the initial air intake temperature.
The addition of certain materials such as lead and thallium will suppress detonation extremely well when certain fuels are used.[citation needed] The addition of tetraethyllead (TEL), a soluble organolead compound added to gasoline was common until it was discontinued for reasons of toxic pollution. Lead dust added to the intake charge will also reduce knock with various hydrocarbon fuels. Manganese compounds are also used to reduce knock with petrol fuel.
Knock is less common in cold climates. As an aftermarket solution, a water injection system can be employed to reduce combustion chamber peak temperatures and thus suppress detonation. Steam (water vapor) will suppress knock even though no added cooling is supplied.
Certain chemical changes must first occur for knock to happen, hence fuels with certain structures tend to knock easier than others. Branched chain paraffins tend to resist knock while straight chain paraffins knock easily. It has been theorized[citation needed] that lead, steam, and the like interfere with some of the various oxidative changes that occur during combustion and hence the reduction in knock.
Turbulence, as stated, has very important effect on knock. Engines with good turbulence tend to knock less than engines with poor turbulence. Turbulence occurs not only while the engine is inhaling but also when the mixture is compressed and burned. During compression/expansion "squish" turbulence is used to violently mix the air/fuel together as it is ignited and burned which reduces knock greatly by speeding up burning and cooling the unburnt mixture. One example of this is all modern side valve or flathead engines. A considerable portion of the head space is made to come in close proximity of the piston crown, making for much turbulence near TDC. In the early days of side valve heads this was not done and a much lower compression ratio had to be used for any given fuel. Also such engines were sensitive to ignition advance and had less power.[3]
Knocking is more or less unavoidable in diesel engines, where fuel is injected into highly compressed air towards the end of the compression stroke. There is a short lag between the fuel being injected and combustion starting. By this time there is already a quantity of fuel in the combustion chamber which will ignite first in areas of greater oxygen density prior to the combustion of the complete charge. This sudden increase in pressure and temperature causes the distinctive diesel 'knock' or 'clatter', some of which must be allowed for in the engine design.
Careful design of the injector pump, fuel injector, combustion chamber, piston crown and cylinder head can reduce knocking greatly, and modern engines using electronic common rail injection have very low levels of knock. Engines using indirect injection generally have lower levels of knock than direct injection engine, due to the greater dispersal of oxygen in the combustion chamber and lower injection pressures providing a more complete mixing of fuel and air. Diesels actually do not suffer exactly the same "knock" as gasoline engines since the cause is known to be only the very fast rate of pressure rise, not unstable combustion. Diesel fuels are actually very prone to knock in gasoline engines but in the diesel engine there is no time for knock to occur because the fuel is only oxidized during the expansion cycle. In the gasoline engine the fuel is slowly oxidizing all the time while it is being compressed before the spark. This allows for changes to occur in the structure/makeup of the molecules before the very critical period of high temp/pressure.[3]
An unconventional engine that makes use of detonation to improve efficiency and decrease pollutants is the Bourke engine.
Pre-ignition
Pre-ignition (or preignition) in a spark-ignition engine is a technically different phenomenon from engine knocking, and describes the event wherein the air/fuel mixture in the cylinder ignites before the spark plug fires. Pre-ignition is initiated by an ignition source other than the spark, such as hot spots in the combustion chamber, a spark plug that runs too hot for the application, or carbonaceous deposits in the combustion chamber heated to incandescence by previous engine combustion events.
The phenomenon is also referred to as 'after-run', or 'run-on' or sometimes dieseling, when it causes the engine to carry on running after the ignition is shut off. This effect is more readily achieved on carbureted gasoline engines, because the fuel supply to the carburetor is typically regulated by a passive mechanical float valve and fuel delivery can feasibly continue until fuel line pressure has been relieved, provided the fuel can be somehow drawn past the throttle plate. The occurrence is rare in modern engines with throttle-body or electronic fuel injection, because the injectors will not be permitted to continue delivering fuel after the engine is shut off, and any occurrence may indicate the presence of a leaking (failed) injector.[4]
In the case of highly supercharged or high compression multi-cylinder engines, particularly ones that use methanol (or other fuels prone to pre-ignition), pre-ignition can quickly melt or burn pistons since the power generated by other still functioning pistons will force the overheated ones along no matter how early the mix pre-ignites.[dubious – discuss] Many engines have suffered such failure where improper fuel delivery is present. Often one injector may clog while the others carry on normally allowing mild detonation in one cylinder that leads to serious detonation, then pre-ignition.[5]
The challenges associated with pre-ignition have increased in recent years with the development of highly boosted and "downspeeded" spark ignition engines. The reduced engine speeds allow more time for autoignition chemistry to complete thus promoting the possibility of pre-ignition and so called "mega-knock". Under these circumstances, there is still significant debate as to the sources of the pre-ignition event.[6]
Pre-ignition and engine knock both sharply increase combustion chamber temperatures. Consequently, either effect increases the likelihood of the other effect occurring, and both can produce similar effects from the operator's perspective, such as rough engine operation or loss of performance due to operational intervention by a powertrain-management computer. For reasons like these, a person not familiarized with the distinction might describe one by the name of the other. Given proper combustion chamber design, pre-ignition can generally be eliminated by proper spark plug selection, proper fuel/air mixture adjustment, and periodic cleaning of the combustion chambers.[2]
Causes of pre-ignition
Causes of pre-ignition include the following:[4]
Carbon deposits form a heat barrier and can be a contributing factor to pre-ignition. Other causes include: An overheated spark plug (too hot a heat range for the application). Glowing carbon deposits on a hot exhaust valve (which may mean the valve is running too hot because of poor seating, a weak valve spring or insufficient valve lash)
A sharp edge in the combustion chamber or on top of a piston (rounding sharp edges with a grinder can eliminate this cause)
Sharp edges on valves that were reground improperly (not enough margin left on the edges)
A lean fuel mixture
An engine that is running hotter than normal due to a cooling system problem (low coolant level, slipping fan clutch, inoperative electric cooling fan or other cooling system problem)
Auto-ignition of engine oil droplets (Can be solved by using an oil catch tank) [6]
Insufficient oil in the engine
Ignition timing too far advanced
Detonation induced pre-ignition
Because of the way detonation breaks down the boundary layer of protective gas surrounding components in the cylinder, such as the spark plug electrode, these components can start to get very hot over sustained periods of detonation and glow. Eventually this can lead to the far more catastrophic pre-Ignition as described above.
While it is not uncommon for an automobile engine to continue on for thousands of kilometers with mild detonation, pre-ignition can destroy an engine in just a few strokes of the piston.
Knock detection
Due to the large variation in fuel quality, a large number of engines now contain mechanisms to detect knocking and adjust timing or boost pressure accordingly in order to offer improved performance on high octane fuels while reducing the risk of engine damage caused by knock while running on low octane fuels.
An early example of this is in turbo charged Saab H engines, where a system called Automatic Performance Control was used to reduce boost pressure if it caused the engine to knock.[7]
Various monitoring devices are commonly utilized by tuners as a method of seeing and listening to the engine in order to ascertain if a tuned vehicle is safe under load or used to re-tune a vehicle safely.
Knock prediction
Since the avoidance of knocking combustion is so important to development engineers, a variety of simulation technologies have been developed which can identify engine design or operating conditions in which knock might be expected to occur. This then enables engineers to design ways to mitigate knocking combustion whilst maintaining a high thermal efficiency.
Since the onset of knock is sensitive to the in-cylinder pressure, temperature and autoignition chemistry associated with the local mixture compositions within the combustion chamber, simulations which account for all of these aspects [8] have thus proven most effective in determining knock operating limits and enabling engineers to determine the most appropriate operating strategy.
Rich
Old 02-07-2017, 03:31 PM   #273 (permalink)
To make the fuel burn faster you could increase the compression ratio.
Engines that have had their compression raised run less timing.
Old 02-07-2017, 03:48 PM   #274 (permalink)
None of that has anything to do with the difference in vaporizing feul before the combustion chamber or in the combustion chamber.
The difference you claim is only that there is unburnt fuel after power or late in power. If that were true the exhaust would be much hotter then it already is or raw gas would be dripiping out the tailpipe. If 20-40% (some people claim their vapor systems go from 30-200mpg so basically 95%) of the fuel is just burnt as extra heat that would be enough fuel to melt the exhaust and especially the cat into a liquid ball of metal after awhile. I think my little buddy heater makes more heat than my converter and it runs for 4 hours on one of those little bottles. My truck dumping 4 gallons an hour for 4 hours even if it were only a 20% waste that's 3 gallons of gas burnt as pure heat in the converter or 2 feet of exhaust before the converter. That is a TON of heat.
Old 02-07-2017, 04:33 PM   #275 (permalink)
OK I am giving up on the site and this thread.
First NO ONE hnere has ever build a Vapor system.
Second no one here seems to even have any idea out side the box.
Third we are not even discussing the idea of what power might be had with 100% vapor of a gal of gasoline.
How about this:
How much does 1 gallon of liquid gasoline displace as a vapor? The saturated vapor volume of an average gallon of liquid gasoline when fully evaporated is 160 gallons of vapor at 60° F and sea level. When you convert 1 gallon of gasoline into 160 gallons of highly combustible fuel vapor you increase your nation’s fuel supply by 16,000% (16,000% of 1 is 160). If you paid $5 for just one gallon of liquid gasoline you would actually only be paying $0.03 (3 cents) per gallon of fuel vapor.
How can you convert 1 gallon of liquid gasoline fuel into 160 gallons of gasoline vapor and increase your fuel supply by 16,000%? There are two known and proven ways to convert liquid gasoline into fuel vapor. One is to heat the liquid fuel before it enters the engine. The other is using ultrasonic nebulizer technology.
( Note using the exhaust head is a old bad idea once an engine is on 100% vapor there is little exhaust heat, so you vapor system dies...)
If liquid fuel is heated to a temperature of 450 degrees F, the fuel is fractionalized by catalytic cracking and converted to smaller light molecular hydrocarbons, methane and methanol. Where can you get this kind of heat in order to fractionalize liquid fuel? Manifolds and exhaust pipes can reach temperatures of500°F to 1000°F.
It is a well documented fact that air pollution from internal combustion engines is caused by unburned carbon fuel. Today, all gasoline powered vehicles burn only finely divided particles or droplets that are sprayed from the carburetor or fuel injectors, into the engine cylinders. This is a very wasteful process of converting gasoline or diesel to energy. 20-30 % efficiency at best. Converting liquid gasoline to a gasoline vapors will easily give 5 times the mpg and near zero emissions.
In the old days engines ran very lean as demonstrated by the fuel needle valve. In the old days just 1 tiny needle valve did the work of 6 to 8 fuel injectors. In the old days all engines ran on a much leaner amount of (less) fuel.
All internal combustion engines were made to run on highly combustible vapor, not liquid. It is well known that fuel-lean running improves the fuel efficiency of all vehicles. In the old days, under cruising conditions, the carburetor engines always ran lean – about 15% excess air. In the old days liquid fuel was reduced (made leaner) to finely divided particles or droplets before they enter the combustion chamber above the pistons. The carburetors reduced the liquid fuel into a very lean fuel mist before the fuel entered the combustion chamber above the pistons. Very high gas mileage is achieved by simply reducing liquid fuel into what all combustion engine need – gas vapor.
Vapor burns much cleaner than gasoline and has a higher octane rating. A lean running engine (ie, an engine using more air than fuel) has a cooler combustion process than the typical ECM engine with a preset (never deviating) chemically correct mixture of 14.6 air : 1 fuel. Running cooler is also better for the engines. Cooler running engines means a reduction in heat damage and failure.
In the early 1930s, Charles Nelson Pogue equipped a Ford V8 coupe with a vapor carburetor he designed and built and got over 200 MPG. He drove the V8 Ford from Winnipeg, Manitoba Canada to Vancouver B.C. Canada. He traveled 1879.5 miles on just 14.5 gallons of gasoline (the entire distance on just 3/4 of a 20 gallon tank of fuel) A standard carburetor used 106.5 gallons (or five, 20 gallon tanks of fuel) on the same trip.
In 1977, Tom Ogle demonstrated a 351 ci. Ford getting over 100 miles per gallon. He used a multiple fuel vaporizing system that had a 3 gallon tank. His system used heat to vaporize the liquid fuel. He received patent number 4,177,779 on Dec. 11, 1979, which described “A fuel economy system for an internal combustion engine which, when installed in a motor vehicle, obviates the need for a conventional carburetor, fuel pump and gasoline tank. The system operates by using the engine vacuum to draw fuel vapors from a vapor tank through a vapor conduit to a vapor equalizer which is positioned directly over the intake manifold of the engine.”
An ultrasonic nebulizer can also convert liquid fuel into a vapor. Liquids such as water acids, salt solutions, fuels, acetones, ketones, etc., can be atomized (to convert a substance into very fine particles or droplets). Ultrasonic atomizing is carried out by focusing ultrasonic energy onto a liquid surface and by scattering liquid particles by the energy.
Vapor volume of a liquid is the number of cubic feet of vapor resulting from the complete evaporation of the liquid. The vapor volume depends on parameters of density, temperature, pressure and molecular weight which is affected by the variety of formulas for gasoline that is comprised of a wide range of hydrocarbons.
Using a common industrial formula: one liquid gallon = [(8.31) x (SG) x (387 cu ft)] / (MW) Where:
8.31 = pounds in a gallon of water
SG = specific gravity of liquid being vaporized
387 = At standard conditions, one pound-molecular weight of a material will evaporate to fill 387 cubic feet of space.
MW= molecular weight of liquid being vaporized
Using the approximate gasoline constants:
One liquid gallon of gasoline = [(8.31 pounds in a gallon of water) x (.70 approx. specific gravity of gasoline) x (387 cu ft)] / (105 molecular weight of average gasoline) = 21.4 cubic feet of vapor volume. There is 7.481 U.S. gallons in one cubic foot. Therefore one liquid gallon of gasoline = (21.4 cubic feet) x (7.481) = 160.4 gallons of saturated gasoline vapor. The vapor volume will vary based on the specific formulation of gasoline, pressure, and temperature. Ultrasonic nebulizer technology makes it possible to convert 1 gallon of gasoline into 160 gallons of highly combustible fuel.
How an ultrasonic nebulizer works to convert a liquid to gas.
Using an ultrasonic nebulizer, liquids in a vessel (such as a fuel tank) sit on top of a vibrating element. and a high intensity ultrasound is omitted. As waves move through the liquid, the liquid will begin to be pushed upward, making a small fountain. Off the surface of this fountain small particles will begin to float above the liquid and appear like smoke. This smoke like appearance is actually very fine vapor. If gasoline was used in this process the small particles that would appear like smoke would be very fine gas vapor. To move the very fine particles a small air flow/gas or vacuum is needed – like a small fuel pump or the vacuum that exists in all combustion engines.
Is the ultrasonic nebulizer technology to convert liquid gasoline into a more abundant (160 times more) vapor gas safe to use? A fog machine reveals that it is safe as a fog machine is a device which emits a dense vapour that appears similar to fog. This artificial fog is most commonly used in professional entertainment applications. Typically, fog is created by vapourizing proprietary water and glycol-based or glycerine-based fluids or through the atomization of mineral oil. Mineral oil is liquid petroleum which is a liquid by-product of the distillation of petroleum to produce gasoline and other petroleum based products from crude oil. If a fog machine can safely and effectively atomize mineral oil – a by-product of oil – then a similar device like an ultrasonic nebulizer can also safely and effectively atomize 1 gallon of gasoline to produce 160 gallons of gasoline vapor.
Who said the reason for high gas prices was because the World is running out of oil? George W. Bush did on March 5th 2008 ~ “We gotta get off oil, American has got to change its habits,”.. “It should be obvious to all, demand has outstripped supply, which makes prices go up.”
Old 02-07-2017, 05:15 PM   #276 (permalink)
ScanGauge <3
ThermionicScott's Avatar
You have to expect some skepticism with these things. Since I had not heard of these concepts before this thread, I was looking forward to your results once you got a system lashed together...
Best tank (so far): 32 MPG
Old 02-07-2017, 05:36 PM   #277 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Then why not heat the fuel, presurize it then nebulize it?
Old 02-07-2017, 05:52 PM   #278 (permalink)
So there is no converting an exsiting fuel injection car to vapor?
Old 02-07-2017, 06:03 PM   #279 (permalink)
Well I have theory but was looking for help.
I was hope there might be such help here.
Rich
Old 02-07-2017, 06:07 PM   #280 (permalink)
Simple fact pressure raises the boiling point of liquid IE The pressure caps on Radiators.
Nebulixing is only finer droplets... we want VAPOR.
lies, scam
